My Dell D630 CPU Cooling fan stops working after it boots up. What should I do?
2 Suggested Answers
Pyrhyc
  • 2028 Answers
SOURCE: CPU Cooling Fan
Here's a link for one of the cheapest I found. You can also check Ebay, you might get a better deal.
http://pcpowerzone.com/dell2100.html
Posted on Jun 25, 2008
Dell inspiron D610 fan wont turn on
New cpu heatsinks use water in sealed tubing, and can cool for a long while. Idling computer may not need more cooling.
Mar 15, 2012 | Dell Lattitude D610
My fan is not working ...my system and charger is over heating
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Feb 22, 2011 | Dell (6F858) Cooling Fan
My fan is not running
Which fan is not running? Case fan, CPU fan, PSU fan? CPU fans will cause the computer to shutdown automatically usually with in a few seconds of boot. If it isn't running at all, simply replace it. They are measured in milometers 40, 60 , 80, 90, 120 and some 200mm form factors. Just replace with the same size fan size and you should be up and running again.
Comment if you need more help.
Aug 14, 2010 | Dell (6F858) Cooling Fan
CPU Fan sounds like a jet and computer won't start
It sounds more like the hard drive, the fan has nothing to do with your computer booting up. If the hard drive is starting to go bad it will not boot up, that's what it sounds like your computer is doing. I recommend checking out the hard drive and replacing it.
Jul 02, 2010 | Dell (Fan Only) M/N AFC0912DE, DC12V,...
Why Dell Laptop cpu fan are first time power on can work but after boot process can't work?
Maybe you are interested in this:
http://www.laptopcpufan.com/dell-laptop-cpu-fans-c-1.html
Jun 15, 2010 | Dell (H5195) Laptop Cooler, CPU Fan,...
My laptop is freezing for hours at a time.then i shut it down,and retart but it also takes for ever,some times all day is this due to the freezing or is this another problem .and can it also be ovet...
you need do some thing follow:
1) clean the cpu fan and sink(around there dirdy)
2) check the cpu fan is running and stop ok when power on if running go next
3) check the cpu fan, is there any running and stop then see it run again before the laptop freezen?
4) if the fan not running again before freezen that your fan control circuit out of work on the motherboard need to repair
5) if the fan running control ok that the fan can run and stop and run again. you have to add a EXT cooling base under the laptop
hope to help you solve it
May 09, 2009 | Dell Latitude D600 Notebook
Cpu fan failure message when booting
Sad to say but this model dell uses a specific fan made for dell. Unless you want to modify your cpu cooling system you will need to contact dell for a system specific replacement part. Hope this helps.
Jan 10, 2009 | Dell Dimension C521 PC Desktop
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
