Question about Samsung LN55C650 TV
Ln55c650 no power
Basically the tv won't start I thought it was like my older tv with the capacitors but all of them seem to be fine when I opened the back. Any other ideas why the power would just shut off?
3 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: Samsung LN55C650 shut down; won't come back on again!
Someone has to open the set and look first at the power supply--if you are not able to do that consider having a shop look at the set.
Posted on Jun 11, 2012
  • 1684 Answers
SOURCE: Samsung TV won't turn on. Red light is solid, won't blink when pressed. All capacitors seem fine (none swollen or vented).
That model is covered under a class actions lawsuit settlement over bad power supply boards. You need to contact Samsung about this and get a warranty claim started, even if the original warranty is over the settlement terms will cover parts and labor. You can get additional information about this along with contact information here: http://www.ccl-la.com/blog/index.php/samsung-has-reached-a-settlement-in-class-action-lawsuit-over-faulty-tv-power-supplies/
Posted on Sep 25, 2012
The backlight on my Samsung ln55c650 goes out after being on for a short time.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Nov 19, 2015 | Samsung LN55C650 TV
When CRT JVC TV is first turned on, the image looks shrunken and warped, eventually, the image looks fine. What to fix?
SMPS fault. Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
Check all the electrolytic capacitors.
May 26, 2014 | Televison & Video
TV won't power up, but the capacitors seem fine....
The "rust" you are seeing is actually dried chemical fro the inside of the capacitor which does indicate the capacitors have bulged and blown. Even one or two bad capacitors will keep the power supply from starting up correctly. You need to replace them and the power board should be as good as new. Remember that when you replace them that they all need to be replaced not just the ones with visible bulging tops. The reason why you need to replace them all is two fold. First when some go out it puts a strain on the others and second you down want to have to keep opening the tv to replace them a few at a time every few months when they keep failing. If you need information on the capacitors to replace here is a link to capacitor information on the Digital Lifestyles models.
http://www.ccl-la.com/catalog/index.php?cPath=95_101
Feb 28, 2013 | Digital Lifestyle Televison & Video
Sep 24, 2012 | Samsung LN32A330 32 in. LCD TV
Jun 10, 2012 | Samsung LN55C650 TV
Ln55c650 flashe s
The Problem is with the power supply. It needs to be replaced. It is having abiasing problem that causes the backlight to flicker or strobe
Jul 22, 2011 | Samsung LN55C650 TV
Ln55c650 keeps flashing bright to dim very fast after about 30 minutes of being on if i shut it off for a few minutes it goes away til about 30 minutes the picture never goes away just gets bright and dim...
I had the same issue occur on my ln55c650 (screen flickering, not the actual image but the front lights flashed which was too distracting) and they had to replace the power supply pc-board. Seems some issue with power module in the TV rather than the side panels. Luckily for me, TV was still in warranty.
Hi I have a Samsung LN55C650. Yesterday it started to flicker on and off. If you turned off the tv for awhile the flicker would cease for 30 to 50 minutes and would then come back. It is now...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jul 17, 2017 | Samsung LN55C650 TV
Screen has started to flicker constantly. tv is 9 months old. When switched off flickering stops for about 5-10 minutes and then starts again
I had the same issue occur on my ln55c650 and they had to replace the power supply pc-board. Seems some issue with power module in the TV rather than the side panels. Luckily for me, TV was still in warranty.
Feb 23, 2011 | Samsung LN55C650 TV
Samsung LN55C650 TV Logo
41 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
