Question about whipper snipper stihl fs 38
Clean fs38 carb
Cleaning carbuerretta
How to Clean an Outboard Carburetor?
didnt specify unit --generic answer --best way is to buy a rebuild kit [should have instructions]--carb cleaner --disconnect carb --and tear down the carb becareful their are small parts inside using cleaner cleal all parts and housing --in the rebuild kit should be instructions on putting it back together
15 minute Carburetor Cleaning Rebuild Yamaha 20HP outboard 4 stroke How to Clean an Outboard Carburetor Outboard Motor Carburetor Cleaning
Oct 20, 2016 | Boating
My stihl fs400 strimmer starts first time and runs on full throttle then dies a few moments later starts first time and does ame thing again
inside the muffler there is a screen that gets all gummed up, take muffler assy. apart and clean screen, if you have a propane torch, this works well as you burn crud off it becomes ash and wipes or blows off. first link shows how.
press the helpful button and follow me on fixya
Easy Repair on STIHL FS38 Grass Trimmer Clogged Spark Arrester
how to fix stihl trimmer
STIHL GAS TRIMMER REPAIR Stihl FS 40 Grass Trimmer RAN NO OIL IN GAS blown...
How to fix bogging out grass trimmer with clogged spark arrester
Feb 03, 2016 | Stihl Garden
Run good at idle but pop and spits at full run
make sure the gap in the spark plug is correct and clean.make sure carb is clean and has proper suction aka loose carb hoses bolts exc.ohhh and if you take the carb off definitely check the reeds while your at it
Dec 08, 2012 | RTO 200cc Full Size Four Wheeler ATV
I have a keeway hacker 125cc how do i clean the fuel filter
try cleaning dirt from carb. spray carb cleaner to intake. or remove bowl and clean. pull jets and clean.
Sep 21, 2012 | 2010 Keeway Hacker 125
After cleaning my carbs.. just the bowls and carb
Well, a couple things may be wrong.
1) debris could be lodged under the needle valve. Remove the float by gently slideing the float pin out, the needle will either slide out with the float or remain in the seat and a pair of needle nose pliers will help to retreave it. clean the seat and inspect the needle valve for damage.
*note that even the smalles debris can keep the needle from seating so take care during reassembly*
2)depending on the type of carb cleaner used, and the exact type of needle valve in your carbs, the needle valves may have been dammaged during the cleaning. Some carb cleaners can "eat" neoprene or rubber components in carbs. It is always best to fully disassemble them before cleaning, if you are not confident in your ability, have a pro do it for you.
The solution for this is to remove the needle valve as above, and inspect the needle and float for damage. **If in doubt replace the needle valve**
Good luck.
Mar 25, 2010 | Honda Gl 1500C Flat six Motorcycles
Need to replace line on FS38 Line Trimmer. No instuction manual. It must be an easy procedure. What diameter line and how is it done?
I googled your fs38. It is a Stihl FS38. The first sight on the search comes up with an 82 page operating manual from stihl.ca
This should help.
Good Day.
Oct 25, 2009 | Garden
THE THROTTLE CONTROL SPRING CAME OFF THE CARB ON MY FS38 stihl trimmer. Which hole does it go back into? Thanks.
Look to see which one has a worn spot . That is the one I would use. If it isnt that one, try the other. Good luck...Lee
Sep 22, 2009 | Garden
It acts like it is flooded, starts with choke off and throttle depressed. runs until carb runs out of gas then dies
Yes, Your carburetor sounds like it needs cleaned. Or you may possibly need to purchase a carb. kit for your trimmer if the cleaning doesn't do any good. When cleaning the carb. use a Den Tek Brush, (teeth cleaning brush), to clean the small ports. Also, check the small screen in carb. Can get clogged easily.
Jim
May 28, 2009 | Garden
Cleaning Carb Jets
You shouldn't have to adjust anything as long as you don't increase the jet size and put everything back the same way it is removed.
May 09, 2009 | 2000 Yamaha YZF-R6
Carburator cleaning
The First thing you have to NOT DO, is try to start it if it has been sitting for any long duration of time, 6 months or more, second, you have to remove the gas tank, drain the contents, into a can you can see in, look for a dark brown colored corpusal, in the gas, if there is some, that is an indication, that your carbs need to come apart, unless you are a seasoned mechanic, you will have to remove the carb, take the bowl off, of course you will look for the brown couloured substance again, clean the bowl,remove the pin, holding the float in placebeing carfule to secure the needle valve in its proper place after cleaning it thouroughly, remove the jet, using a tiny bit, you reem the jet hole center, taking care not to bore it out, the you run the bit in the jet hole, cleaning any debri that may be there, use carb cleaner and keep spraying it in all in puts and out puts the carb may have, then if you put your mouth to the feul input to the carb, blow in it to be sure it is clear, if not youl have to use carb cleaner and air to clean it out, air and carb cleaner is the key to cleaning it properly, some carbs need to be taken apart and soaked in a carb cleaner, before reassembly, just keep blowing air in all the inputs and out puts, to be sure they are cleared, reassemble and GO
Nov 10, 2008 | 2001 VOR SM 500
Garden Logo
Top whipper snipper Garden Experts
richie46
ray gallant
Bill Boyd
Are you a whipper snipper Garden Expert? Answer questions, earn points and help others
