Confirmation numbe Have confirmation number but iternary has not printed
Tip
Numb Hands in the Morning
Numbness entails a loss of sensation in any part of the body. Hands aren't an exception. However, having numb hands when you wake up in the morning isn't a common symptom in healthy individuals. It can involve one hand or both hands.
In some circumstances, numbness may not be the only symptom. It is normally accompanied by other symptoms such as burning sensation, pin and needles, tingling sensation and electric shock-like sensation.
Sometimes, you may feel your hands become weak and uncoordinated.
Should you worry about this strange feeling?
Yes.
There are several causes of numb hands in the morning. Anything that compromises the blood supply to the nerves of your hands can cause numbness. In some conditions, compression to the nerves of the hands will make you lose sensation in your hands.
Below, are the most common causes of numb hands in the morning:
Peripheral Neuropathy - this happens following nerve damage. It can be due to infections, side effects of medications, etc. This condition can manifest as tingling/prickling sensations in the affected hand. It is usually associated with increased sensitivity to touch. The hands may become painful and weak.
Carpel Tunnel Syndrome - this is another condition that can present with tingling sensations. It is one of the causes of numb hands in the morning. This occurs when there is compression of the nerve that pierces the wrist to supply parts of your palm. The nerve called median nerve. This can be caused by underlying comorbidities like hypertension (high blood pressure), diabetes, thyroid gland dysfunction and autoimmune diseases.
Carpel tunnel syndrome may occur also during pregnancy and in individuals who have sustained injuries to the wrist or bone fracture.
Injury to the ulnar nerve - apart from median nerve, the ulnar nerve also plays important role in nerve supply. It goes from the brachial plexus and runs downwards to the arm and the forearm. This nerve is at risk of damage in individuals who involve themselves in sports like baseball, tennis or golf which needs a lot of grasping. When involved in injuries, trauma to the ulnar nerve which passes medially to the elbow joint can happen.
Like in an elbow joint dislocation or when bones forming the elbow joint get fractured. Injury to ulnar nerve also present as numb hands in the morning.
Diabetic neuropathy - this is also known to cause numb hands. However, it occurs in patients known to have diabetes. In fact, diabetes has devastating effects on the nerves and vasculatures in different parts of the body. When these nerves are exposed to elevated blood sugars for a longer duration, may undergo deterioration. The blood vessels in diabetic people are also said to undergo changes that reduce their ability to carry oxygen and nutrients to the nerves.
This poses further insult to the nerves. The nerves lose their function causing the loss of sensation. These individuals will present with numbness among many other symptoms.
Vitamin B12 deficiency - vitamin B12 helps in blood cells and DNA formation. It is one of the nutrients whose deficiency may present as numbness of the hands. It is common in individuals who strictly feed on vegetables. Since they do not eat animal meat which is rich in vitamin B12, such people are prone to its deficiency. Vitamin B12 deficiency is also common in individuals who take an excessive amount of alcohol.
It is also in diseases of the stomach and intestine like atrophic gastritis, celiac disease and Crohn's disease that hinder its absorption to the circulation.
Injury to the brachial plexus - this is a group of nerves that give branches from the neck, running to the arm, the forearm, wrist, and hands. It is rare for someone to get brachial plexus nerve injury. However, in situations like when there is over outstretching of the upper limbs or accidents like falling on an outstretched hand, injury to the brachial plexus may happen.
Additionally, underlying conditions like inflammation or tumors may cause compression to these nerves, rendering them malfunction. This also will present with the loss of sensations (numbness) of the hands.
If you feel numbness in your hands when you wake up in the morning, that might entail one of the above causes. It's important to see your doctor whenever this happens. You might need a thorough neurological examination or a blood test to check levels of sugar in your blood. In fact, management of this condition will need to be individualized. The management can be as simple as taking vitamin B12 supplements in case of vitamin B12 deficiency or having electrical nerve stimulation treatment.
You might want also to perform imaging studies like X-ray to check for any fracture or a Doppler ultrasound for any perfusion problems.
on Nov 03, 2017 | Miscellaneous
What can cause numbness & tingling in both arms and legs for an extended period of time?
numbness in the arms is typical carpal tunnel syndrome, i had it , had a neurologist do some tests and had both hands done at once, i suggest onyly 1 hand at a time, numbness is due to pressure on a nerve fot the legs numbness on the outside of the thigh is usually pressure on a nerve in the groin area usually due to weight or wearing a belt to tight over time.
Jul 03, 2014 | Health & Beauty
Need a manual for a Frigidaire Gallery Self-Cleaning Convection Oven/stove Model CFEF388RES1
Try the following link, but recheck your model number it comes up invalid. Just type the right model numbe into the search box and you should be taken to a page where you can download a manual which you can print. Good luck
Aug 28, 2013 | Heating & Cooling
How to I turn off the automatic printing of the fax logs.
To change fax confirmation
1. Press Setup.
2. Press Print Report, and then Fax Confirmation.
3. Press the right arrow button to select one of the following, and then press OK.
Off - Does not print a fax confirmation report when you send and receive
faxes successfully. This is the default setting.
On Fax Send - Prints a fax confirmation report for every fax you send.
On Fax Receive - Prints a fax confirmation report for every fax you receive.
Send & Receive - Prints a fax confirmation report for every fax you send and receive.
May 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
How can I get a FAX Confirmation printed out on the HPJ4680?
If you require printed confirmation that your faxes weresuccessfully sent, follow these instructions to enable fax confirmation beforesending any faxes. The default fax confirmation setting is Off. This meansthat a confirmation report is not printed for each fax sent or received. Aconfirmation message indicating whether a fax was successfully sent appearsbriefly on the control-panel display after each transaction. NOTE: You can include an image of the first page of the faxon the Fax Sent Confirmation report if you choose On Fax Send or Send &Receive, and if you scan the fax to send from memory To enable fax confirmation
1.Press the (Setup) button.
2.Press right arrow to select Print Report, and then press OK.
3.Press right arrow to select Fax Confirmation, and then press OK.
4.Press right arrow to select one of the following, and then press OK. Off Does not print a fax confirmation report when yousend and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every faxyou send.
OnFax Receive Prints a fax confirmation report for every fax you receive.
Send& Receive Prints a fax confirmation report for every fax you send andreceive
Jan 10, 2011 | Office Equipment & Supplies
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
Ink does not last after 6 pages ... prints some than too light or not at all. ink jammed? can i have a phone numbe
i does really because my printer wont print a poem for me for school an i already printend 6. and its still printing. step 1 press & hold power. step 2 while holding power hold the x button then release them both. that should work.
May 04, 2010 | Canon PIXMA iP1600 Printer
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
