Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
What is belt size for for craftsman LT2000 46 inch deck
  • 5 Answers
SOURCE: i need belt diagram for 42 in deck
You can go to the Sears website an download a free owners manual that shows what you need.
Posted on Apr 25, 2009
  • 57 Answers
SOURCE: craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
Posted on May 18, 2009
  • 376 Answers
SOURCE: LTX 1000 CRAFTSMAN /42 IN. DECK BELT LODGED ABOVE
Without the model number, I couldn't tell you what belt goes on the ground drive. That 174883 is a 5/8 x 97" and is your deck drive belt. Your ground drive belt may just need replacing. They will wear thin and loosen up between the pulleys and cause the problems you're having. The old belt may still have the numbers on it.
Posted on Jul 04, 2009
  • 133 Answers
SOURCE: need a diagram for a sears craftsman 42 inch deck drive belt and
I don't have a deck diagram but you should be able to figure it out it you put the back part of the belt (flat) up against the pulleys that are wide and the narrow part (v) into the smaller pulleys. It might take a couple of times but it is not that hard to figure out. Also put the (flat) side of the belt on any tension idlers. Hope this works.
Posted on Jul 29, 2009
mowerman1857
  • 389 Answers
SOURCE: I need a belt diagram for Craftsman LT 2000 42
Look under the "running boards" Sears(AYP) sometimes put them under there. If not, go to www3.sears.com, type in your 917.xxxxxx model number and the pictures will show you an exploded view of the belt configurations
Posted on Sep 14, 2009
I have a 27 hp Craftsman mower with Kohler motor and 48 inch deck. What is the drive belt replacement size?
try here
http://www.searspartsdirect.com/partsdirect/brands/Craftsman-Parts?gclid=CMO2sJSHzdQCFVQ1aQodpmIKJg
Jun 20, 2017 | Craftsman Garden
PRIMARY BELT SIZE
I WOULD SUGGEST HIGHLY YOU GET REPLACEMENT BELTS FROM SEARS . THE AUTOMOTIVE BELTS ARE IN ONE INCH INCROMENTS SEARS BELTS ARE IN HALF INCH .. GET YOUR MODEL NUMBER AND CONTACT YOUR LOCAL SEARS OR K MART . FOR THE PROPER BELT ! .. JUST THE WAY IT IS WITH CRAFTSMAN MOWERS ... SORRY ....
Oct 21, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
Need belt for craftsman 42 inch deck size, what size is it
You will probably need more info.
The belt is listed in your manual, if you have one.
If you can bring the belt in, a good auto parts store will have it in stock.
If you have the model no. we may be able to find the size for you on the internet.
Gary
Aug 21, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Need to fine out if it would what other size of belt you can use on 38 inch cut on poulan riding lawn mower
Are you asking what size belt to use or are you asking what other size belt, like you want to use one a little smaller or a little larger? If that is the case, what difficulty are you having that you would need to do that? Did you put a Craftsman deck on a Poulan or something odd like that?
Aug 06, 2011 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
What size deck belt does a model#917273640 craftsman take
Measures 21/32 inch x 97-2/5 inches. item number 174883 from sears
Jul 19, 2011 | Craftsman Garden
I need to know what size blade belt I need for my craftsman lt2000 42 inch mowing deck... the model number is 917273130
it's a 95.5" belt... you can cross reference most belt part numbers on the Dayco website
Sep 27, 2010 | Craftsman Garden
42" craftsman mower deck belt 144200 to tight on the deck
Manual lists the incorrect number for this model! i learned through many difficulties. Correct belt is a # 144959, 1/2 " by 95"
Aug 09, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
LTX 1000 CRAFTSMAN /42 IN. DECK BELT LODGED ABOVE PULLEY AND STOPPED MOWER AND BROKE BELT. IS THE BELT SIZE 96 OR 97 INCH? THE BELT HAS DONE IT TWICE/STCK BETWEEN THE PULLEY AND THE THING ABOVE IT.
Jul 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
344 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
