Question about Toro Garden
How to tighten cutting belt on a toro wheel horse 8-25?
  • 8404 Answers
SOURCE: NEED MANUAL FOR TORO WHEEL HORSE GARDEN TRACTOR 416-8
As far as I understand, fixya.com does not stock or sell this mataerial. The purpose of this site is to get direction on a course of action to follow ...
Here is my suggestion ... if you have looked in the manuals section of fixya.com and not found what you are looking for, visit the manufacturers web site which is probably www.toro.com/wheelhorse or something very similar ... Google it to find it ... or you could search www.archive.org
Thanks for using fixya.com
If this helps you, positive comments are appreciated
a
Posted on Oct 26, 2009
  • 391 Answers
SOURCE: I HAVE A TORO WHEEL HORSE MODEL 71223, I PUT A NEW DRIVE BELT ON
The belt or linkage is mal-adjusted or the belt is sticky and will not slip when the clutch pedal is depressed
Posted on Jul 19, 2010
suzukiracing
  • 200 Answers
SOURCE: I HAVA A TORO WHEEL HORSE MODEL 71223, I PUT A NEW
The problem sounds like the tranny if the belt is correct.Thanks for asking and I hope it helps.
Posted on Jul 21, 2010
daneinwv
  • 124 Answers
SOURCE: I'm interested in a snow
My name is Dane and I am going to assist you in solving your problem.
I looked up the information on this snow cab and I found out that it is a universal unit that should fit on any MTD mower 1997 or newer. It should be fine. I would, however, buy this from somewhere like a local mower supply shop or hardware store so that you have the ability to return it just in case.
Well, I hope I've helped. If you found this useful, please leave me some THUMBS UP if you think I'm deserving! :-) Thank you! Dane
Posted on Dec 06, 2010
Testimonial: "Well, I've looked all over the internet and nobody that sells these will say that they do or don't fit. I thought the same thing, that it should fit. "
  • 264 Answers
SOURCE: WHAT CONFIGURATION DOES BELT GO
You can go here and get a manual. Theres a $2 charge but it's worth it and will certainly help you.
Posted on Jan 15, 2011
My toro wheel horse cuts off after mowing for a little while
Ensure oil is full. 30w. All mowers have a low oil cutoff.
Oct 09, 2012 | Toro Lawnmower Lawn Mower High Wheel...
Need a manual for Wheel Horse 520-HC!
https://lookup3.toro.com/request/request.cfm Go to this website and put in model number and you can download a manual and parts book.
May 31, 2012 | Garden
Toro wheel horse rider recycler 8hp-25inch cut model#56132 how to remove mower deck
Jump onto www.toro.com and download the free service manual for your machine. Note down all the details on the ID plate on the mower, you will need it to find the correct manual.
Apr 30, 2011 | Toro Garden
My toro 212-5 mower keeps spitting off the deck belt
You may need a new one. If that doesn't work you may have a bent pulley that's cause it to jump off or the barrings in one of your pulleys may be bad which would cause the pulley to wobble therefore throwing the belt off.
Jan 31, 2011 | Toro Wheel Horse Drive Belt For Tiller...
WHAT CONFIGURATION DOES BELT GO BACK ON TORO RIDE ON. TORO WHEEL HORSE 15-44 HXL
Jan 15, 2011 | Toro 3 Blade Set For Wheel Horse 42" Deck...
Repace large belt on toro riding mowermodel14ap80rp744
Not sure what the problem or question is. How to replace the large belt?
Aug 19, 2010 | Toro 3 Standard Blades For Wheel Horse 50"...
Jul 18, 2010 | Toro Garden
I have Toro Wheel Horse riding lawnmower model # 70040 - 790000
need the ser number of the unit. the pulley don't split its one part, i need the ser number . this is no easy job. good luck
Oct 13, 2009 | Toro Lawn Mower With Toro Power Tools
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
54 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
