Question about Philips 47PFL7403D 47 in. LCD TV
Philips LCD lamp repoacement - Philips 47PFL7403D 47 in. LCD TV
Philips 170s LCD Backlight turns on only 1 sec and than the backlight off. The indicator lamps still green.... anyone can help me? thanks
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 08, 2010 | Philips 170S5FB 17" LCD Monitor
Philips 170V LCD screen steadily blinks on and off, even when not
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
May 13, 2010 | Philips 170V6FB (Black) 17" Monitor
Where do i buy the bulb
The best place to buy the lamp is Discount-Merchant.com!
They usually have sales going on, and you'll get the OEM for your TV which is made by Philips Lighting of North America. If you have the original lamp in your TV it's made by Philips... a P22h if you've got an LCD projection.
These lamps should last 2-3 years at minimum.
Always buy from authorized distributors and buy original OEM parts whenever possible.
Feb 05, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Ihave a Philips 50PL9126D tv and I just replaced the lamp because the picture was very dark. I can see the picture but it is still somewhat dark, bright in the middle,dark at the edges. I tried to adjust...
Sounds like you may have the wrong lamp. Make sure you purchased a Philips lamp that's 100% compatible with your television model. Philips pioneered that lamp, so naturally they make 100 different types for DLPs and LCD projections.
You may have an elliptical lamp instead of parabolic. The lamp for your TV should read P22h.
Feb 04, 2010 | Philips Televison & Video
Sony KDL-46XBR4 much darker on the right side of screen
ITS THE PANEL ASSY. I JUST HAD MY REPOACED. SONY WILL HONOR A COURTSEY WARRANTY UNTIL 2012
Nov 26, 2009 | Sony KDL-46XBR4 46 in. LCD Television
Bulb pop and picture is out
Here is a link for a replacement Philips lamp for your TV model. Don't worry if it doesn't say Sony on the box as Philips makes the lamps for Sony anyway. Pleas take a moment to rate my answer. Thanks...
http://www.partstore.com/Part/Royal+Philips+Electronics/Philips+Lighting/F93087500RL/New.aspx?ModelMfgName=Sony&ModelBrandName=Sony&ModelNumber=KDFE42A10
Nov 23, 2009 | Sony KDF-E42A10 42 in. LCD Television
Where can i get a replacement bulb for 52 inch by d:sign lcd tv. the bulb reads philips uhp 120w 1.0 101859100
some electronic parts dealers are now selling this part. the actual size of the tv is important to have the real size you need. But the real original part maybe only the manufacture can sell it to you
Apr 17, 2009 | Televison & Video
Lamp reset.
there are 2 clocks 1 for lamp and 1 for total, the total you cant change. dark picture, make sure your got same wattage lamp for replacement, I find original Philips lamps the best. if it continues follow manufacture instructions on cleaning mirror and lens.
Apr 12, 2008 | Zenith E44W46LCD 44" Rear Projection...
Yellow tinged edges
Your problem is most likely your Blue and Green lens' inside the light engine. It's not something you can replace yourself. I worked for Philips for 14 yrs. repairing the LCD projectors the last 6 Yrs. Call philips and get the number of an ASC in your area that has repaired projectors.
Feb 14, 2008 | Philips Garbo Multimedia Projector
Philips 47PFL7403D 47 in. LCD TV Logo
35 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
