WFS1073DD wont turn on - Washing Machines
Whirlpool model wfs1073dd. what is the cause of water coming out of soap holder when trying to fill machine
The dispenser is flushed at the beginning of fill to remove detergent residue. This is especially important if powdered detergent is used.
Nov 15, 2016 | Whirlpool Washing Machines
WFS1073DD front loader. Why did it lose power and shut down completely during wash cycle?
It's one of the best washing machines . yes the board dies . I fixed a couple of them . They are now running for years .
It's just the board, other bits like the motor, pump or bearing are one of top in the list other brands can let you down . Broken bearing or burnt motor. Also it's gentle on your clothes and wallet!!! Saves you heaps.
I can fix yours. Contact me .
Feb 01, 2016 | Whirlpool Washing Machines
I bought a new handle for my washer WFS1073DD but i cant work out how the spring goes on to connect the handle.. PLEASE HELP!!
Its hard to describe how the spring sits, but you have to remember that the catch must be in tension so that it always engages in the lock. there is only one way that it will do this, so im afraid its going to need a lot of patience and trial and error.
if you go to the e-spares website, there maybe a video tutorial.
May 29, 2014 | Washing Machines
WFS1073DD seems like no power supply. There is power at the wall. No lights or fault codes
Retrieve the diagnostic manual taped inside the
machine & follow the test procedure for that problem
Aug 29, 2013 | Whirlpool Washing Machines
Door won't unlock whirlpool wFs1073dd front loader
If it has water in the the machine, it has a safety feature that will not allow the door to unlock. There is a manual release but you have to take the bottom kick plate off. Unplug the washer. Then reach up on the right side of the washer and you will feel a plastic lever about the size and shape of a nickel pull down on this lever to release the door. If it full of water i would clean the pump first to get rid of the water. you can clean the pump by taking off the kick plate and you will see a pump with a lid with a handle on it. you can unscrew this and it will have a trap attached to the back of the lid. pull the trap out and clean any debris out then screw it back in. make sure to have buckets and towels handy once you unscrew the lid any water in the machine will fly out at you. the easiest way to avoid this is to clamp the hoses that go to the pump.
Aug 24, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Clean Pump Whirlpool WFS1073DD
Thank you kerrygibson, the black pipe did it.
Jul 09, 2012 | Whirlpool Washing Machines
How do i clean the filter/pump on my whirlpool Front Load Washing Machine WFS1073DD
We cannot open the pump black round inside it keep goin round
Jan 28, 2012 | Washing Machines
My wfs1073dd washing machine is leaking water from the bottom
you will have to check the hoses for lose conections/slits if its not a pipe then the drum seal is probably leaking
Jul 30, 2011 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
