Question about Yamaha DVD-S530 DVD Player
Dvd-s530 tray won't open
Tray won't open, blocked
2 Suggested Answers
SOURCE: Yamaha dvd player S530 disc tray no open, Outer
I downloaded a service manual for this unit. It showed where the manual release mechanism was. Released the cd stray, examamined the mechanism and found nothing. Added a little lubrication to some of the moving parts. Reassembled, and everthing now working fine.
Posted on Dec 20, 2009
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
Samsung v8500 dvd stuck
i can understand is this trays is stuck. see the steps and fix it.God bless you.
  1. Open the housing by removing mounting screws and anything blocking the tray. Press the open/close control to the extend tray, then unplug the unit. To remove a clip-on tray front, brace the tray and slide the panel to one side.
  2. Unplug cables between the front panel and the interior. Remove any screws securing the front panel and remove the panel. If it won't move, check beneath it for clips or additional screws.
  3. Remove the hold-down on top of the disc tray and gently pull the tray out of the player. Clean the travel rail and guides with a swab dampened with denatured alcohol. Lubricate lightly with white lithium grease.
  4. Remove the drive belt (using gloves or tweezers) to inspect for dirt, water, or damage. Clean with a lint-free cloth moistened with denatured alcohol. If the belt is damaged, replace it.
Oct 03, 2012 | Samsung DVD-V8500 DVD Player/VCR
CD cannot load, will not eject, had to wind down transport manually to get CD out
see this steps and fix it. God bless you
Service a DVD player disc tray:
Oct 02, 2012 | Televison & Video
Monitor doesnt want to open
SEE THIS CAUSES AND FIX IT. God bless you
Oct 01, 2012 | Dual XDVDN9131 Navigation system with DVD...
Yamaha dvd player S530 disc tray no open, Outer player shell is off and no dvd nor broken parts, cannot find a manual release button? is their a remedy or a service manual for this.
Dec 15, 2009 | Yamaha DVD-S530 DVD Player
Philips DVD 723 . the tray is not opening. blocked message comes.
There will be a slotted hole on the underside slide a screw driver across this will manually activate the tray dogleg and will part open the tray for you.
Dec 05, 2009 | Philips DVDR3380/05 DVD Recorder
Open dvd tray blocked with a dvd
There is a place to put a paper clip and push all the way in and will open tray manually.
Dec 03, 2009 | Packard Bell Easy One Silver 2120 Notebook
MY DVDR3380 TRAY WILL NOT OPEN, SAYS ITS BLOCKED
I had the same "Blocked" problem and solved it - by using a rubber band! Unplug the machine and take off the outer cover. Remove the DVD reader and take off the cover to the reader - you can now easily recover the DVD that was stuck in the machine. Now slide out the actual DVD tray, you will have to bend back a couple of restraining bars to get the tray out completely. You should now see a small white wheel which is actually the end of a concealed electric motor. There will also be a larger black pulley which controls the movement of the DVD tray. If there is no band connecting the pulley and the white wheel, that is your problem and I solved it with a small elastic band. Put everything back and turn on, wait for all the messages to clear and press the eject button - the tray opens simples. It has taught me never to force the tray in manually, but to always use the eject/open button.
Aug 22, 2009 | Philips Televison & Video
Yamaha S661 Player wont play multi region
This one is for S530, S540, S550, S557, S560, S600, S657. It's worth a try. Tell me if it works.
  1. Open the disc tray
  2. Press 9, 9, 9, 9, 0
  3. Press ENTER
  4. Close the disc tray
Apr 13, 2009 | Yamaha DVD-S661 HDMI DVD Player
I cannot open the DVD drawer on my Philips DVDR3480 DVD RECORDER – it just won’t open? The screen display just keeps saying ‘Error’. Any help is appreciated.
I have two of these dvd recorders and both have the exact same problem where the drive won't open. It opens fine when there is a disc in the tray. So I just unscrewed the cover, press the white part which would be over the center of the disc as it's trying to open, it should then open. Then just make sure there is always disc left in the tray.
Nov 26, 2008 | Philips Televison & Video
Yamaha DVD-S530 DVD Player Logo
73 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
Electro Med Services...
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
