Can i wash the filters in my nilfisk vacuum - Washing Machines
5 Suggested Answers
SOURCE: nilfisk advance floor scrubber vacuum problem
CAN YOU HELP? I AM LOOKING FOR A SMALL FLOOR POLISHER AND SCRUBBER FOR MY OWN USE AT HOME. i SHOULD HAV TWO 5_6" SCRUBBER PADS AND FLOOR POLISHING PADS. THANK YOU AND GOD BLEES. NORSANRAIDERS@MSN.COM LOWTON , OK
Posted on Jul 10, 2008
EwingElect
  • 276 Answers
SOURCE: I SERVICE/USER MANUAL FOR NILFISK VT60CR.
Some information: http://www.nilfiskcfm.com/ProductLit/VT60.PDF
Accessories list: http://www.nilfiskcfm.com/ProductLit/VTACCE_1.PDF
Otheriwse to contact a local Nilfisk rep http://www.nilfiskcfm.com/FindARep.aspx
Posted on Apr 08, 2009
SmartAlec
  • 171 Answers
SOURCE: Vacuum emitting strong odors when it's on.
Hi there SmartAlec from NelsonVacuums.com.au here. I am a nilfisk vacuum agent and although i havent actually worked on one exactly the same as yours there are no Nilfisk with any kind of washable filters at all. I think you will have to replace it. If you are in Australia i can check out the cost of replacement filters for you just drop me an email with the exact model number.
Hope this helps.
Happy Vacuuming :)
Posted on Sep 01, 2009
  • 430 Answers
SOURCE: Nilfisk Family Vacuum - Strong Awful Odor
Not sure what a bacteria smell is perhaps you mean a mildew type smell.
If you have picked up something wet, start at the front of the vac and work your way to the exhaust.Change the front most filter first. Baking soda may help to eliminate some of the odor.
Personally as an allergy suffer, which you may be given the Brand I would remove all and let them and the tank air outside. Meanwhile install a fresh set.
Posted on Sep 13, 2009
Why is red light on my Nilfisk Orbit vacuum cleaner on ?
[PDF]Nilfisk GM80 and GM80i Vacuum Cleaner User Manual ...
www.sylvane.com/media/.../nilfisk-gm80-vacuum-cleaner-user-manual.p...
Troubleshooting. Loss of Power. 5. 6 ... CAUTION: This Nilfisk vacuum cleaner or any other vacuum cleaner is not to be used in explosion-hazardous areas, as ..
Sep 19, 2015 | Nilfisk Vacuums
My Nilfisk GU305 cuts out after a few minutes use
You are probably right. There is not enough air flow around the motor. It uses the air from the vacuum as the cooling air.
There is a secondary filter after the first filter bag. You may think the bag is not full and don't think you need to change. Sometimes the material you vacuum is so fine that it will clog the filter bag. I've done it vacuuming sheetrock sanding dust. Then just below the main filter is the secondary filter. Depending on the age and amount of use, there could be other problems. Motor brushes about to fail. A wire connection that separates as temperatures rise. Then reconnects when "cool". Plug end may be a problem. Its connection to the switch. The switch it'self could be.
Mar 21, 2015 | Nilfisk Vacuums
My Nilfisk Xtreme X200 vacuum cleaner will not start. The lights are workng on top but when I push start, it won't work.
Hi There,
I work as the tecnician for VacuumSpot and have done many repairs on the X200 extreme from Nilfisk. There are 2 reasons for the fault you are describing. THe first is that the machine has overheated due to a lack of cool air and has tripped the thermal cut out. This is usually as a result of using generic bags (not originals), having an old blocked filter or having a blockage in the hose somewhere. If the machine starts okay after a couple of hours of rest replace the bag, check the filter and if its dirty change it and check for a blockage in teh hose.
If it does not start after time to cool off you may have a faulty motor which is not an easy one to repair so I would suggest you take it to a Nilfisk agent to be assessed.
Mar 29, 2013 | Washing Machines
Looking for details for fitting dust bag in nilfisk king hoover
Hi There, I have made a quick video showing how to check the filters and also how to change the Nilfisk King Vacuum Bag. Take a look and you should be able to work it out.
Aug 30, 2011 | Nilfisk GDF2040 Vacuum
Need directions on how to remove old cotton filter and install new one and same for HEPA filter on Nilfisk GM/GS 80.
This link should help:
http://www.fixya.com/search.aspx?cstm=0&_s=Nilfisk+GM%2FGS+80+instruction+manual
Jim
Dec 03, 2009 | Nilfisk Family Vac Bagged Canister Vacuum
Sep 13, 2009 | Nilfisk Family Vac Bagged Canister Vacuum
Hope this helps.
Happy Vacuuming :)
Aug 31, 2009 | Nilfisk Family Vac Bagged Canister Vacuum
My filters? need cleaning
most likely the hose is blocked, drop a coin down it to confirm. You are best to replace the filters, they are not very expensive; though they are not likely to be the cause of your nilfisk over heating
Sep 26, 2008 | Nilfisk Family Vac Bagged Canister Vacuum
Nilfisk advance floor scrubber vacuum problem
Mar 12, 2008 | Vacuums
Washing Machines Logo
10 people viewed this question
Top Washing Machines Experts
