Question about Electrolux EW30GF65GS Gas Range
How to unlock the lock mode on gas oven door?
2 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: oven door lock does not unlock
Hi
Thanks for using FixYa. There is an over-temperature switch built into the electrical panel of the oven. Resetting this switch might solve the issue.
To reset it: Turn off the power. Open the door (if door is locked, turn the power back on and gently try pulling the door every few seconds as the locking mechanism cycles until it is unlocked). Remove the 3 screws below the control panel (screws point upwards, with the head just inside the oven). Pull off the face of the control panel. Let it dangle by the wires so that you have access to the space behind it.
Within the electrical enclosure exposed by removing the control panel, look for a small silver and black device with 2 wires attached to the back. The device is about .5" wide by 1" long and is attached with 2 screws to the sheet metal on the bottom of the electrical enclosure.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Nov 26, 2009
Why is oven door locked after self-cleaning mode?
How To Fix Oven Door That Doesn't Open After Self Clean ...
www.partselect.com/...Stove-Oven/Door-Will-Not-Open-After-Self-Clea...
How To Fix An Oven Door That Won't Open After A Self Clean Cycle ... This may reset the control and allow you to unlock the door. If you still cannot unlock the .
Repair - Dead oven after self clean mode, blank display ...
? 9:38
https://www.youtube.com/watch?v=UylZKwzAPow
Feb 22, 2014 - Uploaded by Random Repair
Repair - Dead oven after self clean mode, blank display, locked door Kitchen Aid Whirlpool How to repair an ...
Nov 26, 2015 | Kenmore Kitchen Ranges
Oven door wont open
i was cleaning the oven when they a black out and when the light came on the oven whould not come on and the is still lock what can i do
Jun 01, 2010 | Kenmore 36665 / 36669 Gas Kitchen Range
Maytag gas oven lock does not release
Unplugging it for a few minutes may reset it.
Sep 28, 2017 | Maytag MEW5530D Electric Single Oven
Kenmore 75565 gas oven door is locked. While baking, my son
Had to loosen the lock -- loose enough that the door opened. Only thing that worked. Of course then door wouldn't shut! Cut off the lock and will have to replace.
Feb 10, 2010 | Kenmore Kitchen Ranges
Frigidaire, Gas Oven Door
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%$#
Oct 10, 2008 | Frigidaire Gallery GLEFM397DS Electric...
Oven door that wont come unlocked
sounds like you have a latch/lock issue. the unit seems to think the door is still currently locked, preventing proper operation, i would try to see if you can locate the door/light switch and manually trip it with your hand(turning off light). then while keeping depressed activate the self clean mode again, the machine will try to engage the lock/latch, as soon as it does then cancel it and it will return back to a normal resting location. you must keep the light switched pushed in order for this to work correctly
Oct 07, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven door locked
Please check my earlier post on this problem.
I forgot to add that the only way the Tech is able to get the oven door unlocked after it shuts down in the Self-Clean (Self-Destruct?) mode is to take a pair of pliers and short across the bad Thermal Protection swtich before replacing it.
Mar 22, 2008 | KitchenAid KGSA906PSS Gas Kitchen Range
Oven stays in locked door mode cant use oven
locked door is flashing and oven will not go on, help need to disconnect dorr latch if anyone knows how
Dec 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Self cleaning
Maryann, try shutting the breaker off for 5 minutes and see if the door unlocks. Im assuming the oven has cooled down. If that doesn't work try holding the cancel and broil pads for 3 seconds. This will put it into the quik test mode. Once in this mode press the clean button. This should toggle between lock and unlock. Don't know if this will work for you but it's worth a try..Catriver...post back.
Oct 12, 2006 | Jenn-Air JJW9330D Electric Single Oven
Electrolux EW30GF65GS Gas Range Logo
20 people viewed this question
Top Electrolux Kitchen Ranges Experts
Rommel Balcita
Mike Henne
Level 1 Expert
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
