Question about WHITE-RODGERS DIV White Rodgers Furnace Fan Control Circuit Board 50A55-474 50A55-571 50A55-843
Control Circuit Board 50a55-571 - WHITE-RODGERS DIV White Rodgers Furnace Fan Control Circuit Board 50A55-474 50A55-571 50A55-843
How to put in the circuit board on hotpoint aquarius wf440 ?
this may be of some help good luck
otpoint control module configuration for selfix - YouTube
? 9:21
https://www.youtube.com/watch?v=cHpz2OcbHAY
16 Sep 2011 - Uploaded by Selfix UK
Hotpoint control module configuration for selfix ... How to change the display pcb on an Ariston Washing ...
How To Replace A Washing Machine PCB - YouTube
? 4:19
https://www.youtube.com/watch?v=vskrPU9zU5M
27 Apr 2013 - Uploaded by Selfix UK
How To Replace A Washing Machine PCB ... Repair HotpointWF541 WF540 WF740 with flashing lights ...
Modules & Control Boards ' Washing Machines ' Spare Parts ' Hotpoint
parts.hotpoint.co.uk/.../washing-machines/...boards/.../C8-RIC-LVTRC-...
Have you lost complete control of your washing machine? ... If your PCB assembly (printed circuit board) is faulty then replace today for an efficient and effective ...
How to Replace Washing Machine Control Panels - Hotpoint ' eSpares
www.espares.co.uk > Home > Advice Centre
8 Jun 2010 - Replacing any of the front panel controls on a washing machine is ... how to replace any of the knobs, buttons, printed circuit boards that sit ...
How to Diagnose Washing Machine Control and Program Problems ...
14 Nov 2013 - Watch Josh explain how to diagnose washing machine control and program problems. ... If you then suspect that the problem still lies in the circuit board ... to test the board and you'll actually just need to replace it altogether.
Hotpoint WD420 fault ' Page 2 ' DIYnot Forums
www.diynot.com > Forums > How to... > Appliances
31 Oct 2009 - 15 posts - ‎11 authors
hotpoint aquarius wf530 washing machine flash like Christmas tree when ... After reading this forum I took the PCB board out and the C17 ...
Hotpoint WF540 washing machine board issue - pics included ...
www.electro-tech-online.com > ... > Repairing Electronics
19 Mar 2011 - 14 posts - ‎9 authors
Just took the board out of the washing machine to check the c17 cap ... was gonna cost £150 just for a replacement board without fitting.
Hotpoint - EMW Electronics
https://emwelec.co.uk/index.php?l=product_list&c=13
This is the Mark 6 board fitted to late Hotpoint washing machines. The module will be programmed to your model number - ready to fit. Typical models are WF550P WF560G .... Hotpoint Arcadia PCB Modules. SKU: 256. Hotpoint Arcadia PCB ...
modules and PCB's for washing machines and washers for Candy ...
www.unifit.co.uk/washing-machine-washer-spares-parts-replacement-mo...
Hotpoint SCR, WMA, WMS washing machine pcb control board ... 1200RPM 6 KG 2003 TO CURRENT LINEN), HOTPOINT - WMA58N (AQUARIUS 1400 RPM 6 ...
  1. Hotpoint Appliance Parts‎
    Adwww.hotpoint.co.uk/SpareParts‎rating for hotpoint.co.uk
    Save £5 When You Spend £35 or More! Low Cost and Next Day Delivery.
    Price Match Guarantee · Spend £35 & Save £5
  2. Hotpoint Spares - Delivered Within 24-48 Hours.‎
    Adwww.hotpoint-spares.co.uk/Shop/Spares‎Machine Spares
  3. Dishwasher Parts
  4. Cooker Spares
  5. Fridge Spares
  6. Hob Spares
  7. Replacement Circuit Board - Fried the hard drive circuit board?‎
    Adwww.onepcbsolution.com/‎hotpoint washing machine circuit board
    hotpoint washing machine control board
    washing machine pcb repairs
    hotpoint washing machine pcb problem
    washing machine circuit board replacement
    hotpoint pcb repair
    hotpoint aquarius washing machine circuit board
    circuit board for hotpoint aquarius
1 2 3 4 5 6 7 8 9 10 Next
Nov 22, 2016 | Hotpoint Washing Machines
Tip
Frigidaire Affinity Common Error Codes. (E4A, E9E, E56, E46 and more)
Hi.
