Question about Pentax X70 Digital Camera
Why memory card error comes on screen of my pentax x70 even with new sd card
Memory card error shows on screen even when I put a new SD card in the camera
SOURCE: Largest capacity SD card for Pentax Optio S5N
The maximum supported size is most likely 2GB SD Card. Cards with 4GB and more are following a new (incompatible) standard called SDHC (SD High Capacity), SDHC cards work only in devices specifically supporting SDHC. The Optio S5N uses the old SD standard where 2GB are the maximum size.
Posted on Aug 13, 2008
mail541
  • 58 Answers
SOURCE: my pentax k100d has a memory card error
Trun the camera off and remove the batteries. Leave it for at least a minute before inserting the batteries. Put the car in and turn the camera on.
The firmware in these cameras can get confused. Removing the batteries for a minuite or two will allow the camera circuits to discharge and so it will reset from start when powered-up again.
If this does not work then the camera may need to be sent away for repair. This need not be expensive it could be as simple as re-programming the camera. (Their program memory is writeable and so it can be accidentally altered under certian circunstsances. It may be possible to do this yourself using the downloadable firmware upgrade, but I would let someone else try thet first!)
However, it is just possible that the new card is also faulty!
Check the cards in your PC by obtaining a SD card reader to allow you to plug it directly into your PC.
For reference I would always recommend inserting and removing memory cards with the camera turned off. I would also use the SD card reader to load the images into the PC. Unplugging devices form the USB port can be harmful to some devices. Check the bottom right of your PC screen for an 'safe unplug' icon when things are plugged in.
Posted on Jan 21, 2009
robmcd27
  • 423 Answers
SOURCE: SD memory prohibits functioning of Pentax E30
I know that usually, you should format the card for the camera that your going to use. Try formating it in the camera and see if that works. Let me know if I can do anything else for you,
Rob
Posted on Feb 22, 2009
pontelemon
  • 531 Answers
SOURCE: new sd memory card doesn't work in my digital camera
It will not work with any "sdhc"
Posted on Mar 19, 2009
  • 65 Answers
SOURCE: Camera won't read new SD card
The sd card is to big go for a 2gb ted10
Posted on Apr 20, 2009
Joecamera showing locked card will not format delete or take picture
Take the memory card out of the camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Feb 13, 2011 | Pentax X70 Digital Camera
Apr 18, 2009 | Pentax Optio 550 Digital Camera
Rob
Feb 22, 2009 | Pentax Optio E30 Digital Camera
SONY DCS T1 FORMAT ERROR C:13:01
Hi.. I think you have solved the problem yourself... replace the adapter with a memory stick... You have eliminated the micro sd card as bad... now try a new known good memory stick..
Thanks
jim
Feb 18, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
My pentax k100d has a memory card error
Oct 01, 2008 | Pentax K100D Digital Camera
Memory card
Hi and welcome to FixYa.
Your camera will not work with an SDHC card. It must be an SD card.
Don't forget to format the card in the camera after you install it. Elsewise it won't work properly.
Thanks for coming to FixYa, and feel free to rate my solution.
Rob
Jul 28, 2008 | Pentax Optio T10 Digital Camera
May 17, 2008 | Pentax Optio S5n Digital Camera
Pentax X70 Digital Camera Logo
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
