Question about Ariens 34 In. Zoom Series Riding Mower
How do you tighten PTO belt?
PTO belt is loose and I can't figure out how to tighten. Mower is only 2 months old so I have no idea how it got so loose.
  • Anonymous Mar 23, 2014
    mower will not go up hills think the power belt is slipping or loose how do i tighten it
I had a similar problem with my mower right after i bought it. my belt was just loose enough to be a pain on cutting i bought a larger pully with the same belt groove and center hole as the one on my deck but in a larger diameter and replaced a pulley on the side(easiest to get to) the belt is still going but does need to be replaced. Keep your original pulley so when you buy a new belt you can swap it back
Posted on Jun 30, 2009
    Scholar:
  • 81 Answers
If the belt is loose it probably needs replaced or has jumped out of one of the pulley or belt guards allowing it to be sloppy. Belts get stretched in many different ways, tall grass, grass getting in the pulley, or they just plain stretch. First though, check to be sure the belt hasn't jumped out of it's normal runway.
Posted on Jun 23, 2009
    Problem Solver:
  • 5 Answers
Check the idler arm and make sure it can move. Sometimes they can stick and will prevent the belt from re-tighting as you adjust the height of the deck.
Posted on Jul 07, 2009
I have a 2011 cub cadet ltx1040 with 42 inch mower deck. replaced belt, pto cable and spindle brake pads. Belt is still loose when pto engaged and cannot find any adjustment to tighten belt. All parts...
If all the parts are correct then you need to check the belt routing diagram. Sometimes you can find it on the mower deck and in the owners manual. Look carefully at the spring locations on the deck to be sure there correct. George
Aug 31, 2013 | Garden
Toro Z4220 PTO problem
check fuse to pto dose pto click when you start the swicth could be that safty switch has come lose keeping pto from operation take off belt and by pass switch to pto see if it activates what you want to make sure pto didnt burn up im more thinking it is a relay gone bad or a blown fuse
Jun 26, 2013 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I have a 2002 YardMachine, 660 Model, 15.5 HP, 42" Cut. Two Issues. 1) After changing of PTO Cutting Blade Belt, mower lost all power to transmission. No GO F or R. Before belt change, mower would loose...
without looking at the belts i will tell you that the wheels on most mowers only come in a few sizes and are made by just one or two companies. so find a mower or small engine repair shop in the phone book and go get some new wheels and bearings from them. makes it easy if you take an old one with you. while you are there run the belt issue past them and maybe they can give you some guidance.
Oct 18, 2010 | Yard Machines 42" Tractor Mower Blade Kit ...
Mower starts, but won't move forward. I found torn belt underneath. I'm assuming this is a drive belt (are there two--one for each wheel). How do I change it out. (Best way to lift a zero turn?).
First, wedge something in front of the front wheels (when you lift the back, there's no brake action). Get the jack from your car and position it to lift the rear of the mower chassis. Jack it up then put blocks under the rear wheels - you may be able to do both at once, or you may have to alternate - then lower onto the blocks. Get enough space. You'll have to take off the mower belt and remove the PTO clutch anchor (two bolts) and may have to take off the wires connected to the PTO clutch (connector may be above the chassis). Then pull off the spring that tightens the idler arm, remove the old belt (if it's still there) and install the new one. Refasten the spring to tighten the idler, replace the anchor and mower belt, and mow away. Good luck! Please rate my answer if helpful, thanks.
Jul 05, 2010 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
I have a model 13aq609g063 troy bilt riding mower. It has a 18hp briggs & stratton, 2 cylinder, ic engine. the engine runs fine, the bottom pulley on the engine for the pto belt turns when running, and...
Another possibility, is a broken spring or a tight/ rusted idler pivot arm.
with the engine off & the deck down, engage the pto & pull on the belt to see which pulley is the tensioner
Nov 07, 2009 | Garden
Broken belt
This is actually pretty simple:
Remove Pto guard on mower deck
Stand mower up on back stands
Pull the friction disc away from the drive disc
slip new belt in between the friction disc and drive disc pushing all the way through
release friction disc allowing to come back in contact with drive disc
loop belt around engine pulley
let mower back down
route belt around mower pulley
loosen guides on idler pulley
route belt through idler pulley
with engine off move pto lever to tighten mower belt
adjust guides on idler pulley allowing 1/8" from belt
tighten bolt on idler pulley
release pto tension
install mower pto guard
and you should be ready to mow
Aug 14, 2009 | Garden
Cable for pto is loose and when done mowing will not disengage, the blades still spin. You can turn the mower off and then they will stop, and the tractor will restart with no problem, as if the pto is not...
It's probably not the cable, but the idler arm on the deck that the pulley that tightens up the belt is not moving back and forth freely, probably from rust. Spray penatrating oil on the pivot point while working it back and forth until it frees up. If still having problems, let me know. Dwain
Jun 10, 2009 | Garden
Ariens 34 In. Zoom Series Riding Mower Logo
1,102 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