This error codes apply to Frigidaire Affinity washers and dryers:
E11 - Fill time too long.
E13 - Water leak in tub, or air leak in air bell.
E14 - Reed switch.
E21 - Water not pumping out fast enough.
E23 - Drain pump relay on control board failed.
E24 - Drain pump relay on control board failed.
E31 - Pressure sensor not communicating with control board.
E35 - Pressure sensor indicates water overfill.
E41 - Control board indicates door switch is open.
E42 - Door remains locked after cycle is completed.
E43 - Control board problem
E44 - Control board problem.
E45 - Control board problem.
E46 - Control board problem.
E47 - Control board is sensing the door PTC circuit is open during spin.
E48 - Control board is sensing the door PTC circuit is closed.
E4A - Program Timeout Fault.
E52 - Bad signal from tacho generator.
E55 - Motor overheating.
E56 - High motor current.
E57 - High current on inverter.
E58 - High current on motor phase.
E59 - No tacho signal for 3 seconds.
E5A - High temperature on heat sink.
E5B - High temperature on heat sink.
E5C - High temperature on heat sink.
E5D - Communication problem.
E5E - Communication problem.
E5F - Communication problem.
E67 - Input voltage on microprocessor incorrect.
E75 - Water temperature sensor circuit (digital readout models only).
E76 - NTC temperature for the cold water valve over the limits
E95 - Communication error.
E9E -Voltage error.
EB1 - Incoming power frequency out of limits.
EB2 - incoming line voltage above 130 VAC.
EB3 - Incoming line voltage below 90 VAC.
EF1 - Clogged drain pump.
EF2 - Too much soap.
on Apr 09, 2010 | Frigidaire Affinity ATF7000ES Front Load...
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
What does F09 mean mean for a whirlpool AW0 3561 front loader?
Washing Machine Fault Cod Fault
FH No Water Inlet
FA Aquastop Failure
FP Drain Failure
F5 NTC Failure
F6 Tachometer Failure (no motor movement detected)
F7 Triac Short Circuit detection
F8 Heating Element, Open Circuit
F9 Overflow Failure
F10 Motor control unit (Thermal)
F11 Communication failure
F12 Heating Element Short Circuit
F13 Dispenser Circuit Error
F14 EEPROM Failure
F15 Motor Control Unit Error
F16 Control Failure (Control Unit)
F18 Control Failure (Control Unit)
F20 Control Failure (Control Unit)
F21 Control Failure (User Board)
F22 Control Failure (User Board)
FDL Door Lock Error
FDU Door Unlock Error
Whirlpool Washing Machine Fault Codes
So the answer is Overflow Failure
Apr 13, 2015 | Whirlpool Washing Machines
Loc error code Frigidaire frontloader
From the frigidaire site.
Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 Too much soap.
Jul 24, 2014 | Frigidaire GLTF2940ES Front Load Washer
Fan control printed circuit board
Printed Circuit Boards are the 'brain' of the boiler. They control every action and can be found in most appliances from boilers to warm air units and fires. They are often referred to as a PCB, control box, mother board, driver board, sequence board, ignition board or power board. For more info you can visit at http://dferrantielectronics.co.uk/
Contract Electronic Assembly Manufacturer
Dec 24, 2013 | Stoves Ovens
Our washer keeps stopping and flashing F11 and will not finish load
The F11 code is saying that there is a problem with the motor or motor control board, both at the bottom of the machine. Most often the problem is not there but rather in the communications between the CCU circuit board and the motor or motor control board. The CCU circuit board (inside back, top of machine, plastic case) has what's called cold solder joints where the relays (5 of them) and the spade connectors are supposed to be firmly soldered to the circuit board. Whirlpool had a quality control problem with these circuit boards but won't recall them. The cure is to remove the CCU circuit board in the plastic case (it's easier that way) then remove the circuit board and touch-up those cold solder connections I mentioned. If your not up on soldering techniques, you can remove the CCU case, with the circuit board inside, and take it along with this response, to a good appliance repair shop and they should be able to help you out. Good luck.
