Question about Pentax Optio S6 Digital Camera
Lost my installation cd for pentax optio s6
Now my computer won't recognize it when i plug the camera into the usb port. any help would be greatly appreciated!!!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Pentax Master
  • 102,366 Answers
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Aug 30, 2012
  • 3 Answers
SOURCE: pentax optio s6
perhaps mazzachris would be interested in unloading his/her E10 LCD to me?  My E10 LCD is cracked.
Posted on Nov 05, 2007
This is exactly how my problem started. Then after repeated attempts to turn it on or off the lense actually stuck in the on position. After GENTLY forcing it in the off position, it began turning on and would immediately turn back off. After reading every problem posted that had to do with the lense I figured that the lense had somehow worked it's way of the "track or gear" that moves it in and out. I don't recommend this solution unless you figure that the cost of having it repaired proffesionally would be more than to replace the camera (I am a trial and error type of repair person). On my camera, also an S6, when the lense came forward and began to retract, I GENTLY held the lense in place for just a second. I repeated this probably four or five times until it "worked itself" back into the proper position. It does make the clicking noise while doing this which made me a bit nervous but it worked. The camera actually even seems to be focusing better which leads me to believe that possibly it hadn't been quite right for a while. AGAIN... you have to decide if the cost of proffessional repair is worth it to you. I am not a pro but this worked GREAT for me. Hope it helps.
Posted on Jun 14, 2008
spotatohead
  • 95 Answers
SOURCE: NEED MANUAL FOR PENTAX OPTIO DIGITAL CAMERA S6
Since you asked so nicely, here's a link to the manual:
http://www.pentaximaging.com/files/manual/Optio%20S6%20Manual_web.pdf
Posted on Jan 06, 2009
  • 11967 Answers
SOURCE: how do I unlock the memory card?
Move the slide switch on the side of the card.
Posted on Nov 11, 2009
richard191
  • 691 Answers
SOURCE: i ahve the pentax optio s6 camera. the camera
Hello
Thank you for using FixYa for your problem
Sounds like the LCD is faulty, but there are a number of things that can cause the LCD to play up too
Always check the batteries first (check that the voltage is correct with a volt meter) but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Anything is fixable but it is more "is it cost effective"
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Dec 01, 2009
Testimonial: "thx for your quick reponse. very helpful"
Lost my cd
Hi, It seems the CD jsut has a ACD see software.
You can download it online.
lemme get you the link...
Oct 01, 2008 | Pentax Optio M20 Digital Camera
I have a pentax optio m20. I lost the installation cd. Can I install the software on line?
You don't need any special software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what said first, you can use any photo cataloging program such as Picasa.
Aug 21, 2010 | Pentax Optio M20 Digital Camera
My laptop does not recognizes my camera and have no CD to the cam
Dec 29, 2009 | Pentax Optio S6 Digital Camera
Download photos from Pentax S6 to my PC
Apr 09, 2009 | Pentax Optio S6 Digital Camera
Pentax Optio M40 is not recognized by PC
Mar 02, 2009 | Pentax Optio M40 Digital Camera
New computer does not recognize pentax 33l
Optio 33L and Vista
Plug camera into USB port using the cable supplied, and switch the camera on. Computer will display the "found new hardware" sign, and ask you to insert the disk that came with the 33L into the disk drive. That done, the drivers will be installed in the usual manner. AT LEAST, THAT'S HOW I DID IT - AND IT WORKS!
de VK5QV
Feb 18, 2008 | Pentax Optio 33L Digital Camera
Connecting OPtio S4i to PC
After formatting my PC to upgrade it I've been unable to install the USB driver software to save pictures from my Tentax OPtio S4i to my PC.
My computer isn't recognising my camera when I plug it into the USB port.
When I've tried to install the Driver using the disk I got with my camera, at the stage where it asks me to MODIFY REPAIR or REMOVE, the software I get the following showing up on display boxes:
Aug 19, 2007 | Pentax Optio S4i Digital Camera
Pentax Optio S6 Digital Camera Logo
46 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
