Question about Little Tikes Cycling
Mongoose raider 04a15c parts
Do you have a 1-800 number. I wish to buy a specific part. A gearwheel, or flywheel
2 Suggested Answers
  • 49974 Answers
SOURCE: replacement part for krups F417
go google and type in -- krups k417 -- and there are pages of information from different sites
Posted on Nov 15, 2015
How to hot wire a mongoose 90
join the wires on the back of the ignition switch. Power wire to one of the others until the ignition light comes on. Better to buy a new key though.
KYMCO Mongoose 90 Specifications KYMCO USA
Jan 29, 2017 | Kymco 2011 Mongoose 90
Replacement part for krups F417
Nov 14, 2015 | Cars & Trucks
Need charger and battery for model number 044T1085wm
Power Wheels Toddler 6 Volt Rechargeable Replacement Battery all 6 volt batterys will do the job just make sure you get a battery and a charging system together and you may need to split the wires and use electrical tape from the new battery to the old battery system wires
May 27, 2014 | Mongoose Raider Quad Ride-on Bike
Need a charger for model number kt1085wm mongoose raider quad
I have 6v chargers with alligator clips on the end that work, you'll just have to remove the plastic battery cover (6 screws) so that you can clip it onto the battery
Jan 06, 2013 | Mongoose Raider Quad Ride-on Bike
I need a seat for a mongoose raider quad
Do you still need one? I can order you one
Nov 28, 2012 | Mongoose Raider Quad Ride-on Bike
Need charger for this quad
Here is the number for kidtrax customer service you can order one from them 877-741-6154
Jun 28, 2012 | Mongoose Raider Quad Ride-on Bike
I need Parts battery chargers motors
you can call kid trax customer service to order
Please call: 877-741-6154
Sep 10, 2011 | Mongoose Raider Quad Ride-on Bike
Seat inca van 00 sdi 1.9 diesel.. tension polly came loose.. timing belt slipped.. I need to know how to reset it again. Where are the markings on the crank shaft and the cam shaft? Please attach any...
Timing belt set-up for a 2000 Seat Inca 1.9 SDi
1. Align the crankshaft timing marks on the flywheel / gearbox
2. Remove the valve cover
3. Lock the camshaft
4. Fit the injection pump locking pin
5. Loosen the camshaft gearwheel bolt, 180 degrees. Use a wrench to counter-hold
6. Loosen the camshaft gearwheel while holding it in place
7. Fit the timing belt in the sequence as shown in the below figure: a - b - c - d - e - f - g
8. Fit the timing belt and camshaft gearwheel together
9. Turn the tensioner clockwise to align both marks
10. Tighten the large bolt on the tensioner to a torque of 20 Nm
11. Check for correct fit
12. Lock the camshaft. Tighten the camshaft gearwheel bolts: 45 Nm. Use a wrench to counter-hold
13. Remove helping tools
14. Turn the engine two rotations by hand
15. Repeat the procedure if required
16. Fit the vacuum pump
17. Refit the crankshaft pulley. Tighten torque: 20 Nm + 20 degrees
18. Fit the timing belt cover
19. Refit the valve cover
20. Fit the ancillary drive belt
21. Refit the inlet air manifold hoses
22. Check the injection timing
Torque settings:
Camshaft gearwheel: 45 Nm
Tensioner pulley: 20 Nm
Crankshaft pulley: 20 Nm + 20 degrees
May 26, 2011 | Volkswagen Passat Cars & Trucks
Cycling Logo
44 people viewed this question
Top Little Tikes Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Little Tikes Cycling Expert? Answer questions, earn points and help others
