Question about Health-O-Meter Health O Meter Weight Tracking Scale
Scale keeps beeping - Health-O-Meter Health O Meter Weight Tracking Scale
Avery Berkel 1770 shop scale is continually beeping
Any time you let something set you should check the battery backup it might be low power beep telling you it is bad.
Jan 29, 2013 | Office Equipment & Supplies
Starts up beeps put somehing on it and it dosn't weigh
The pressure sensor under the platform is probably corroded or broken...it may not be economic to replace it...buy a new scale.
Jan 13, 2013 | Royal Postal Scale Gray
Scale keeps showing lo no weight
Try taking the battery out and putting it back in, also there should be a small reset button. You will need a toothpick to push the reset button. Allow time for the scale to reset before stepping on it.
Apr 19, 2011 | Homedics Digital Scale
Keeps showing err. Thinner scale
Tap the scale twice with your foot so 0.0 appears first, then weigh yourself. If you step on the scale before 0.0 appears, the scale will not function properly.
Sep 26, 2010 | Conair Thinner Scale by TH304 Glass Body...
How do i program the taylor body fat scale
From the Taylor web site
http://www.taylorusa.com/faq-scales
The easiest way to program the scales is to pull the manual up for the scale and follow the directions. The procedure does vary according to the scale.
In general the procedure is to tap the power or set button until it brings up the height and then hit the arrow keys until you get to the correct height. Hit the power or set after each entry usually height, age, gender, athlete mode. It will then beep and you will need to hit the arrow up until you see 1 (this is the memory number) tap the set or power and it will beep again. The scale is now programmed.
The general recall procedure is to hold the power or set button down for 2 seconds (or tap the up arrow) until the memory number goes up. Then just tap the power or set and it will beep. Then step on the scale to get the information. The weight will be first, then running zeroes, then thefat%, and finally water%.
Jan 15, 2010 | Taylor 5599 440 Pound Tempered Glass Body...
My scale keeps giving me an err2 message. How do
1. Take out the battery
2. Put scale on hard surface
3. Stand on scale for five seconds
4. Put battery back in
5. Tap your foot on scale to make 00000 appear
6. When the 00000 disappear tap your foot on scale again and then stand on scale till your weight appears
If this does not work the first time (it has always worked the first time with my scale) the repeat the steps a second time. If the second time does not work call the company because something else is wrong.
Dec 16, 2009 | Taylor Body Fat Analyzer & Scale, Model...
MY bfm588dq-81 scale is malfunctioning. The
Throw it away. The product sucks. I know, I'm throwing one away right now and I"ll NEVER purchase one again.
Aug 17, 2009 | Health-O-Meter Health o Meter BFM588DQ-81...
The sound gets on my nerves
This link provides a troubleshooting/FAQ directly from the company...I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
Jan 03, 2009 | Taylor Dgtl Body Fat Scale
Health-O-Meter Health O Meter Weight Tracking Scale Logo
Top Health-O-Meter Health & Beauty Experts
creative_lac
Level 1 Expert
Shehu Pro
Shehu Pro
Red721
Level 1 Expert
Are you a Health-O-Meter Health and Beauty Expert? Answer questions, earn points and help others
