Question about LG Refrigerators
Freezer frezing up
Hello. i have a refrigerator that the freezer is frezzing. i already check the heaters and the blower and they are working fine . this freezer it is all digital. could be the circuit board
  • 2 more comments
  • jessicapicha Jun 23, 2009
    yes
    yes the compressor keeps on running
    brand LG m# LRSC26923TT S# 606MRRH00686 WHERE IS THAT PART LOCATED
  • Mike Price
    Mike Price May 11, 2010
    Is the compressor running constently?
    President:
  • 744 Answers
This is likly caused by the defrost thermostat, the following web page will give you instructions on testing and replacing the stat. http://www.acmehowto.com/howto/appliance/refrigerator/check/defrosthermo.php
Posted on Jun 23, 2009
  • 1 more comment
  • Mike Price
    Mike Price Jun 23, 2009
    ok this is not the defrost stat...it is the running thermostat. give me the model # and i will give you a link to the part you need...model # located normally inside refridge door.
  • Mike Price
    I am having troble locating the part through my regular channels...will make a few calls tomorrow. Most of the suppliers i use you can buy the part right through web site. will contact you tomorrow.
  • Mike Price
    Good morning, I have contacted my main supplier of parts, they do not supply LG...unfortunatly I was unable to locate this part...I would contact LG for a parts dealer local to where you live and get a cold control...please note that the cold control may be built into the control board which may be why i am unable to locate it, the control board ran for around $250 - $300.
    I hope this helps...If I can be of any further assistance please feel free to comment again.
FRIDGE/FREEZER KEEPS FREZING UP
Did you check or replace the defrost timer? It could be a solid state type built onto a Printed Circuit board or could be a timer motor, it all depends on the model and make of the freezer.
Apr 10, 2008 | Refrigerators
Freezer nor the refrigerator gets cold
The answer to these questions lies in the way the freezer/fridge combo works. The freezer is where the cooling coils are located. Then air is moved over the coils and circulated through the fridge side by a small blower or fan. The problem arises when the air is not circulated for some reason.
The reasons the air is not moving is usually two reasons
The fan or blower has failed.
The coil is covered over with ice and blocks the air flow.
The first reason is pretty simple to fix, you simply replace the air circulator and things are good again.
The second reason can be more difficult.
1. The timing device that runs the defrost cycle of the refrigerator is defective.
2. The heater coil that melts the water is shorted or not working
Usually the first thing to check is the heater coil. If there is resistance through the coil then most likely it is still good.
The timing device can be an advanced defrost control board or a mechanical timing device.
If the heater coil checks out to be good then the problem should be the timer.
For most situations, unplugging the refrigerator and allowing it to defrost on it's own will get you going temporarily, till parts can be shipped to you. That will melt the ice and give you a few days or a couple of weeks till it ices up to the point where it will not work again.
So you can see here, the problem can usually be traced to one of three things.
The fan or blower
The timer device
The electric heater coil
By methodically checking these parts you can isolate your problem and fix it.
Jun 30, 2011 | GE PFCS1NFY (208 cu ft) Bottom Freezer...
Hello. I have a side by side refrigerator MSD25...
The fan or blower
The timer device
Take care....
Jun 24, 2011 | Maytag MSD2542VE Side by Side Refrigerator
Refrigerator is not working! Compressor stopped. Lights still work fine, but the fridge and freezer are not cold! AH!
The fan or blower
The timer device
Hope this will help to fix the fault of the refrigerator....
May 20, 2011 | Kenmore 64802 Top Freezer Refrigerator
Refrigerator not cooling freezer works fine blower motor in rear of unit on but turning slowly
Since the freezer is fine, you are in good shape. Pull off the back cover inside the freezer to inspect the evaporator coils. You should see a light frost pattern. If it is heavily frosted, then you have a open heater element - located at bottom of evaporator. If heater is good and you have heavy frost buildup, replace motherboard and thermistor which is clipped to the top of the evaporator.
Oct 01, 2010 | GE GSS20IEP Side by Side Refrigerator
Freezer works but refrigerator is not cold
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
There are many people that have this problem and are searching for answers as to what to do and what could be causing this problem. It seems to be weird that the freezer is working fine and the fridge side is not. Why would the coldest side be good and the warmer side not?
  1. The fan or blower has failed.
  2. The coil is covered over with ice and blocks the air flow.
For most situations, unplugging the refrigerator and allowing it to defrost on it’s own will get you going temporarily, till parts can be shipped to you. That will melt the ice and give you a few days or a couple of weeks till it ices up to the point where it will not work again.
  2. The timer device
  3. The electric heater coil
Take care.
Jul 18, 2010 | Kenmore 63822 / 63824 Bottom Freezer...
The upper area were is not frezzing is not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sgasgaiyl
Jul 15, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
The items in the rear of the refrigerator are frezing
  1. take all from freezer out
  2. open back wall
  3. check if the fan is damage
  4. check the heater element
  5. check thermostat
  6. one of them is bad
  7. you might need to defrost some of it with hair fan
  8. good luck
Dec 31, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a rooper top frezer refrigerator the refrigerator does not get cold because the ducts that connect to it freeze, I change the timer,check the heater,is good , change the defrost thermostat, but...
it seems to me that you have a clogged drain, that is located in the freezer compartment behind the panel. make sure that is not clogged. that will cause the issue you are having.
Oct 21, 2009 | Roper RT18HDXKQ Top Freezer Refrigerator
Refrigerators Logo
133 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
