Question about Maytag M7DH45B2A Dehumidifier
Dehumidifier not collecting water
Machine is working but not collecting water in the tank
heatman101
  • 43501 Answers
SOURCE: dehumidifier indicates that the water tank
Here is a tip that I wrote to help people with just that dehumidifier problem..
Dehumidifier Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
Posted on May 04, 2010
  • 16 Answers
SOURCE: 2 dehumidifiers in the same room set to 35%
It could be bad or is could bee full of dirt and dust. Try cleaning it with a vacuum or a soft brush
Posted on Oct 13, 2010
  • 1015 Answers
SOURCE: Should the dehumidifier be blowing air out? It is
Unless the water level sensor is not working and you have the humidity setting low enough to call the fan should be running. If not then check water level sensor or float control to make sure they are working. Make sure the float is free to move if so equipped.If not clean and free up float.I would turn control dial up all the way and see if you can hear it trying to run. Turn it up and down several times.Also if you have a volt meter check to make sure you have incoming power to control and fan motor. Before I spent the money on a new motor I would bypass control and wire straight to motor.Try to isolate problem by process of elimination instead of just replacing parts till you find the right one. I have done this to many times and ended up spending more in parts and alot more in frustration,then the unit was worth to start with. Thank you.
Posted on Apr 17, 2011
heatman101
  • 43501 Answers
SOURCE: hi, i have maytag m3dh30b2a
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Apr 23, 2011
  • 4736 Answers
SOURCE: My dehumidifier is not discharging
Skooter, the problem you're having is a result of either the drain hose being clogged or the inner tubing of the hose connection is clogged. When this happens the water is diverted into the bucket. To solve the problem do the following:
Turn the unit OFF & unplug it. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hose connection and tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reconnect the hose, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor the hose end for water flow. . Be patient, as it may take up to 10 minutes or water for water to appear.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
Hope this helped you to solve the problem & thanks for choosing FixYa.
Posted on Sep 19, 2011
The dehumidifier is on but the tank is not collecting any water.
heatman101
Sep 07, 2011 | DeLonghi DE500P Dehumidifier
My dec14 has stopped prodicing water in the tank but seems to be working normally. I have damp patches on my walls so there is moisture to collect. Why has it stopped working please?
heatman101
Aug 12, 2011 | DeLonghi Dehumidifiers
No water being collected in the tank,, just fanning
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Feb 21, 2011 | Danby DDR2509EE Dehumidifier
Unit shows green light for dehumidifying, but no water collects in tank. Dank smell in basement does not diminish
heatman101
Feb 09, 2011 | DeLonghi DE40P Dehumidifier
The water is not going into the collection tank and just leaking all over the floor
When you pull the tank out and look on top-right of the underside of the machine, (image being on top of the tank while it's sitting in the dehumidifier), can you see the nozzle properly sitting there? Imagining that the collection tank is inside of the machine, the water should be dripping directly out of that nozzle, into the tank. Also make sure that nothing is attached to that nozzle, cause the water to be redirected elsewhere.
Aug 04, 2010 | Kenmore 54501 Dehumidifier
Problem with haier hd306 dehumidifier
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Oct 02, 2009 | Haier HDN655E Dehumidifier
Our Whirlpool gold dehumidifier is leaking water. We have checked the water reservoir and it is in correctly and continues to collect water. But, water is seaping onto our floor from the dehumidifier.
Do you use a hose with your dehumidifier? Could it be leaking? I have two machines in my basement. I use hoses on both. I had to do funny stuff to make the hoses not leak on the plastic 'blown' tanks. Even the cap that originally came with the machines were leaking before I started to use the hoses.
Check for holes in the tank as well.
Sep 27, 2009 | Dehumidifiers
Maytag M7DH45B2A Dehumidifier Logo
62 people viewed this question
Top Maytag Dehumidifiers Experts
Michael Van Der...
Michael Van Der...
Bill Long
Mike Squire
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
