Question about Samsung CLX 3160fn All-In-One Printer
A printer repair man fixed our deve error. took
A printer repair man fixed our deve error. took printer apart and replaced hard drive. next day a spool fell out. how do we fix this. do you have a picture of the spool layout in the printer?
    Brigadier General:
  • 4,090 Answers
Maybe the printer repair man guarantees his work? i would be telling him that sijnce he fixed it this problem occured.
Posted on Jun 23, 2009
7.010.43 problem with Xerox Phaser 8550
Hi there, Love your enthusiasm to fix it - probably very similar to me. But I think you'd be better suited finding a replacement part and buying that, then replacing with an original. I'm not sure what part of the world you're in, but there will be xerox service centres around. Or you could call-up a local printer repairer and ask them to get you the part. Otherwise you just start opening a can of worms when you start gluing it in - then there's a potential that it doesn't hold properly and next thing you're having the same problem again. Alternately - try to pick up a used printer on ebay or similar of the same model that is broken or for parts and hope that they don't have the same problem.
Feb 10, 2014 | Xerox Phaser 8550DP Printer
My dogs were playing and my laptop fell onto the ground, not once,but twice (about two feet each time)! I heard a whirling, scrapping noise then it went away after some time.Everything worked fine for a...
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
go to control panel administrive tools computer management you can right click on the drive select properties tools check now?tick in both boxes to scan for and attempt to repair/recover any bad sectors and automaticall fix any corrupt files
in xp
hope this helps
Jan 31, 2011 | Computers & Internet
My Dryer stopped heating, It justs runs with no heat.
Get the rear cover off and check the fuse
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 09, 2009 | Dryers
Electric Window cable connections
unfortunatly there is no diagram or actual repair for a window regulator. the only fix is to replace the regualtor assembly. ive replaced hundreds of them at the jeep/chrysler/dodge dealer i work at
Jan 05, 2009 | 1999 Jeep Grand Cherokee
X73 found loose spring
I was having a similar problem. After finding the service manual (4402_X73.pdf) and taking the thing apart, an ink-covered broken spring fell from the inside. I checked around the 'Maintenance Station' and found the other half still hanging. Apparently -because I haven't got a replacement yet to confirm- the spring goes across the bottom of the 'Maintenance Station' to a lever on the other side. If someone can tell me where to post a picture of the thing, I'll gladly do it.
Jun 21, 2008 | Lexmark X73 All-In-One InkJet Printer
Canon imagerunner 2200 error code E000602-0003
This is hard drive failure. If you another code other than 003 you may have gotten away with a scan disk, but not always. in your case the hard drive has died. a Canon Technician will need to replace it and re-install the machine's system software
Mar 13, 2008 | Canon imageRUNNER 2200
Printing blank pages
I am working on the same problem. While you will not like the
answer here it is for the canon mf6530. What is causing it
is the shutter over the laser is failing to open. There for
it blocks all exposer. A temperary fix is to carefully lift the
shutter and tape it open using black electrical tape. Then
try a few prints you should have an image if this is your
issue as it is mine. I do not recommending running it in
this condition very long. When I find the final answer I
will attempt to post it.
Jan 05, 2008 | HP DeskJet 880c InkJet Printer
Error message
If you are getting inksystem failure along with Error 0xc18a0106 then contact HP support, if you are not getting ink system failure along with Error 0xc18a0106 then power cycle the printer and then reset, this will resolve the issue.
Jul 03, 2007 | HP Photosmart 3210 Printer
Samsung CLX 3160fn All-In-One Printer Logo
108 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
