Question about Fortron (FSP400-60PFN) (fsp40060pfn) 400-Watt Power Supply
Fortron FSP400-60PFN diagram - Fortron (FSP400-60PFN) (fsp40060pfn) 400-Watt Power Supply
Fortron ATX 300GTF wanting 2 power the molex connector on this unit for an external disk drive not linked to a computer.cant get power without plugging in or modding the 20 pin power adaptor.
Most new power supplies can only be turned on via motherboard signal. That is why you have to plug in the 20/24 pin connector from PS to mo bo. When operating yellow wire is 12 volts and red is 5 volts DC. And black is ground.
Mar 07, 2016 | Computers & Internet
Where can I get a wiring diagram?
NEED WIRING DIAGRAMS FOR LIONEL #1055 TEXAS ...
www.faqqq.com/.../need-wiring-diagrams-for-lionel-1055-texas-lionel-doll...
Question Product: Lionel Dolls, Playsets & Toy Figures Question Details: NEED WIRING DIAGRAMS FOR LIONEL #1055 TEXAS NEED WIRING DIAGRAMS ...
treadmill wiring diagram Dolls, Playsets & Toy Figures ...
www.fixya.com > Forum > Tags > treadmill wiring diagram
Ask your treadmill wiring diagram doll, playset and toy figure questions. ... need a wiring diagram for a massey ferguson 135 tractor lookin for a complete wirng ...
pactrol p16 wiring diagram Dolls, Playsets & Toy Figures ..
Jan 17, 2016 | Toys
Need a vacuum hose routing diagram for a 99 VW Beetle 2.0
VACUUM LINE DIAGRAMS
There are few direct links showing exact vacuum line diagrams. I suggest you to refer the direct links.
Click the link below: -----
How to locate the vacuum leak?
http://howtobyme.blogspot.in/2012/01/how-to-locate-vacuum-leak.html
Vacuum Hose Routing Diagram For 1995 Chevrolet Corvette Throttle Body?
http://schematicsdiagram.blogspot.com/2011/12/vacuum-hose-routing-diagram-for-1995.html
VACUUM DIAGRAMS For Audi A4?
http://repairhelpcenter.blogspot.com/2011/11/vacuum-diagrams-for-audi-a4.html
VACUUM DIAGRAMS For VW Passat?
http://vwrepairhelp.blogspot.com/2011/11/vacuum-diagrams-for-vw-passt.html
Vacuum line diagram For 1996 Chevrolet Lumina?
http://schematicsdiagram.blogspot.com/2011/12/vacuum-line-diagram-for-1996-chevrolet.html
Vacuum diagram for Isuzu?
http://technoanswers.blogspot.com/2012/01/vacuum-diagram-for-isuzu.html
Ford 4 wheel drive vacuum solenoid working system?
http://technoanswers.blogspot.in/2012/02/ford-4-wheel-drive-vacuum-solenoid.html
These will help.
Thanks.
Dec 06, 2012 | 1998 Volkswagen Beetle
R & R motor and where do the vacum lines
There re few direct links showing exact vacuum line diagrams.I suggest you to refer the direct links.
Click the link below:-----
How to locate the vacuum leak? http://howtobyme.blogspot.in/2012/01/how-to-locate-vacuum-leak.html
VACUUM DIAGRAMS For VW Passat? http://vwrepairhelp.blogspot.com/2011/11/vacuum-diagrams-for-vw-passt.html
------------- Vacuum line diagram For 1996 Chevrolet Lumina? http://schematicsdiagram.blogspot.com/2011/12/vacuum-line-diagram-for-1996-chevrolet.html
-------------- Vacuum Hose Routing Diagram For 1995 Chevrolet Corvette Throttle Body? http://schematicsdiagram.blogspot.com/2011/12/vacuum-hose-routing-diagram-for-1995.html
------------- Vacuum diagram for Isuzu? http://technoanswers.blogspot.com/2012/01/vacuum-diagram-for-isuzu.html
Ford 4 wheel drive vacuum solenoid working system? http://technoanswers.blogspot.in/2012/02/ford-4-wheel-drive-vacuum-solenoid.html
These will help.
Thanks.
Nov 26, 2012 | Cars & Trucks
Where located fuel sensor Suzuki Ario 2003
Component location diagrams for most 2003 Suzuki Aerio cars and light trucks sold in the U.S. from 1990+.
