Why Sony ks60r200a becomes green yellow picture?
Yellow light instead of green on my machine what does this mean
PS3 yellow light typically is related to the CPU or GPU that has become unseated due to overheating. Your best option is to contact Sony send in the unit and they will fix it for a fee it was $150. This is often referred to as the "yellow light of death".
Jul 04, 2016 | Video Game Consoles & Games
I turn it on and it become red around the green light and become yellow after i had it fix for changing the reading disc
Did you have sony fix it or someone else? You have a motherboard failure and your system will need to be serviced again.
Sep 03, 2013 | Sony Playstation 3 (PS3) Console
Yellow tint
How to remove password sony xperia LT26i
May 23, 2013 | Sony Ericsson XPERIA S LT26I Nozomi Arc HD
Sony tv
TURN TV OFF, PRESS 'DISPLAY' ON REMOTE, THEN' VOLUME UP', THEN 'CHANNEL 5', THEN HIT 'POWER BOTTON', ALL IN THAT SEQUENCE, FAIRLY FAST.. THEN JUMP BUTTON( 3) TIMES, THEN CHANNEL 2( 9 )TIMES THAT SHOULD BRING UP LAMP HOURS
Feb 24, 2010 | Sony KDS-60A2000 60" HDTV
Audio is good, screen is a green/yellow
is a problrma in antenna cable that you check the wiring
Jan 05, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hi,I can play a DVD disc on the system and get sound from the surround sound speakers but I can't get a picture on the tv,Sony Trinitron.The connetions are from the DAV S500:(DVD only)red and white cable...
First try with yellow video output of DAV-S500 in yellow video TV input to get its picture. (yellow output means composite video out)
Green-Blue-Red video output is component output that will be turn on when you switch the unit into Progressive picture mode, that option would be available in Menu of DAV-S500
Hope this info will help you.
Thanks.
Nov 29, 2009 | Sony DAV-S500 System
3 year old Sony KDS R50XBR1 suddenly no picture, no sound
MY SONY KDS-R50XDR1 TV ITS PLAYIN GREEN THERES NO BLUE HOW CAN I SOLVE THIS PROBLEM.
Feb 10, 2009 | Sony KDS-R50XBR1 50" HDTV
Picture keeps turning green or yellow
This could be the screen amp board or a picture tube shorting.
$$$ yes
Jul 11, 2008 | Sony KP-57WS520 57" Rear Projection...
Picture goes out periodically
Sound like color problems, could be convergence going out. Not quite sure of yellow color, but you could be loosing one of the 3 colors red blue green, this could be why you see yellow.
Sep 24, 2007 | Sony KP-61S75 TV
Sony wega rear projection
Many Sony LCD projection TV's have a problem with optic block failures and your description is exactly what happens. Picture starts turning yellow or green and blotches of yellow or green. Many Sony model have an extended manufacture warranty on these optic blocks and if you get me the model and serial # of your unit I can provide more info.
Nov 13, 2006 | Sony Grand WEGA KDF-42WE655 42" Rear...
23 people viewed this question
k24674
