Question about Noria 7 Android 4.2 Tablet - White
My tablet won't power, only shows battey then shuts off, won't charge
Won't power on even with charger plugged in to it
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 111 Answers
When you see the battery icon, hold the power button in a few seconds longer and see if it then powers on. Good Luck.
Posted on Jun 28, 2014
My tablet shut off while still charged and will not come back on, any help?
Hi Queenfrog, The link below is a youtube video showing you how to fix your tablet, There's video's down the right side you can check out as well....CHEERS..
https://www.youtube.com/watch?v=0PAB6khykWE
How To fix any Android Phone Tablet that won turn on
Apr 21, 2016 | TabletExpress Dragon Touch 7 Black Dual...
Wont charge ,tries to come on while plugged in but shuts right back off?
Allow the charger to charge the battery with the tablet OFF over night. The tablet requires MORE power than the charger can provide - but the charger provides enough power to slow charge the battery. In the morning it should be fine - unless the battery no longer can support a charge.
May 18, 2015 | Maylong Android Tablet M-250
Trouble charging a Digland 10.1" tablet
Did the charger that you are using come with the Tablets? Many 5 volt chargers can only output a 0.5 to 1amp current, while a Tablet typically needs 2 to 2.5 amps charging current. So, if you're using a charger from some other device, then it's almost certain that it cannot provide a sufficient current for the Tablet, and the charger overloads, shuts down cools off, turns on again, overloads again, shuts down etc repeatedly - giving the exact symptom you are reporting.
Even if the charger did come with the Tablet, some of the Chinese ones are of very poor quality and cannot provide reliable service. A replacement charger rated to suit your Tablet (there should be something in the specifications that came with the Tablet listing the requirements for the charger) should solve your problem {:o)
Jan 01, 2015 | Tablets & eReaders
My nextbook 8 runs well if I leave it plugged into the charger but shuts off soon after unplugging even with a full charge.
It could be the battery is already on its end of life. Could be, your charger can't deliver enough power to work and charge the tablet. Before you start worrying, please leave the tablet on a charger over night, with everything switched off. Then remove it from the charger and start it. If you keep having the same problem, and you can't check the quality of the battery, start saving for a new tablet. Not worth paying 100 dollar for replacing the battery, if you can buy a new tablet for the same price. If you can open the tablet, check if the battery is still connected correct.
Dec 27, 2014 | Tablets & eReaders
How can I restart my tablet it has just gone black not even showing signs of charging
plug in usb cable an power up /down til it asks to recover it, maybe
be sure charger is working touch to tongue :P
Oct 19, 2014 | Tablets & eReaders
Most likely a dead battery or bad charger. Test and/or replace the battery or charger.
May 10, 2014 | Noria 7 Android 4.2 Tablet - White
Battery not charging tablet gets hot and wont turn on
The battery is dead and cannot be recharged. Replace the battery.
Mar 26, 2014 | Polaroid S7 7-in. Internet Tablet
Galaxy Samsung tab 10.1 won't turn on
you had to plug it in the charger for a while and then you hel the power button for more than a minute
if it not work hold power button and volume up for 20 sec.
Mar 22, 2013 | Tablets & eReaders
7" touch andoid tablet won't charge
It may be the charger has a loose wire. In that case a new charger would fix the problem. Mine has a problem with the charging port itself. I am fortunatly that my tablet is under warrenty they are going to replace the tablet for me.
Dec 27, 2012 | Nextbook Premium 7 Capacitive Touch...
My galaxy tablet was fine yesterday but today it will not turn on. The battery ran dead and I pugged it in and nothing, The red light does not even come on to show it is charging. I have tried both the car...
You can damage the battery but it is very rare to actually do that. What you need to do is plug it in to the wall charger and leave it alone over night. At that point it should be just fine. it will actually start to show some signs of life after a few hours but don't be tempted to do anything wih it. it will first show a charge light or something after maybe 40 minutes if it is a faster charger.
If it shows no life the next day then you can try charging again but at this point you may hae a problem that requires either a battery replacement or warrenty. The battery has a microcontroller on it and when the battey gets real low they do not behave that well and typically you get the stone dead brick behaviour. And most people do not let it charge long enough to get it working. It is possible that there are other problems but those are usually moore serious and require replacement of the unit. The battery can be replaced but requires the etire case to be disassembled.
So charge it then check your warrenty and it may need serious repairs or to be replaced. If it is out of warrenty then you need to be careful on the cost verses replaceemn
Mar 13, 2011 | Samsung Galaxy Tab Tablet PC
Noria 7 Android 4.2 Tablet - White Logo
81 people viewed this question
Top Noria Tablets & eReaders Experts
Are you a Noria Tablet and eReader Expert? Answer questions, earn points and help others
