Question about Schwinn 26in Women's Mirada Bicycle
Installing a water bottle on a bike - Schwinn 26in Women's Mirada Bicycle
    New Friend:
Http://youtu.be/rUgrRTXCC_g
Posted on Oct 11, 2014
How do you attach a water bottle holder. I don't see any indention's for the screws on the frame.
if there are no screw holes in the frame You need to get two clamps that go around the frame and they will hold the holder in place...available at any bike shop.They usually come with the water bottle
Aug 27, 2013 | Mongoose Domain Dual Suspension Mountain...
Where do you to install frame pump?
Thats were they go ,is and unscrew / screw back up .take water bottle cage out ,put the bracket for the pump,in top put your water cage ,put bolts back in , secure it and u should be good.the only reason you shouldn't be able to fit it ,is because is not for a bicycle .
May 01, 2013 | GMC Denali 700C Road Bike
R6 the wiring harness gets warm the ignition wires get warm when you put the lights on the horn and fan doesn't work and when the bike starts to get warm the water is pushed out thru the water botel...
Water coming out means that water is being pressurised from the combustion chamberIf bubbling in the bottle thenRadiator cap not sealingHead gasket blownCracked head or barrelGood luckBike-Doc
Jan 10, 2012 | 2003 Yamaha YZF-R6
Need directions to install the Schwinn water bottle cage
How do I attach a Schwinn water bottle to a Schwinn cruiser bike which has no screws in the frame
Jun 19, 2011 | Schwinn Cycling
How much coolant does the bike hold?i drained the coolant from the water pump
Even the bigger bikes only hold between two and four quarts. If you have one gallon of antifreeze you will have enough to do a complete change. If you buy concentrated antifreeze only use distilled water to dilute it. Tap water will add unwanted minerals that could cause deposits in the motor and radiator. Most motorcycle water pumps use a ceramic washer so they only recommend you use a NON-SILICA formula anti-freeze (any motorcycle manufacturers antifreeze, Gm Dexcool, etc.). 50/50 mix should be right for all riding conditions. If you have enough coolant for the engine but not the over flow bottle reuse some of the old anti freeze in the over flow bottle.
Mar 17, 2011 | kawasaki ZX-6R Ninja Motorcycles
How do you install a drink cage and a basket ?
Installation of water bottle holder is simple. It usually mounts using the two screws on the top of the tube leading to the pedals of the frame. Remove these screws from the frame using a 4mm or 5mm allen wrench, place the holder over these holes, and rescrew in the bolts.
Installation of the basket is dependent on the model and location of the basket. However, all will mount to the frame(in the back) or fork of the bike on bosses.
Mar 15, 2011 | Schwinn 26in Women's Mirada Bicycle
I dont know how to put my water bottel on my magna bike
Many bikes are sold without a water-bottle holder, but have a place to install one. You will likely have to purchase a water bottle holder, and install the water bottle holder yourself.
Most bikes have a spot for one on the Down Tube. (The Down Tube is the part of the frame that runs from the handlebars to the pedals.) Look on the top of the Down Tube, and see if there are two screws. Likely you will need an allen wrench to remove them and install the holder.
Feb 25, 2011 | Schwinn Cycling
Where do i install water bottle?
You should have two cap screws either on your seat tube or down tube or both. Go hit your local bike shop pick up a bottle cage and install it there. If you don't have mounts on your frame your shop can hook you up with a cage that straps on. Good luck.
Oct 05, 2010 | Cycling
Schwinn 26in Women's Mirada Bicycle Logo
Top Schwinn Cycling Experts
Michial Gueffroy
Tony
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
