Question about Health-O-Meter Health O Meter Weight Tracking Scale
What to do when the scale keeps beeping when stepped on?
I keep getting Err after replacing battery
my scale keeps reading err when I step on it
Jun 01, 2014 | Homedics Digital Scale
When you get onto the scale (Taylor Lithium 7506), the numbers just keep cycling and never stop. We tried changing the battery, even though the scale is less than three months old, but it still does the...
Turn it over - take out battery and check with multimeter to ensure it is still workable - let sit for 10 to 15 seconds - replace battery - set it on level surface and step on and back off. Step on it again and it should now work.
Sep 16, 2011 | Taylor 7506 Precision Tech Lithium Battery...
Scale keeps showing lo no weight
Try taking the battery out and putting it back in, also there should be a small reset button. You will need a toothpick to push the reset button. Allow time for the scale to reset before stepping on it.
Apr 19, 2011 | Homedics Digital Scale
Keeps showing err. Thinner scale
Tap the scale twice with your foot so 0.0 appears first, then weigh yourself. If you step on the scale before 0.0 appears, the scale will not function properly.
Sep 26, 2010 | Conair Thinner Scale by TH304 Glass Body...
I HAVE A SET OF EKS ELECTRONIC BATHROOM SCALES AND ON REPLACING THE BATTERY I AM GETTING A READING OF ERR 5 WHICH I PRESUME IS AN ERROR CODE. CAN ANYONE HELP PLEASE?
When you see the err message step off the scale and wait 5-10 secs then step back on and it should be ok. Remember that when standing on it you must keep absolutely STILL.
Good Luck
Aug 14, 2010 | Health & Beauty
My scale keeps rotating from one set weight to another and never stops?
mcdevito75 here, You can try to replace the battery, and try this, remove the battery-ies, step on and off the scale then re-install battery-ies and see.If nothing works, contact scale manufacturer.
Jun 28, 2010 | Homedics Glass Digital Scale - Advanced...
How do i program the taylor body fat scale
From the Taylor web site
http://www.taylorusa.com/faq-scales
The easiest way to program the scales is to pull the manual up for the scale and follow the directions. The procedure does vary according to the scale.
In general the procedure is to tap the power or set button until it brings up the height and then hit the arrow keys until you get to the correct height. Hit the power or set after each entry usually height, age, gender, athlete mode. It will then beep and you will need to hit the arrow up until you see 1 (this is the memory number) tap the set or power and it will beep again. The scale is now programmed.
The general recall procedure is to hold the power or set button down for 2 seconds (or tap the up arrow) until the memory number goes up. Then just tap the power or set and it will beep. Then step on the scale to get the information. The weight will be first, then running zeroes, then thefat%, and finally water%.
Jan 15, 2010 | Taylor 5599 440 Pound Tempered Glass Body...
My scale keeps giving me an err2 message. How do
1. Take out the battery
2. Put scale on hard surface
3. Stand on scale for five seconds
4. Put battery back in
5. Tap your foot on scale to make 00000 appear
6. When the 00000 disappear tap your foot on scale again and then stand on scale till your weight appears
If this does not work the first time (it has always worked the first time with my scale) the repeat the steps a second time. If the second time does not work call the company because something else is wrong.
Dec 16, 2009 | Taylor Body Fat Analyzer & Scale, Model...
I need a users manual for my Um-016
Tanita UM Series Body Fat / Hydration Monitor InstructionsTanita UM Series Body Fat Monitor/Scale Instruction Manual
How to Determine Body Fat Percentage
Setting & Storing Data in the Memory
1. Turn the power on using the set button.
2. Select a Personal data number using the Up/Down arrow buttons, then press set.
3. Select your Age using the Up/Down arrow buttons to scroll through numbers, then press set.
4. Select Male or Female using the Up/Down arrow buttons, then press set.
5. Specify the Height using the Up/Down arrow buttons, then press set.
The unit will beep twice and the display will flash all data (Male/Female, Age, Height) to confirm the programming. The power will shut automatically, or you can tap the weight only button (in front of monitor) for quick shut off.
How to select Personal Data Number
1. Press the Up memory button to turn on.
2. Use the Up/Down arrow buttons to select your personal data number, then press set.
3. The unit will beep and the display will show the programmed data.
4. The unit will beep again and the display will show '0.0' and then step on the platform.
5. Your weight will show first, then "00000" will appear and then your Body Fat Percentage will appear on the display.
Programming the Guest Mode
1. Press the Down Guest button to turn on
2. Follow the same steps for programming as outlined above.
3. The unit will beep twice and show '0.0', then Step onto the platform.
Taking Weight Measurement only
1. Select weight only mode, by toe-tapping the weight only button located at the base of the scale.
2. Wait for the scale to display ‘0.0', then step on.
Replacing the batteries
1. When the "Lo" error message appears on the screen, the batteries need to be replaced.
Understanding Your Readings
Healthy Range Indicator
(Please note this function is only applicable on adult mode, as no standard healthy ranges have been established for children and athletes.)
Your body fat monitor/scale instantly compares your body fat reading to the healthy range chart. Following your body fat reading, a black bar will flash across the bottom of the display, identifying where you fall within the body fat ranges for your age and gender.
(-): Underfat; below the healthy range. Increased risk for health problems
(O): Healthy; within the healthy body fat percentage range for your age/gender
(+): Overfat; above the healthy range. Increased risk for health problems
(++): Obese; high above the healthy body fat range. Greatly increased risk of obesity related problems.
Oct 18, 2009 | Tanita 2204 Body Fat Scale
Health-O-Meter Health O Meter Weight Tracking Scale Logo
26 people viewed this question
Top Health-O-Meter Health & Beauty Experts
Shehu Pro
Shehu Pro
Red721
Level 1 Expert
richie46
Are you a Health-O-Meter Health and Beauty Expert? Answer questions, earn points and help others