Feb 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What is code F-24
E11 Fill time too long. Refer to test (1).
E13 Water leak in tub or air leak in air bell. Refer to test (2).
E21 Water not pumping out fast enough. Refer to test (3).
E23 Drain pump relay on control board failed, wire off pump or pump Replace console control board, wire or
defective. pump.
E24 Drain pump relay on control board failed. Replace console control board.
E31 Pressure sensor not communicating with control board. Refer to test (4).
E35 Pressure sensor indicates water overfill. Refer to test (5).
E36 Console control board problem. Replace console control board.
E38 Air chamber clogged or pressure sensor defective. Check air chamber, rpl press. sensor.
E41 Control board thinks the door switch is open. Refer to test (6).
E43 Console control board thinks the door locking device has failed. Refer to test (7).
E44 Console control board problem. Replace console control board.
E45 Console control board problem. Replace console control board.
E46 Console control board problem. Replace console control board.
E47 Console control board thinks the door PTC circuit is open in spin. Refer to test (7).
E48 Console control board thinks the door PTC circuit is closed. Refer to test (7).
E52 Bad signal from tacho generator. Refer to test (8).
E56 High motor current. Refer to test (9).
E57 High current on inverter. Refer to test (9).
E58 High current on motor phase. Refer to test (9).
E59 No tacho signal for 3 seconds. Refer to test (10).
E5A High temperature on heat sink caused by overloading. Test first-if bad-rpl speed control brd.
E5B High temperature on heat sink. Replace speed control board.
E5C High temperature on heat sink. Replace speed control board.
E5D Communication problem. Refer to test (11).
E5E Communication problem. Refer to test (11).
E5F Communication problem. Refer to test (11).
E66 Heating element relay failure. Refer to test (14).
E67 Input voltage on microprocessor incorrect. Refer to test (15).
E68 Current leakage to ground on heater or fuse opened. Refer to test (14 & 15).
E71 Wash NTC failure. Refer to test (15).
E74 Wash temperature does not increase. Wire off NTC - rpl water valve.
E75 Water temperature sensor circuit. Refer to test (12).
E82 Console control board problem. Replace console control board.
E83 Console control board problem. Replace console control board.
E91 Comunnication error between UI board and console control board. Refer to test (16).
E93 Console control board problem. Replace console control board.
E94 Console control board problem. Replace console control board.
E95 Communication error. Replace console control board.
E97 Console control board problem. Replace console control board.
E98 Console control board problem. Replace console control board.
EB1 Incoming power frequency out of limits. Refer to test (13).
EB2 Incoming line voltage above 130 VAC. Check voltage at outlet. If < 130VAC,
replace the console control board.
EB3 Incoming line voltage below 90 VAC. Check voltage at outlet. If > 90VAC,
EBE Console control board problem. Replace console control board.
EBF Console control board problem. Replace console control board.
EF1 Clogged drain pump. Unclog the drain pump.
EF2 Too much soap. Advise customer to reduce the amount
of soap they are using.
Apr 24, 2010 | Kenmore 43142 Front Load Washer
Clicking noise in the circuit board and everything in the freezer is thawed
Hi. this will be a failed relay on that circuit board. This is called the PCB(main unit power control board). This board controls the compressor relay functions, and the compressor power current, as well. The evaporator fan, and condenser fan, receives their respective current from this power control board, also. When a circuit board of this nature begins to malfunction, it will cause the unit to not cool properly, due to limited, or no fan actions, or a failed compressor cycle. I would recommend to replace this damaged control board, asap.
Dec 04, 2009 | GE Freezers
Television turns on and off, turns up volume and changes channels
Hi
Replace all tact switches at the control panel... all switches is have bad resistance thats why your system is abnormal!
Thanks!
Feb 24, 2009 | RCA 27V520T 27" TV
WHITE-RODGERS DIV White Rodgers Furnace Fan Control Circuit Board 50A55-474 50A55-571 50A55-843 Logo
196 people viewed this question
Top WHITE-RODGERS DIV Photography Experts
Tony
Are you a WHITE-RODGERS DIV Photography Expert? Answer questions, earn points and help others
