Question about Vehicle Parts & Accessories
How to fix sticking shifter button
Shifter button sticks
    Master:
  • 710 Answers
Try cleaning it and using a light oil.
Posted on Sep 07, 2014
On an automatic stick shift the stick shift came apart. What holds the knob on the gear shift rod?
Honda Accord - YouTube
? 5:31
www.youtube.com/watch?v=gRPG8D7Pa-U
Dec 20, 2010 - Uploaded by Auto Parts Direct To You How To Repair / Replace A Broken Or Stuck Shifter Shift HandleButton Knob On 2003-2006 Honda Accord .... How to Fix Your Loose Stick (manual shift stick) - Duration: 6:17. by Fixbook 165,139 views ... How to change a gear shifter light on a 2003honda accord - Duration: 4:04. by Joe Lester 46,291 ...
Sep 24, 2015 | 1998 Honda Civic
How to fix a 2003 Isuzu Rodeo Sticking Shifter
finesse! seriously, I'm the only one who can get my rodeo out of park... try pulling the shifter SLIGHTLY towards you and left BEFORE you push in the button. works everything's for me. good luck!
May 17, 2014 | 2003 Isuzu Rodeo
Shifter stickes in park and shifter button sticks till i hit it
check the selector switch down the side of your gearstick.
Dec 11, 2013 | 2001 Isuzu Rodeo
My Mazda 2000 AUTOMATIC transmission suddenly will shift to a gear but will not engage. You can slide the stick to a different gear without pressing the button on the stick. I was told the shifter actuator...
dude go to a parts store and get a printout for removal- replacement of a shifter linkage..then go to a salvage yard and get a used cable and shifter setup and put it in yourself if possible..its not that hard...
Dec 08, 2013 | Cars & Trucks
2005 XC90 shifter is locked - can only shift between drive an neutral, can't put into park when i come to a complete stop. the key is also locked in the ignition
check the button that you push in on your shifter. will the shift button not go all the way back into the shifter like normal. can you pull it out toward the dash? be easy when doing so to keep from breaking it. something has broken inside the shifter and allows the button to come out too far. try sticking ur finger in the shifter behind the button and realign the button. the button should go all the way into the shifter when it is aligned. it's only a temporary fix but will get you home.
Aug 14, 2010 | 2005 Volvo XC90
SHIFTER STICK!
U need to pull the shift rails out and check them for wear, chances are they are in need of replacement, if u dn't know how to do this have a trans repair shop do it.
May 30, 2009 | 1992 Nissan 300ZX
Transmission?
It may be the shifter lever bushing at the base of the shifter. To check you must remove the stick shift cover. With the stick exposed, push down and turn on the plate that holds the shifter shaft. It is spring loaded and may take some effort. ( Remove stick while in neutral) Pull the stick out of the trans where the stick shift pivots should be a rubber bushing about the size of a half dollar. I think you can only get this part at a Toyota dealer. Hope this helps !
Apr 13, 2009 | 1995 Toyota Corolla
Gear shifter
The shifter cable and linkage may be getting sticky. Locate the linkage and cable on the gear selector (transmission side under hood) and spray them with some PB Blaster or WD 40.
Dec 14, 2008 | 2007 Chevrolet Monte Carlo
2005 grand am shifter problem
The shifter button on the shifter is released when you start up your car and step on the brake pedal. If you are having an intermittent problem, you may be having a shifter release solenoid issue. the shift solenoid is part of the brake light switch system so the problem can also be in the brake switch. If you do not know how to check it out, I would bring it to a reputable repair shop and have them check it out for you.
Oct 12, 2017 | 2005 Pontiac Grand Prix
Vehicle Parts & Accessories Logo
20 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
