Sharp HDTV LCD Screen keeps resetting to wrong position for computer use
I have a 42" Sharp LCD HDTV with a Dish Network satellite receiver connected to HDMI input 4 and a computer connected to input 7. Lately, every time I switch to computer the screen is reset to the wrong position and changing the position manually in the TV's menu works until I switch away again. I can't change the default setting to keep viewing the computer in the correct position--both vertical and horizontal positions are off every time I come back. This use to only happen occasionally, now it's all the time. How do I change the default position to the correct spot. Horizontal should be 61 and vertical should be 50. Currently the default setting continues to reset to horizontal 58 and vertical 28.
SOURCE: Banding on LCD TV
you need a new motherboard
Posted on Feb 28, 2008
  • 2035 Answers
SOURCE: Strange Flicker with HDMI components
Reset the yamaha player to factory sttings and check if the issue still exists ,unplug all the cables and replug the cables if the issues still exists its the problem with the Yamaha receiver, please get it changed as its a new player................................
Posted on Jun 10, 2008
  • 405 Answers
SOURCE: Connecting to Dish Network receiver/tuner
Posted on Jun 27, 2008
SOURCE: ps3 defaults to 576p when connected through onkyo 606 receiver
You have to tell the PS3 what the Okyo can do and it probably cannot do 1080P 60Hz (but can likely do 1080P 24Hz).  Try ticking more resolutions in the PS3s setup
Posted on Sep 03, 2008
  • 346 Answers
SOURCE: Blue horizontal and vertical lines
poor convergence
Posted on Nov 12, 2008
3D tv issues with HD channels on Dish Network
check screen resolution of your lcd tv & receiver too
Aug 24, 2012 | Dynex DX-L42-10A 42 in. LCD TV
I have a picture but no sound sound on HDM2.I have dishnetwork. There is a very minimal amount of sound for about 5 miniutes then it goes away. I can turn TV off and back on again and I have some sound...
Reset the receiver by unplugging it for 10 seconds then plug it back in. Unplug the HDMI cable from the TV and the receiver and plug it back in. If you are still not getting any sound connect another component (VCR, DVD Player, etc.) to the same TV, using same cable, same input, and same channel to see if it works. If it still doesn't work with the other component, replace the cable. If it works then give us a call at 1-800-333-DISH (3474) for some additional troubleshooting. We hope this helps. Thank you for being a valued DISH Network customer.
Phillip Chang
DISH Network Customer Service Representative
Feb 12, 2011 | RCA L42FHD37 42 in. LCD HDTV
When my dish network satellite box automatically switched channels to record a scheduled TV show recording, the channel switched and when it did only the top dislay of what channel it was on came up and...
Hello! This is what we call a black screen with banner. If you unplug the receiver for ten seconds this will reset the receiver and should correct this.
Daniel Busa
Jan 13, 2011 | Olevia 742I 42 in. LCD TV
Just moved my TV to a home with cable. It was hooked up to Dish network. there is no signal. Thank you.
We would be happy to help get your DISH Network signal back.The first thing we want to check is if there is anything blocking the signal toyour satellite dish like tree branches, severe cloud cover, or snow build-up.If it is safe to do so, remove the obstruction or wait for it to pass. If thatis not the case then reset your receiver by unplugging it for 10 seconds thenplugging it back in, the reset may take up to 5 minutes to finish (note: thereceiver's power plug usually has a red tag attached to it). At this point wewant to check the connection between your receiver and the outlet; please visitthis link and select the model receiver you are using to check the wiring ofyour receiver: you have check the connections perform a check switch test. Press the menubutton, then the numbers 6-1-1 on your DISH remote, this should take you to thepoint dish screen, select check switch on the right, then test on the bottom ofthe screen. Once the test is complete exit the menus and let the receiveracquire the signal (If Error 836 appears, do not save the matrix, cancelit and call our 24/7 customer support number listed below.). After all thesesteps if the receiver is still not getting the signal it should please give usa call on our 24/7 customer service line 1-800-333-DISH (3474) for additionaltroubleshooting.
We hope this gets your signal back. Thanks for choosing DISH Network!
Phillip Chang
Nov 12, 2010 | Olevia 742I 42 in. LCD TV
I have an LG 42LG70 42 in. HDTV LCD TV. Whenever I have my brightness setting below 40, my Dish DVR will no longer respond to its Dish issued remote control. If I turn the brightness anywhere above 40,...
Tries unplug,replug the DVR box an hour later.The box should reset itself and update it software.The box should work normal again.Not,call Dish Network to replaced the box,have intermittent problems.
Aug 26, 2010 | DISH Network ViP722 DTV Receiver /...
After programming my NEW Harmony One Logitech remote I can't get it to change channels on the Dish HDTV DVR along with a bunch of other problems.
To control a Dish Network PVR/Satellite, it needs to be set to respond to the default Remote Address (1).
To reset your Dish Network PVR/Satellite to the default Remote Address:
1. Press SYSTEM INFO on the receiver's front panel. The System Information screen displays on the nearby TV and shows the Remote Address.
2. Using the original Dish Network remote, press and hold SAT on your remote control for about three seconds, until all of the mode buttons light up, and then release SAT.
3. Using the NUMBER PAD, press the 1 button
4. Press POUND (#). If you entered the address correctly, SAT will flash three times.
5. Press RECORD. Make sure the Remote Address you see on the System Information screen is 1.
6. Press the SELECT button on the front panel to close the System Information screen.
7. Your Harmony remote should now control your Dish Network PVR/Satellite box
NOTE: Dish Network PVR/Satellite receivers sometimes have two tuners, allowing them to be used in more than one room on different TVs. Harmony remotes can only control a Dish Network receiver's main tuner while still in the same room with direct line of sight to the device.
What other issues are you having with the remote?
Dec 25, 2009 | Logitech Harmony One Advanced Universal...
SNOWY screen--can't find the right channel for Dish Network
Press INPUT button on your TV remote and select right input.
Nov 02, 2009 | Sharp AQUOS LC46LE700 46 in. LCD HDTV
Help me please
Here they are:
Dish Network Satellite receivers:0775, 1005, 1505, 1775
Feb 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
