Question about Polk Audio PSW111 Speaker
Makes loud popping noise volume knob seems to be bad
    New Friend:
  • 3 Answers
Volume controls are known to go intermittent and cause this.Its a surface mount type and would require exact part.Try removing back of pot to get inside to chemical spray it out with pot cleaner.
Posted on Aug 09, 2014
How do I replace a subwoofer potentiometer ?
If the 10k resistor is the variable volume one then change it.Some sub amp plates have epoxy all over the pcboard.Hard to remove type.I think yours is soldered to a sub pcb and need soldering experience to remove.
Sep 14, 2014 | Polk Audio PSW111 Speaker
Popping noise
Check the sub with a multimeter. It should read the ohms it is rated at when you hook it to the positive & negative inputs. It its off your coil if bad.
Mar 16, 2013 | Alpine SWR-1241D Car Subwoofer
Sunfire annoying popping noises
If you remove the volume knob, and tighten the nut below, it should take care of the popping noise, as well as any input noise issues. Based on my experiences with my MKII
Apr 01, 2009 | Sunfire True Sub MK II Subwoofer
Guitar amp make large crescendo-like noise, loud pop at end.
Same loudness, no speaker? This sounds (no pun intended) like a filter capacitor shorting out. Open it up and VERY CAUTIOUSLY look for what is making the noise. Filter capacitors can eject hot stuff. Very dangerous.
Jul 22, 2008 | Audio Players & Recorders
Intermittent, random, loud popping noises.
you have a problem with your amp. most likley the finals are passing dcv intermitently to the load.
May 28, 2008 | Audio Players & Recorders
Popping & hardly any volume
i had the first problem and you can probably fix it by turning the volume knob all the way up and down about 20 times. it worked for me. supposedly the potentiometers in the z-5300 get dirty or worn out, somehow this might fix it. for the second problem maybe try plugging it into the laptop and unplugging it again seeing if it goes back to normal?maybe its a problem with the amp?
May 07, 2008 | Logitech Z-5300 Computer Speakers
you should check the outline ctrl..for a mic...it could produce a noise...if you have your speakers connected to pc...check the position of the plugs and the volumen of mic put in down...
Nov 24, 2007 | RCA RT2760 System
Polk Audio PSW111 Speaker Logo
267 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
ed_dantes
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
