Question about Asko T712C Dryer
Sensor Dryer turns off after a few minutes. Filters are clean and water tray empty. We found that the dryer will work when the filter is not out back in place. When the filter is in the dryer will stop
  • 351 Answers
SOURCE: dryer wont turn on
The dryer has an overfill cutout if you start and hold in the start button you should hear the pump come on,and pump the water out. then the dryer will start.if it happens again you may have a blockage in the black drain hose take the top panel off and blow down it,or the pump itself could be faulty.(if the dryer is sitting on the floor you have to drain the water into the drawer, if its mounted ontop of a washing machine you can connect the long bkack hose to the sink.
Posted on Mar 02, 2008
SOURCE: ASKO T780 dryer automatically shuts down after aprox. 20 minutes
Check sensor for fluff. We have asko tumble drier and have had to clear this of fluff many times. Take bottom panel off, as if removing filter to clean. Located on left hand side is a plastic cover, grey, secured by one security head screw. Once screw is out carefully remove circular cover uncliping clips. Inside is a sensor with a plastic cage around it, about size of one pence piece, clean fluff out with toothpick for example. This should do the trick. Good luck.
Posted on Feb 15, 2009
SOURCE: i have an asko dryer
Try taking the lint filter out and gently washing it with a soft scrubber. The screening is very fine and it might look clean to sight but might still need a more thorough cleaning.
Posted on Mar 07, 2009
SOURCE: My asko T760 dryer shuts down after a few minutes.
Remove bottom panel. The condenser unit is on the left side. Open the section by undoing the clips, and look inside the little "cage". That's the sensor. Remove any lint using a toothpick and you should be good to go!
Posted on Jan 10, 2010
  • 351 Answers
SOURCE: Ive rinsed the bottom filter as advised and dryer still shuts off
also wash the door filter,it may need to be serviced
Posted on Jun 17, 2010
Ecologixx 7. Why does it keep switching itself off?
could be the door switch has failed . try leaning on door when starting .
Sep 13, 2015 | Bosch Washing Machines
My dryer stops after a few minutes and all the lights flash. It stops turning and doesnt get warm or hot in that time. I have cleaned all filters and emptied the water. Can anyone help?
I believe it has something to do with the computer circuitry. You might try to reboot it. Unplug your dryer for a few minutes, plug it back in and see if that works. It did for my washer. Good luck.
Feb 07, 2015 | Dryers
Doesn't dry
Drying consists of removing moisture through heat and airflow. Check to make sure that your venting tube is not kinked somewhere and therefore not allowing the air to flow freely from the dryer.
Apr 11, 2014 | AEG T57800 Electric Dryer
I have a Siemens e44-10 dryer. It works for few mins and that stops. The light looks like. Up of water flashes. I cleaned all filters, and the water tank is empty. Can u help me?
I had the same problem above. I tok the side panel off and disconected the float and cleaned it. I noticed alot of water mixed with dust. I used a dry cloth to get the water away and made sure the reservour was clean. I assembled everything and it is all working. Tips, make sure the condense tray is emptied after each Washington aswell as the dust filter. Clean out bottom filter once a month. This saved me having to buy a new machine and tok just half an hour. Phew, money in the pocket!
Aug 03, 2012 | Dryers
My BOSCH dryer #WTE86300US keeps stopping in mid cycle and gives the signal F3 which says to check condensation outlet and I have cleaned all the parts and cleaned hose but it will still beep after a few...
I have owned the same dryer for about a year and just started having this F03 problem. The condensation drain hose is the soft flexible rubber hose coming out of the back of the dryer and it drains into the same drain as a washer. It's easy to pull the hose off its connector at the back of the dryer and just blow hard into it to make sure there's no lint clogging the hose and reconnect it to the dryer. Next open the panel on the left of the dryer and thoroughly rinse (water only, no soap) clean the two parts behind the door (first is plastic and behind that is the condensation filter which probably is loaded with lint). Sometimes the lint in the condensation filter channels (those that run from front to back) can be quite stuck. Use a long pipe cleaner to get in there or a garden hose with a spray nozzle. Shake the excess water out of the condensation filter and dry off the outsides of two parts. Clean all the lint out the compartment where the parts go. There is one more crucial step not mentioned in the manual. Once you remove the condensation filter you will see a small plastic panel on the lower wall of the condensation filter slot. Slide a flat blade screwdriver or a blunt table knife under the panel and gently pop it open. Under the panel is a small chamber that you can't see very well where you will find a slurry of lint/water which is what clogs the condensation outlet. With latex gloves reach in there and clean it out. Use paper towel to get it all out. Blow hard into the dryer through the condensation hose to clear up any last bits. Pop the panel back in place as well as the condensation filter and the plastic part. Take out the lint filter (within the dryer drum compartment) and wash it with soap and water. Use an old toothbrush or something to clean the screens thoroughly. Rinse well and dry it completely. Clean all the lint out of the empty compartment. Put all three parts back into the dryer. Clean all lint off the door. Using paper towel moistened with white vinegar clean the two metal sensors in drum compartment on the front wall and lower left. Run the dryer empty but with heat on for a few minutes to make sure all the water is drained out. Now try drying a load. I think it's a good idea to rinse clean the condensation filter at least once a month since it collects a lot of lint. Hope this works for you.
Sep 22, 2010 | Bosch WTE86300 Electric Dryer
My dryer has a build up of water and give an F03 error. What can do to fix it?
Aug 08, 2010 | Bosch WTE86300 Electric Dryer
Problem with whirlpool condenser dryer,light on to say empty water bottle but after doing all that and cleaning it out it still wont reset. HELP PLEASE!
Empty the bottle and then unplugg the dryer. Plugg the dryer back in and see if the empty light goes off.
Apr 04, 2010 | Dryers
Ariston ventless dryer- "Clean Filter" light won't turn off, so dryer won't start
I had this same problem. The dryer would turn on for a few seconds and I could hear the water pump working followed by the "clean filter" light. This dryer has a float sensor which detects whether the pump is successfully getting rid of the condensed water. The only problem is that lint and other particulates condense out in the water and over time the float sensor gets stuck in the up position. The Ariston call center explained that the float sensor can trip the "Clean Filter" light.
In any case, the float sensor is located in the back of the dryer where the pump outlet tube comes out (when facing the back, it is in the lower right). I had to take apart quite a bit of the dryer to get access to the sensor. I ended up taking the near side off to release the plastic snaps that hold the cover over the sensor.
To fix the sensor, all I had to do was clean out the "bath" that the sensor floats in. And then figure out how to put it all back together.
Oct 06, 2009 | Ariston Technologies ASL75CXSNA 24"...
Asko T712C Dryer Logo
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
