Question about Acuderm Acu-cautery Kit
How can i open to change batteries - Acuderm Acu-cautery Kit
Cannot open battery compartment to change battery's
All you need to do is slide the battery cover to the Open position, then open the battery cover to access the batteries. If it doesn't open easily you may have some corrosion on the batteries holding the cover closed.
Mar 01, 2016 | Casio Exilim Ex-fh20 20x 9.1mp Digital...
Change the batteries in my hand held can opener modelS1212
Put both thumbs in the center of the flat side (the bottom). Apply downward pressure and move your thumbs toward the "tail" of the can opener to slide the bottom off and reveal the battery compartment.
Sep 23, 2014 | Kitchen Appliances - Others
Can't open to change battery
Google the model number for "manual" which if found will have instructions for replacing the battery or take it to some place like walmart who will open and replace it for you.
Nov 05, 2012 | Watches
I HAVE A SURESAFE20ES; BATTERY IS DEAD; WHERE DO I OPEN TO CHANGE THE BATTERY? IT'S PRETTY URGENT
You need to charge the battery...not change it. If you can get a charge into it try a factory default code like 7777 to try to reprogram the safe.
Jul 04, 2012 | Cars & Trucks
Change battery
please specify remote model for possible solution
May 17, 2012 | Dryers
Hello, Ineed to change the battery of the time and date. I want hnow the number of the battery to buy one and changing. Regards Josephine.
Sounds like you uwant to change your CMOS battery. You should bring this to a professional so as to not damage your computer. If you don't know what you are doing to will cause more damage than a worn out CMOS battery
Sep 13, 2009 | Compaq Presario Notebook
Keypad and remote will not open door
Did the remote and keypad work before you changed the battery? Changing the battery in the keypad should not affect the remote.
Jun 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
After changing the battery nothing can be changed, no function possible and"open" remains written on the display, the type of the battery is clt 1616
The battery is CTL 1616 and I had the same occurance when I opened up my model Casio model 3043. I needed to use the battery to test my model 2767 and find out if a new battery would bring it back to life (yes, it still lives). After replacing the battey back into my 3043, I jumped the (ac) to (-) and at first the watch would indicate all was well but then it would revert back to "open". I tried over and over to try and get the "open" display to clear but I was not successful. I then thought to go ahead and replace the back on the case to see if the three contact springs would change the display and sure enough, "open" no longer was in the display. The watch works perfectly as before. As for the 2767, as soon as I jumped the (ac) to (-) the "open" display went away. There is only one spring contact to the back case on the 2767 model. Unfortunately I do have an extra spring that fell out when I opened it up and I have no clue as to where it goes. I have not found anyone who can help me on the location for the shorter spring. Any advice would be most helpful.
May 20, 2009 | Casio Triple Sensor Pathfinder PRG60-1AV...
Changing the batteries
I'll give you info on how to change batteries in two different type mouse units. Not sure what type you have.
The normal way to change batteries on a mouse is to turn it over and open the little door on the bottom The compartment holds 2 AA batteries.
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this.
Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Aug 16, 2008 | Logitech 931150 Mouse
Acuderm Acu-cautery Kit Logo
422 people viewed this question
Top Acuderm Sport & Outdoor - Others Experts
Bill Eager
Are you an Acuderm Sport and Outdoor - Other Expert? Answer questions, earn points and help others
