Question about Sony KDL32L5000 32 in. LCD HDTV
How do i know if if power board is no good?
Ligthing
I HAVE NO REAR LIGTHS NORE BREAK LIGTHS NORE THE DASH BOARD
First check fuses. The parking lights and dash lights come on with the light switch, but have different fuses. if you have front lights( the switch is good), but no rear, check the grounds in the rear. They are usually mounted to the frame on the drivers side rear. As for the dash they have their own grounds. Places I know are at the steering column and behind the drivers side kick panel. You could also have problems at the plugs them selves, Corrosion. If you have no parking, brake, or reverse lights, it is a ground problem.
Jun 13, 2016 | 1999 Mitsubishi Montero Sport
When I press the power on the on ligth does not come on,and the dryer does not come on,befor when i press the power on the ligth blink for a secon and go out, and now when i press the power on nothing
The first think you need to do is check the circuit breaker. If the breaker is off, turn it all the way off and then to the on position. If it trips off again, you have a short in the wire. DO NOT plug anything into the outlet. It is a 220 line and you can be seriously injured.
Another issue could be the circuit board is faulty and the machine will prevent itself from turning on. If the breaker is good and the machine still does not remain on, you will need to call a service technician for the dryer. Good Luck!!
Dec 13, 2014 | Dryers
Power goes down suddenly
If it is out of warranty, write down the model of boards inside
replace the power board, once installed power it up, and see if this
does solved your previous issues, good luck
Mar 18, 2014 | Hitachi Gst Hitachi L37X01A 37 inch Full...
I turn on the tv and in a moment the stand by and a red ligth turn on blink twice and the tv goes off i read the code what it means but i dont know what to do exactly can you explain and tell what to do
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this helpout in solving the problem...
Aug 22, 2011 | Sony KDF-E42A10 42 in. LCD Television
I have a tv sony wega and the ligth us blinking 6 times in standby I change the lamp and still not turning on what can I do
Hoping this will help to solve the problem....
Aug 08, 2011 | Sony Televison & Video
My sony bravia 46" doesnt
hi,
you have to replace the inverter board. If the invereter board overloaded the powers supply, then the tv will go to standby after some time.
ok
Jun 21, 2011 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
My sony grand wega kdf-60XS955 dont turn on
Power suppply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 08, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
PLTV-3250 SPECTRONIQ No Power no ligth
Most of these have a bad power supply Number on board FSP 194-3F01. Available on Ebay.
Jan 12, 2009 | Insignia I-PD1020
EVAPORATOR MOTOR WILL NOT STAY ON
m
ake sure yo have a good ground to the unit
allso take note of blinkingg ligths these are codes to let you know what the problem is
Jul 17, 2008 | Ruud UBHC Air Conditioner
Hitachi T.V.
Good Day, halobeast044;
Replaced the LAMP. Good Luck big IRISH.
Jul 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Sony KDL32L5000 32 in. LCD HDTV Logo
48 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
