Question about Wolff Sunvision Pro 24S Tanning Bed
Fans stopped working on sunvision tanning bed
Fans keep running after bed shut off
The fans will run until the temperature has been reduced. Just because you shut it off doesn't mean it gets immediately cold. It's just like the fan on a car that keeps running after the car stops.
Jan 03, 2015 | Wolff Sunvision Pro 24S Tanning Bed
Sunvision facial tanning bulb buzzing and flicker's and won't light
It is not the socket. If the bulb is installed correctly, there is a starter on the ballast that needs to be replaced.
May 07, 2014 | Wolff Sunvision Pro 24S Tanning Bed
Tanning bed manual
http://tanning-bed-parts.com/documents/ETS%20Tan%20Documentation/Manuals/22680.pdf
I was able to find you a PDF Manual for the tanning bed model you listed, the key to looking for it online was to enter Wolff Sunvision Tanning bed......without the Wolff part it didn't come up.
Hope this helps and good luck!
Apr 28, 2014 | Health & Beauty
Sunvision tanning bed
REd + Black - and white common.
Feb 27, 2014 | Health & Beauty
1986 sca wolff 328sl tanning bed wont stay running
Consult manufacturer. You can track that down online. You may have a over-temp switch inside the bed. If so, then either the switch is bad or the bed is getting too hot. Have a trained technician to check voltage going to bed, if voltage is wrong that can cause bed to overheat. Make sure all fans are running, replace any fan that is not running. Clean all dust out of bed with vacuum and brush while you have it open.
Dec 15, 2012 | Wolff Sunvision Pro 24S Tanning Bed
How to repair a tannin bed model H-24RSB
Have a trained technician to check for wrong voltage going to bed. Then for burned out components and wiring inside the bed. Turn power off to bed before doing this.
Nov 15, 2012 | Wolff Sunvision Pro 24S Tanning Bed
What does the end of the cords look like on a sunvision 24 tanning bed
It should be like a big black power cord with a plug on one end.
Aug 28, 2012 | Wolff Sunvision Pro 24S Tanning Bed
I have a sunvision 24 tanning bed and it isn't coming on what do i do
Have a trained technician to: Check main breaker, check that bed is getting power to it, check for bad fuse on back of bed, check for burned out wiring inside of bed at main relay, check that the timer is good.
Need info on changing fan motor on sunvision tanning bed
Sunquest repair manuel -
https://docs.google.com/viewer?a=v&q=cache:RHuta0rhh0UJ:www.wolfftanningbed.com/files/Sunvision%2520Pro%252024S%2520Tanning%2520Manual.pdf+&hl=en&gl=us&pid=bl&srcid=ADGEESiOZAyvaJoGk2XbMLNiN6HBrbcakHM2K0Ueegni817TYN8RJZmcoxwgkvEhbTnez0fQXKeYfAagL-vGcQOZe-_Lz1A8lISeW2omXte5lo7_wf0N6Ksg9heMx9RvHP7NvzHekFW_&sig=AHIEtbTIgYvCR-poN4KvkaVWUdCqD8mjDA&pli=1
Feb 05, 2012 | Wolff Sunvision Pro 24S Tanning Bed
Wolff Sunvision Pro 24S Tanning Bed Logo
138 people viewed this question
Top Wolff Health & Beauty Experts
Steve
NOEL
NOEL
Are you a Wolff Health and Beauty Expert? Answer questions, earn points and help others
