Question about John Deere 50v 39001-up 55v 60v 16001-up 80ev Chain Saw Operator Manual J9
What year was my john deere 55V chainsaw manufactured?
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: i need to know how
Hi wagersmark...
It could be more of a problem than just the idle screws, they stop idling properly for a reason, most of the time that reason is trash/water in the carburetor.
Here are a few things to check and some hints.
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting a nice blue spark then:
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indetion in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Posted on Aug 28, 2011
I need to find out the year model of a 9600 and 9650 combine. Which number of the VIN indicates the year model. I need this information for insurance purposes. HO9600X645553 HO9650W695460
For automotive applications, the tenth digit is the code for year of manufacture, but automotive VINs are 17 characters in length. At the link, it states that 13 character VINs for John Deere are not coded for year of manufacture. You may have to check with your John Deere dealer for help.
How to Read John Deere VIN
Jul 19, 2017 | Cars & Trucks
What is the oil filter part number for Generator engine serial number CD4045C037188?
your number 4045tf258 should be a industrial generator that number is the model number
John Deere 85 KVA 4045TF258 for sale Price 7 359 Year 2005 Used John Deere... notify john deere and use the model and serial number [i have 2 different numbers and are as follows RE506178 Oil Filter 1 RE5 9754;the first should be the new number and the other was the old ] just to make sure of the correct parts number for your unit
Aug 19, 2016 | John Deere 225 325 375 500 650 Alternator...
Torque for tightening flywheel
Generally 50nm is sufficient. Clutches tend to be a clockwise thread to remove them so the tend not to unwind when running.
Apr 15, 2016 | John Deere Cs36,cs40 Chainsaw Owners...
Saw wont idle, runs wide open
Some saws have a throttle lock that locks the trigger to aid starting. Get a look at the carb to see if it opens when the trigger is pressed and closes when the trigger is released. If it stays open the lock may not be releasing or the throttle linkage is bound up or disconnected from the carb.
Dec 13, 2013 | John Deere 28 30 40v 50v 55v 60v 70v 80ev...
Need gas cap for john deere 40v chainsaw
Take your saw to a lawn and garden shop that repairs chain saws. They should be able to help.
Aug 07, 2013 | John Deere 28 30 40v 50v 55v 60v 70v 80ev...
What year is this tractor? L02355G631940 John deere
The first 2355 was sold in 1987.
They were manufactured from 1987 to 1992. With a BHP of 55.4 Hp
The serial number you gave ...is that an ESN or TSN?
You can contact John Deere here and ask them the date yours was made.
https://secured.deere.com/en_US/ag/httpscontent/contactus/index.html
Mar 01, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 50v 39001-up 55v 60v 16001-up 80ev Chain Saw Operator Manual J9 Logo
18 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