clsk2003aeri003.gifIgnition System Components Location Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
Components on diagram:
  • TP Sensor
  • Ignition Coil
  • ECM
  • MAF Sensor
  • CMP Sensor
  • clsk2003aeri007.gifElectronic Shift Control System Components Location Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
  • Data Link Connector
  • Transmission Range Sensor
  • Throttle Position Sensor
  • Pressure Control Solenoid Valve
  • Battery
  • clsk2003aeri010.gifInstrument Panel For Connector Layout Diagram Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Clutch Switch
  • Thermistor
  • Brake Light Switch
  • Blower Motor Relay
  • Heater Fan Motor
  • clsk2003aeri011.gifInstrument Panel Harness Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Wiper Switch
  • Washer Switch
  • Turn Signal Relay
  • Radio
  • clsk2003aeri015.gifHeadlight System Location Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Headlight Relay
  • Headlight
  • Clearance Light
  • Headlight Diode
  • Clearance Light Relay
  • clsk2003aeri022.gifFuel System Components Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Fuel Pump Relay
  • Fuel Tank Pressure Sensor
  • EVAP Canister
  • Fuel Tank Pressure Control Valve
  • Fuel Filler Cap
  • clsk2003aeri027.gifFloor For Single Unit Parts Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
  • Wheel Speed Sensor
  • ABS Control Module
  • G Sensor
  • Air Bag Control Module
  • EVAP Canister Vent Valve
  • clsk2003aeri030.gifInstrument Panel For Ground Point Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Instrument Panel Ground Points
  • clsk2003aeri036.gifEngine Compartment For Single Unit Parts Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
  • Horn Relay
  • Radiator Fan Control Relay
  • Cruise Control Module
  • Condenser Fan Relay
  • clsk2003aeri037.gifEngine Compartment Components Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • MAP Sensor
  • Knock Sensor
  • Noise Suppressor
  • Heated Oxygen Sensor
  • Sep 18, 2011 | 2003 Suzuki Aerio
    Do you have a digram to show you how to change belt on inglis dry
    amana.gif Diagram A
    Style: Flat with ribs
    Installation Tips: Ribs face toward drum
    transparent1.gif frank.gif Diagram B
    transparent1.gif frig.gif Diagram C
    transparent1.gif ge.gif Diagram D
    Installation Tips: Ribs against drum
    transparent1.gif maytag.gif Diagram E
    Installation Tips: Flat side of belt against drum
    transparent1.gif admiral.gif Diagram F
    transparent1.gif westing.gif Diagram G
    Style: Flat belt
    Installation Tips: Side of belt with words faces away from drum
    transparent1.gif whirlpool.gif Diagram H
    belt1.gif Diagram J
    belt2.gif Diagram K
    belt3.gif Diagram L
    belt4.gif Diagram M
    Jun 25, 2009 | Whirlpool Inglis IP8200 Dryer
    Psu
    200 watt max. 19v DC power brick with a 4 pin plug, with two positive and two ground pins. The PSU is unique to the E-bot. I have not been able to find an exact match anywhere. Foxconn no longer sells the PSUs and will not help with tech support in any way. The PSU was originally produced by Fortron Source Power (FSP). When mine went bad, I had to buy a similar looking unit (but with only a 150 watt max rating), then I had to rewire the output cord, because the 4 pin plug had the positives and negatives switched around.
    If you need a new power brick for the Ebot, I seriously hope you have the old original unit still. If you do, you can then simply buy any 19V laptop power brick that has acceptable power output (at least 120 watt) and then replace the power output cord with the original one from the Ebot's power supply (some soldering required). It's really the only way to replace the unit.
    Jun 23, 2008 | Foxconn eBOT Barebone
    My FSP145-50N power supply won't come on, I think it is the fuse, but wher is the fuse located anyway?
    Hi, remove the power supply from the case, [easy job] examine it and yuo will see about 4 or 5 screws holding the cover together.
    Seperate the 2 parts of the cover and study the printed circut board. The fuse will be a glass tube type fitted to this board. Some PSU's have the fuse soldered in place and you may need to solder a new one in, otherwise it will just unplug and replace.
    MAKE SURE YOU REPLACE THIS FUSE WITH THE SAME VALUE FUSE, available from computer repair or electronics store. regards mistyman
    Oct 11, 2007 | NEC FORTRON/SOURCE 145W POWERSUPPLY...
    NEC FS-8001
    NEC is famous for under rating it seems there sets. Not sayying that the sets are not good but I've seen hundreds of NEC with what looks like over heating. I too hace seen several power supply problems and it comes to mind that a small choke that looks like a small resistor with wire wrapped around it has been the problem several times as you must also take out the parts that looks burnt and clean the area and take off all the overheated solder and clean up the pcb and reinstall and resolder with new solder if you want to not have intermittant connctions again. Oh almost forgot that these coils are on the output of the power supplys and make sure you check all the caps as well in the output of the power supplys as well as in the sweep supply as this can cause your sort of problem as well.. Good Luck PS if a resistor looks burnt they are so cheap you should replace it as resistors that look or have been overheated can and will breakdown under power or a load.
    Apr 11, 2006 | NEC FORTRON/SOURCE 145W POWERSUPPLY...
    Fortron (FSP400-60PFN) (fsp40060pfn) 400-Watt Power Supply Logo
    48 people viewed this question
    Top Fortron Computers & Internet Experts
    David Payne
    David Payne
    Are you a Fortron Computer and Internet Expert? Answer questions, earn points and help others
