Question about Refrigerators
How to remove drip pan - Refrigerators
  • 33 Answers
SOURCE: Cannot remove drip pan
im sorry but that drip pan cannot be removed you might have to do the best you can with it in there.
Posted on Jan 03, 2008
freetek
  • 5568 Answers
SOURCE: mice poo in the drip pan.how do I remove and clean?
Normally the pans are simply lifted a little to clear a lip formed by the frame and then pulled forward. If it hasn't been out before (or for a while) it may be necessary to slide a metal ruler or similar under the frame and pan to free it from the floor. They have relatively large surface area and it would take much gunk under it to make it seem immovable.
Posted on Jan 08, 2009
Maytag317
  • 1136 Answers
SOURCE: need to remove drip pan
Hi, This pan can not be removed without taking the whole frame apart. Best thing is to try and get a long brush (hardware stores sell them) and try and clean it that way.
Using very hot water might help loosen the grime in the pan.
I hope this helps you.
Please let me know if I can assist you further.
Vic
Posted on May 30, 2009
woodchuck789
  • 4066 Answers
SOURCE: drip pan
You may can remove it from the rear behind the cardboard cover or from the front behind the removeable kick panel.
Posted on Aug 14, 2009
sodeep
  • 3267 Answers
SOURCE: how do i remove a drip pan from a kenmore refrigerator
The drip pan collects water when the freezer goes into a defrost cycle. Most times there is very little water and the water evaporates quickly. When there is a problem with the freezer or the water does not evaporate between defrost cycles, the drip pan fills with water. If the front bottom of your refrigerator has a grille, you access the drip pan from the front. If there is no grille, access the drip pan from the rear.
Instructions
Rear Access
1 Unplug the refrigerator from the wall outlet. Pull the refrigerator away from the wall so that you can access the rear of the refrigerator.
2 Look under the refrigerator with a flashlight and locate the drip pan. Often when people install refrigerators they neglect to pull the packing from around the drip pan. The drip pan may have tape or styrofoam around it.
3 Remove any packing material away from the drip pan and pull the drip pan out from under the refrigerator.
Front Access
4 Pull the grille at the bottom of the refrigerator below the refrigerator door with your fingers. The grille secures to the refrigerator with plastic clips.
5 Remove any debris from the access area and throw the debris in the trash. The coils and fan under the refrigerator attract dust and dirt. Clean out the area with a lint brush if you have one.
6 Pull the drip pan out from under the refrigerator.
Posted on Apr 20, 2012
Model# kfcs22evms8 kitchen aid fridge- how to clean drip tray? Can't get at it.
Clean Refrigerator Drip Pan, Clean Walls - YouTube
? 2:55
https://www.youtube.com/watch?v=I9YP0iH_zho
Aug 5, 2008 - Uploaded by Handyman Matters
Scheduled Home Maintenance: clean refrigerator drip pan and wipe ... leaking,Kenmore,Sears,Whirlpool,KitchenAid,Roper,10677292790 ...
How to Find the Drip Pan on Refrigerator ' Home Guides ...
homeguides.sfgate.com > Real Estate Rentals & Leases > Get out of Leases
The drip pan on your refrigerator is a receptacle that catches condensation flowing from ... Occasionally you may need to get to the drip pan to clean it, remove a ...
KitchenAid refrigerator drip pan Questions & Answ
Dec 16, 2015 | Refrigerators
Drip pan
The drip pan is located behind the toe panel (grille) at the bottom. The pan should be located in the left side. If you have auto defrost, the pan may or may not have water in it. It is likely to have accumulated grunge which can be removed by a good wash and rinse, being careful to avoid breaking the pan during cleaning. Reinstallation is the reverse of removal.
Sep 12, 2012 | Maytag MZD2766GES Side by Side...
How do i remove a drip pan from a kenmore refrigerator
Instructions
Rear Access
Front Access
Apr 20, 2012 | Kenmore Refrigerators
Drip pan replasment on mzsd2665heq
Hello there,
To remove and replace the drip pan on your refrigerator, please follow the instruction below:
  1. Unplug the electrical cord of the Maytag refrigerator from the power outlet before attempting to remove the drip pan.
  2. Detach the grille on the bottom of the refrigerator in the front, pulling the grille off by hand.
  3. Place a towel in front of the refrigerator to clean up any spills that may occur while pulling the drip pan out from under the appliance.
  4. Slide the drip pan forward until is free of the Maytag refrigerator.
  5. Empty the drip pan in the sink.
  6. Replace it with a new one,
  7. Then you reverse the process to reassemble it back together,
  8. Plug it back to the power outlet.
Hope this helped. All the best Elect_Comp
Sep 21, 2011 | Maytag MZD2766GES Side by Side...
The drain pan under my refrigerator stinks really bad how can i remove it to clean it
The drain pan can be removed by lifting up the refrigerator and removing the four torex screws on the bottom of each side of the refrigerator. Use 2 pieces of 2x4 to hold up each side of the fridge while removing these screws. After removing the screws the bottom panel will separate from the refrigerator and you can remove the drip pan from the panel as it isn't attached by screws. The pan is VERY fragile and removing the drip pan is a two person job. I recommend just pouring bleach into the drip pan to kill any bacteria causing the smell by removing the back panel which will be held on by several quarter inch screws. You'll see the white drip pan on the right hand side of the fridge looking from the back.
Aug 06, 2011 | Refrigerators
How do I remove the drip pan from a side by side 6.5 Ingliss model I525AGXR002
If you have a removable drip pan get the kick plate off there and that pan should slide out the front. This machine is made by Whirlpool and I am thinking you maybe have a drip pan above the compressor. In that case yall would remove the rear dust cover and use a rag to clean out the pan as it is bolted down to the compressor. Model number don't show up on repair clinic or appliance parts pros.
Mar 27, 2011 | Refrigerators
How to replace a cooktop drip pan
It's really simple. Remove the burner grates, removed the old drip pans, then drop in the new drip pans. You can order a new drip pan from partselect.com if you don't have one yet. Let me know how this works out and if you need any further help.
Benjamin
Nov 04, 2010 | GE Profile JGP636 Gas Cooktop
HOW DO i GET TO THE DRIP PAN ON MY KENMORE REFRIGERATOR MODEL 106.57024601
Hi!
you can get to the drip pan removing the base grill in front of the unit. There is no need to empty the tray, since the water that drips into it is consumed by the evaporator. Some drip pans are even fastened by screws and can't be readily removed.
Good Luck!! Don't forget to rate this post!!
Oct 02, 2010 | Kenmore Refrigerators
Jan 03, 2008 | GALAXY Microsystems 63702 Top Freezer...
Refrigerators Logo
13 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
