Question about Garmin eTrex Vista Cx GPS Receiver
Screen Blanks Garmin GPS 72After 30 minutes using a 12v adapter The screen blanks. A single vertical black line remains. It will not restart until the batteries are re-installed.Garmin sent me a new 12V adapter. It did not fix the problem. At random times the screen on my Garmin eTrex Vista GPS will go blank with just a thin black line usually on the left side but it was on the right side once. I get a little tired of taking the battery out and reinstalling it to make it work again for a minute or half hour. Any ideas
  • silvertree Jul 01, 2008
    This is the same problem I am having with my GPS 72. Removing the batteries will start it again, but the problem happens all over again.
  • Anonymous Mar 13, 2014
    the device keeps going blank with a thin black line between the screen
I had the same problem with an etrex Vista. I spoke with Garmin, they said that a recently launched WAAS satellite is interferring with some models (he mentioned it is the models with a black and white screen). Garmin tech support said that they're working on a software patch but for the meantime switch WAAS off.
Call Garmin tech support with any questions or to find out about the software patch, 1-800-800-1020
Posted on Nov 08, 2007
The screen displays a vertical group of black and grey lines. Won't shut down?
it seems like its in calibration mode
Turn unit off
Slide Power Key to the right ( lock )
Hold your finger on the screen for approx 30 seconds until calibration screen appears
Follow on screen instruction''
Here is a online Manual for your unit that I found ....
Oct 28, 2010 | Garmin Nuvi 285WT GPS Receiver
My garmin etrex legend screen goes blank with a vertical line on the screen after about 5 minutes od operation
Unfortunately the only fix for this is to send it back to Garmin for repair. This one can go one of two ways. Either the screen is faulty in which case it's a quick fix and you go away happy, or it's a software fault.. In which case I'd ask for a new one because in my experience most software faults with Garmin devices become recurring problems even though they clear and reprogramme them invariably we see them coming back with more software issues..
Oct 06, 2009 | Garmin eTrex GPS Receiver
Screen goes blank after locating sattilites.
Accordingto Garmin, this problem can be fixed by disabling the WAAS feature in teh set up menu. There is an incompatibility between the old Garmin software and latest WAAS upgrades. Later software from Garmin is supposed to fix this problem.
May 21, 2009 | Garmin eTrex Legend GPS Receiver
Just quits
I had the same problem (blank screen, vertical line). Per Garmin, turn off the WAAS function. Disable it for now, because the government has changed the WAAS signal coming from the satillite, and Garmin has not yet come out with a remedy to correct this problem yet. It should be out in a software update sometime in the future...............I did this and it corrected my problem immediately. The unit performs perfectly now, however, the accuracy is not as good, due to the lack of WAAS.......................
Dec 04, 2008 | Garmin MAP76 handheldS GPS Receiver
Blank Screen on Garmin E-Trex Vista
The problem is that your software version needs updating. A recently added satellite creates a glitch in the older software. Go to the Garmin website, load WebUpdater if you haven't already done so, and the updated version (3.8) will automatically install to your Garmin unit. I had the same symptoms, they have now disappeared and my Etrex Vista is back to normal.
Oct 14, 2008 | Garmin GPSMAP 76CS GPS Receiver
RINO 120 :: screen blanks out with just a single horizontal line
Had to wait 24 hours to be able to post my own answer
By reading a number of forums, I've found that there was a WAAS satelitte update (bug), that causes this foul up.
The only solution I've been able to arrive at is DISABLE the WAAS feature, as no Garmin Update/patch (for Rino120) has been made available.
To shutoff the WAAS feature press your [Page] button until you arrive at the "Main Menu"
go down until your on the "Setup"(hammer)
go in (by pressing in, on the directional button)
go down until your on the "System"(gears)
go down until your on WAAS, go in and select the Disabled
go up to the "X" (top right) press it, then you can [Page] button anywhere you want from there.
Wonder what WAAS is?
Take care.
PS- Garmin if you read this....I would like to have my WAAS back, and since I registered for updates, back in 2005, why didn't I get an email from you telling me about this issue (when it happened and provide a solution - at the same time :: even a work around as I've posted here)
Oct 02, 2008 | Garmin Rino 120 2-Way Radio
Garmin gpsmap 162 turns on, works for about two minutes, then a thin black vertical line comes across screen and screen goes blank with the line remaining. I have to unplug and start over. Same things...
Possible Solution found on google....
My old Garmin 162 chartplotter was mounted on the binnacle guard and served me
well for many years. Lately, it started getting very slow to refresh screens.
At times, it would shut down with only a black vertical line on the screen. On
our last cruise, the screen froze at a very critical moment. Too old to
repair, I bought a new Garmin 440, which I am very disappointed with, but
that's another story.
I read an article in the GoodOldBoat newsletter about the Department of Defense
making changes to the WAAS satellites that have caused problems in Garmin 72
and 76. Garmin's tech support recommended to turn the WAAS function off on
affected units. So I got out my old 162 and turned the WAAS off and it works
fine. To make sure it wasn't a fluke, I turned it off and on several times,
and it always slowed down with WAAS turned on. With it turned off, the
position error or accuracy, increases 1-2ft, not a big deal. I hooked the unit
up on my truck and drove around. Not a problem. Further reading indicates
that other brands of GPS are also having problems with the new WAAS
So if you are having problems with your GPS and it is new enough to have WAAS,
try to turn it off
Sep 28, 2008 | Garmin GPS
Unit shut down
I have run into the same problem and it may be related to the WAAS (Wide Area Augmentation System) feature. Try disabling this feature (under MAIN MENU / Setup). I used this receiver overseas (Asia and Europe) last year for 35 days straight with no problems. During this time WAAS was disabled as none of these satellites are visible overseas. The problem occurred intermittently prior to the overseas trip, and has reoccurred after returning. I was running into the same problem this past weekend and noticed the screen blanking out (with the vertical line) shortly after differential corrections were applied to the GPS signals. I disabled the WAAS and let the receiver run for over an hour. The problem did not return. Hope this helps.
Sep 25, 2008 | Garmin GPSMAP 76 GPS Receiver
Garmin Etrex display problem
Have you updated your Garmin unit software recently?
Mar 21, 2008 | Garmin eTrex GPS Receiver
Screen Blanks
Contacted Garmin Tech Support and they verified the problem with the WAAS. They said the engineers were looking at the problem. Estimated the fix would be ready in 2 to 3 months. I turned the unit on inside where the unit could not receive any satellites then disabled the WAAS and the unit works without problems. It is just not as accurate.
Oct 19, 2007 | Garmin GPS 72 GPS Receiver
Garmin eTrex Vista Cx GPS Receiver Logo
502 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
