Question about Andis ProPet Clipper Kit in Storage Case with size 10 detachable blade set- Model MBG2
Why won't my ibm thinkpad turn on - Andis ProPet Clipper Kit in Storage Case with size 10 detachable blade set- Model MBG2
IBM Thinkpad T30 2366 won't boot after the IBM Thinkpad screen
you can go to the BIOS setting? if you can,look for "Boot Device Priority" or something like that,it's usually placed on Advanced settings. Set the first boot device as your harddisk,save the settings and restart your computer
Please let me know if it's working or not
Aug 28, 2012 | IBM ThinkPad T30 2366 Notebook
Won't boot in safe mode
Starting an IBM Thinkpad T43 in safe mode allows you to troubleshoot technical issues that you otherwise couldn't. Often when a system has a virus or other type of malicious program, safe mode is the only way to locate and delete the problem. In safe mode, only the computer's essential programs are enabled, and only the files necessary to running the system are in use. Learn how to start an IBM Thinkpad T43 in safe mode using a few fairly easy steps.
1.Close all programs and restart the IBM Thinkpad T43.
2.Press "F8" repeatedly after the IBM logo appears, but before the operating system logo appears. If the "F8" key doesn't work, restart the computer and try pressing the "F11" key repeatedly.
3.Press the "down arrow" key to select "Safe Mode."
4.Press the "Enter" key. The computer will boot up in safe mode.
Sep 16, 2011 | IBM ThinkPad T43 Notebook
Hello, my IBM Thinkpad R51 gives 4 beeps and won't start up. Can you help me?
1.check ram
2. check processer
3.check display connecter&display
please vote me and rate it
Sep 11, 2011 | IBM ThinkPad R51 Notebook
Hello my question? can i operate my IBM r52 thinkpad with out a battery? because the battery will not charge and the thinkpad will not operate with the power cable?
Remove the battery and connect the laptop with the charger and it should operate normally. However, in the absence of battery you won't be able to get backup.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 09, 2011 | IBM ThinkPad R52 Notebook
My ibm thinkpad won't turn on
Try powering on laptop what happens do you hear any beeps or see any lights normally if u see lights this is a sign that it is working if not your motherboard could be bad if you see lights and hear constant short beeps this means your memory can be bad, Try powering on laptop without battery and only power supply plugged in.
Sep 05, 2011 | IBM ThinkPad T30 2366 Notebook
Not able to read dvd's and able to read cd's model lenovo 510i
While I was not able to find that specific model of laptop, I was able to locate the CDRW Bay and based on my research this bay only supports the following models. Though it may look the same and even have the same interface, if it is not in the supported model list, it will not properly function.
Supported Media Types:
  • CD-ROM
  • CD-R
  • CD-RW
  • DVD-ROM
Compatible with:
  • IBM Lenovo ThinkPad R50
  • IBM Lenovo ThinkPad R50e
  • IBM Lenovo ThinkPad R50p
  • IBM Lenovo ThinkPad R51
  • IBM Lenovo ThinkPad R51e
  • IBM Lenovo ThinkPad R52
  • IBM Lenovo ThinkPad T40
  • IBM Lenovo ThinkPad T40p
  • IBM Lenovo ThinkPad T41
  • IBM Lenovo ThinkPad T41p
  • IBM Lenovo ThinkPad T42
  • IBM Lenovo ThinkPad T42p
  • IBM Lenovo ThinkPad T43
  • IBM Lenovo ThinkPad T43p
  • IBM Lenovo ThinkPad T60
  • IBM Lenovo ThinkPad T60p
  • IBM Lenovo ThinkPad X40 series (X series media slice or Ultrabase required)
  • IBM Lenovo ThinkPad X41 series (X series media slice or Ultrabase required)
  • IBM Lenovo ThinkPad T30, X30, X31, R40 series (2366, 2367, 2884, 2885, 2681, 2682, 2683, 2896, 2722, 2723, 2724, 2897, 2672, 2673 - when installed with the optional ThinkPad Slim Drive adapter for the UltraBay 2000 or X series UltraBase or Media Slice)
If you see your model in this list comment back and we can move forward with getting your issue resolved.
Good Luck,
NOLA Tech
Jan 29, 2010 | Lenovo (13N6769) CD-RW/DVD-ROM Combo Drive
How do I turn on the wireless on an IBM ThinkPad 2628 A20m Thanks in advance
To turn on the wireless on IBM Think Pad 2628 A20m you can try the below options
IBM
IBM General - Some models have the wireless slide button on the side of the laptop.
IBM DV series - use the antenna-like button found on the upper section of your keyboard.
IBM R40 - Use the Fn+F5 key-combo.
IBM Thinkpad (General) - Most have software switch or button on Left hand side.
IBM Thinkpad (model not further identified) wireless switch on Front edge of case.
IBM T43/X32 - Fn+F5 -Click "Turn On"
IBM ZD series use the antenna-like button just below the “Lock” key.
Let me know fi this will help
Dec 04, 2009 | IBM ThinkPad A21m 2628 Notebook
Andis ProPet Clipper Kit in Storage Case with size 10 detachable blade set- Model MBG2 Logo
62 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
