Question about Nordic Track NordicTrack T6.3 Treadmill
Does the console light up in blue - Nordic Track NordicTrack T6.3 Treadmill
Blue disk light on until console unplugged now games won't work
One has nothing to do with the other. It's a coincidence.
The blue light means that there is an update available from Nintendo to be installed. It could also mean that you received a message or news from Nintendo. If you don't like the blue light, you can change it in the wiiconnect24 settings.
If your Wii isn't reading games, the first thing to do is to check the disc. If it is not scratched or no discs at all are working, your drive needs to be replaced. You can find a new Wii DVD drive replacement at the following page:
Wii Replacement DVD Drive Repair Part
Jun 22, 2013 | Nintendo Wii Console
Power button light wont stay blue
it's never blue. the disc drive lights up blue when you need an update.
Jan 15, 2012 | Nintendo Wii Console
MY WII BALANCE BOARD IS CHARGED BUT THE BLUE LIGHT WONT STAY ON.
  1. Insert a Wii Balance Board compatible game disc in the Wii console.
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
click here to download repair guide if u want
Dec 15, 2010 | Nintendo Wii Fit - Balance Board + Game...
The Blue light does not turn on and my video does not wor. The System has power the Green Light turns on But the Blue light right next to it does not and I get no Video or sound.
the blue light only comes on when you insert a cd into the console and the cd has been loaded.it stays on permanently when the cd has been loaded and blinks when the cd is still loading.for the video make sure your av cable is properly connected and properly working.try testing your cable on another console or using another cable on your console.
Apr 18, 2010 | Sony Playstation 3 (PS3) Console
Wii Console will not turn off. After pressing the Power off button the console light goes from green to yellow (not red.) After about 5-10 minutes the blue light will start to cycle on and off and the game...
try turning it off on the console and not with the controller. turning it off with controller turns it yellow. press and hold the power button on console for 5 seconds it should turn red.
Jun 30, 2009 | Nintendo Wii Console
Rock band 2 for wii - accessory blue lights won't stop flashing
hold down the power button on the wii console till the light is red, the blue lights will stop blinking
Jun 10, 2009 | Nintendo Wii Console
Blue light flashing
It means that your WiFi signal is on and your console is on standbye mode. You will get updates, etc 24hrs a day automactically if you setup your console "WiFi ON", even when the system is not actively on. The blue lights flashes when it receives a update or any type of news. Change your settings and your problem will be fixed.
Mar 26, 2009 | Nintendo Wii Console
Constint blue light
It means WiiConnect24 is on and you have a message. To turn off WiiConnect24 when you are finished playing the Wii, press and hold the power button until the light truns to red.
Jan 30, 2009 | Nintendo Wii Console
Wii fit board blue light flashing, changed batteries and reset.
open panel on wii console and press configure button console to reset it
Jan 04, 2009 | Nintendo Wii Console
Blue Light stays on
If you have wi-fi working and you leave the Wii on, then thats the reason. The blue light means WiiConnect24 is on.
Dec 25, 2007 | Nintendo Wii Console
Nordic Track NordicTrack T6.3 Treadmill Logo
42 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
