Question about Konica Minolta Minolta Di450 Di470 Di550 Copier Mt Toner 502a 8936-902
How to remove on screen preventive maintenance time m5
    Problem Solver:
  • 19 Answers
You need to get into service mode (utitlity, meter count, stop 0 0 stop 0 1) then go to counters, maintenance counter. reset the counters there, and your on screen message should go away.
Posted on May 12, 2014
    New Friend:
  • 3 Answers
There is no M5 preventive maintenance only M2 and M3 please conform
Posted on May 10, 2014
On my toshiba tecra m5 laptop varius coloured lines keep appearing on my screen
That could be either a bad connection or the display is failing. Check on an external screen and if bad on that it is probably the GPU.
Jan 17, 2014 | Toshiba Tecra M5-S433 Notebook
Acer m5 481pt won't start. screen black, keyboard lights, fan turns on
Remove the battery and the adapter into the wall. When you boot up hold F10 or F12 (if one doesn't work, alternate).
Failing that, it could be a disk or other hardware failure, and you're going to need to take it in to be serviced. Good luck!
Dec 06, 2013 | Acer Aspire ASM5-481PTG Series, M5-481PTG...
My Toshiba Tecra M5 won't boot. The power light flashes on and off, the fan starts but nothing is on the screen. How can I get it to boot?
Well, it sounds like you have a hardware problem. Start by removing the Ram and hard Drive from the machine and insert a boot disk. If your not getting the Tecra Splash screen when you press the power button, the screen that appears before the windows boot screen, you may have a bad Monitor or Burned background lamp or faulty BIOS install or upgrade. Any of which will give you this problem.
Dec 26, 2010 | Toshiba Tecra M5-S4332 Notebook Pc
Garmin iQue M5, Not aquiring satellites
Two possibilities - Antenna (in power cable) or electronics related to antenna. First, do a hard reset. Place the pen top into the RESET hole for 3 seconds...
Next, when the unit is powered, page over to the screen showing satellite signal strength....
If NONE appear within 1 minute (and you are outside and NOT under trees), you have an antenna or antenna interface issue.
Garmin WILL repair the unit for 3 to 4 times its value... A 265WT GPS is cheaper, faster and more accurate. The IQUE is no longer worth repairing....
-Jim
Apr 07, 2009 | Garmin iQue M5 GPS Receiver
Phaser 860 maintenance tray A stuck
1. The Maintenance Drawer will not come out. - Often times this can be overcome by waiting 2 minutes for the ?Hot Ink? timer to expire, then remove the Maintenance Drawer. 2. If the printers Maintenance Drawer is locked in place and can not be removed and there are no cleaning functions currently taking place then the Maintenance Drawer can be unlocked by removing the right side cover and move the Cap/Wipe/Purge belts evenly down to the home position. This will raise the sensor flag from I/O Left and disengage the locking pin that is preventing the Maintenance Drawer from being removed. 3. If either Maintenance Drawer Guides (Blue Plastic Rail guides) have been replaced or removed and reinstalled and this is preventing the proper insertion of the Maintenance Drawer then check on the outside of the chassis frame that both rear locking tabs for the rail guides are protruding through the printers frame and are properly seated and notched into place. ? If they are not properly installed and seated then remove the rail guides and reinstall and then test for proper insertion and removal of the printers Maintenance Drawer. 4. Obstructions or spilled ink (wax) may be covering the Drum Maintenance rail guides and preventing the proper insertion or removal of the Maintenance Drawer. ? Check the printers Drum Maintenance Rail guides for any paper scraps or spilled ink or leaking ink from the Printhead. Make sure that there is no spilled ink under the Maintenance drawer waste tray and that it is seated properly. TROUBLESHOOTING TIPS AND HINTS: In order to provide more clearance when removing the printers Drum Maintenance rail guides, use the X-axis gear to move the Printhead away from the drawer guide that you are removing/installing. Also raise the Cap/Wipe/Purge assembly to reduce interference. When a drawer rail guide is mounted, double check its rear locking tabs where they go through the chassis side frame. Both blue tabs should be visible on the outside of the frame of the printer.
Apr 28, 2008 | Office Equipment & Supplies
Repair on Datacard sp35 locate in Houston Texas
Do you have found a repairer for your datacard ?
Feb 27, 2008 | Datacard SP35 Printer
Garmin M5 Pocket pc
Can I buy your broken M5?
yoko
mmthinman@hotmail.com
(for my art project......)
Aug 06, 2007 | Garmin iQue M5 GPS Receiver
Garmin M5
Could it possibly be your backlight setting? I had a problem with my screen staying dark until i set the brightness level.
settings -> system -> backlight -> brightness -. then adjust your settings.
Konica Minolta Minolta Di450 Di470 Di550 Copier Mt Toner 502a 8936-902 Logo
367 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
