Question about Astar LTV-3201 32 in. LCD Television
Wont turn on
My 32" astar tv (about 1 year old) wont turn on anymore...the green power light flashes so i know it gets also makes a click noise like its trying to go on but nothing happens (black screen) no other previous problems or issues with this lcd tv
thanks joe
    Problem Solver:
  • 16 Answers
Re: wont turn on
call me at 323-767-6030 and I will help you go through with it and the troubleshooting.
Posted on Jan 31, 2009
Re: wont turn on
Same on my lg tv just got it fixed, it was the izuse power board at fault .
Posted on Nov 15, 2007
0 characters
3 Points
Need Help With My 32" AStar TV
I can help you test your power suppy for the Astar LTV-32ASB and try to repair it. But if you know the defective power for sure then I know where to get this original Astar power board. I worked in Astar Company as an electronics technician before till they are clossing down and I know all model of the Astar TV.
Please call me 323-767-6030 I will go through the trouble shotting, with you.
Jan 05, 2009 | Astar LTV-32ASB 32 in. LCD Television
No Picture or Sound from ASTAR 32 inch LCD Television
There is Part Store having Astar LTV-27BG boards in stock. Please check out might help you to power up back your TV.
Aug 28, 2008 | Astar LTV-3201 32 in. LCD Television
ASTAR LTV-3201 will not show picture anymore
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to if you require further assistance.
Dec 27, 2008 | Astar LTV-3201 32 in. LCD Television
power board is bad if it doesnt power up -- the red flashing lights mean that you need to upgrade the software-- you can get a new software upgrade on the website for philips --- use a thumb drive to install it into the television
Dec 16, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
ASTAR LCD TV 32'' won't turn on any more.
I have cable connected to my astar tv. I have the same problem whenever I turn my tv off of not getting the tv to come back on. What works for me is 1. Reset power- turning off both the tv
Nov 17, 2008 | Astar LTV-3201 32 in. LCD Television
Green Light
Most power up issues on these LCDs are due to a dying power supplies.
I repair these power supplies for under $90.00, let me know if you need further assistance.
Oct 24, 2008 | Astar LTV-3201 32 in. LCD Television
There is more than one problem with. A it could be the main board that finally gave out. B the power board in your TV is not work, and now you can see a picture. Depending on how it's connect the screen could be burn out. but just what type of light comes on when you try to turn it on. if the green light comes on and stay on then it has to do with the picture not the power if you need help narrowing down the problem you can call 226-2211 My E Discounts. I'm a tech and we work with a Astar TV from time to time.
Aug 28, 2008 | Astar LTV-20PW 20 in. EDTV-Ready LCD...
I aswell have an Astar LTV-3201.
I live in Brampton.
You can drop the whole TV or remove and send me the power supply board to get it fix.
My email is
May 03, 2008 | Astar LTV-3201 32 in. LCD Television
Google Allelectronics or Hosfelt Electronics for these caps
I just ordered these at a good price but ordered 35Volt instead.
Also replacing 3300uF caps too as they are bulged at top.
Hope this fixes it. Will let you know.
Nov 14, 2007 | Astar LTV-3201 32 in. LCD Television
Wont power on
I also have an Astar TV which turns on and flashes the Astar logo before the screen shuts down (Green power light stays on). From what i understand this is generally caused by low grade parts and to much heat. I dont know if you have gotten close to the TV while it is running but it gets extremely hot. The main issus with this is it causes the Capacitors to blow. there are about 20 of them and they generally sell for about $1.25 - $6 each online. If you have any experience soldering i have read about other people performing the fix themselves. I dont so i am currently looking into the cost to have them replaced by a professional. I will try and post what i find out.
Nov 07, 2007 | Astar LTV-2701 27 in. HD-Ready LCD...
Astar LTV-3201 32 in. LCD Television Logo
345 people viewed this question
Top Astar Flat Panel Televisions Experts
Jaime Hernandez
Are you an Astar Flat Panel Television Expert? Answer questions, earn points and help others
