Question about InFocus LP640 Multimedia Projector
Infocus l640 fan stopped - InFocus LP640 Multimedia Projector
Infocus LP240 fan shuts off
If you want you can check the voltage at the power conector on de main board. but the problem are the fans, replace the fans, and check the routing cable, its very important.
Jun 25, 2010 | InFocus LP 240 Multimedia Projector
Proxima ls 1 fan is to loud
the bearings are going. time to replace it before it stops working and the projector overheats. av solutions in ny might be able to get it. they're an infocus service center. www.avsolutionsny.com
Jan 13, 2010 | InFocus Proxima UltraLight LS1 Multimedia...
I have an IN72 Infocus DLP Projector, after plugging in the power source to a dedicated outlet and verifying that outlet was good I can not turn the projector on. As soon as the plug is inserted into the...
power supply needs to be replaced. you can get the part from an infocus service center, or send it to the to repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Jan 10, 2010 | InFocus IN72 Multimedia Projector
I HAVE AN INFOCUS SCREENPLAY 5000 PROJECTOR THAT DISPLAYS THE MESSAGE "ONE OF YOUR FANS ISNT WORKING SO SHUT DOWN WILL OCCUR SHORTLY"... PLEASE TELL ME WHAT I CAN DO TO FIX THIS ISSUE. THANK YOU IN...
there are 2 fan assemblies in this model. a double fan for the lamp, and a single fan for the dmd chip. check for obstructions through the vents (pieces of plastic or paper will stop the fan). if nothing is in there, you could buy the parts from an infocus service center and replace them yourself or send it to them to fix. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 12, 2009 | InFocus LP70+ Multimedia Projector
Infocus lp820 i press power can not hear any fan moving lamp turn on with gray light after 10 sec lamp shut off and message says "fan stopped"
you need to replace the fans; they may have burned out. you could try to get one from an infocus service center or send it to them for repair, but know that this is an old machine and parts may not be available. you could try getting a used one on ebay that has a different problem and swap out the parts. if you do decide to send it in or find new parts, try av solutions in ny. they're really good. www.avsolutionsny.com
Nov 12, 2009 | InFocus LP 820 Multimedia Projector
Infocus Lp120 stops working after 30 minutes
lamp expiring soon or overheating. also check colorwheel.
Apr 02, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
LP120 : fan stopped error
you can purchase and replace the blower assembly- part # 505-1917-00. it's tricky, but you can do it. find an infocus authorized service center form their web site to buy it.
Jan 19, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Fan problems
find out which fan is not working and clear out the obstruction, if any. otherwise, you need to replace it. they are easy to replace once you find out which one.
Sep 09, 2008 | InFocus LP70+ Multimedia Projector
4805 infocus projector
it is the colorwheel bearings going slowly due to excessive dust and heat. remove the lamp and push in the switch actuator on the lamp door frame. turn the projector on and see the colorwheel spin in the lamp housing window. does the noise happen when the wheel spins and stops when the wheel stops? let the switch actuator go. does the noise stop? it's the colorwheel (pn: 525-0146-00). you can get it through an infocus service center. try av solutions in ny. www.avsolutionsny.com
May 10, 2008 | InFocus ScreenPlay 4805 Multimedia...
InFocus LP640 Multimedia Projector Logo
32 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
