Question about Panasonic CT-34WX54 34" TV
Ct-34wx54 no picture - Panasonic CT-34WX54 34" TV
My Panasonic CT 2521 HDB needs to be reprogramed
Reset it to its factory default, and then reune it. Refer its user manual for details.
May 07, 2012 | Panasonic CT-34WX54 34" TV
Panasonic ct-34wx54. I cant remove the closed captions from the screen. When i go to the menu and try to shut it off the on and off modes are "grayed out" and cant be highlighted. Reset with...
Try pressing the volume down button on the T.V. and the info button on the remote. Do this for at least 5 seconds and it will reset the T.V.
Mar 16, 2011 | Panasonic CT-34WX54 34" TV
I dont have a remote for my tv and it wont turn on manually the led light blinks 9 times and stops and starts again what should i do?
The blinking lights are a service code. You should first try to unplug your TV and leave it unplugged for at least 4 hours... then plug it back in again.
If the blinking light is still there and no picture, time to have the TV serviced. Good luck!
Oct 10, 2010 | Panasonic CT-34WX54 34" TV
Black box in middle of screen
enter in menu pressing the action bottom and turn off the close caption.
May 27, 2010 | Panasonic CT-34WX54 34" TV
Panasonic remote not working
The IR receiver needs to be replaced.Inside the tv.
Nov 18, 2007 | Panasonic CT-34WX54 34" TV
Green Spot On Screen
IN your statement says tv is second hand and also you tried degausser method also. The problem is permanent magnetic field affected your tv set. So the best recovery is fix one button magnet in the affected area.
Aug 08, 2007 | Panasonic CT-34WX54 34" TV
Dark area on screen
If it's a circular area you might be delaing with magnetism. Check the menu and there should be a control for geomagnetic correction and adjust accordingly.
Feb 07, 2007 | Panasonic CT-34WXD65 34" TV
TV Stuck in Demo mode
In the tv and with the set turned on press and hold the ACTION and CHANNEL UP buttons at the same time for more than 5 secons.Let Us know how it goes.
Oct 16, 2006 | Panasonic CT-34WX54 34" TV
Not receiving commands from the remote. (Panasonic Panasonic CT-34WX54 HDTV)
Sometimes remotes have a switch to select tv,vcr,or cable,amke sure the remote is in the tv mode,other than that rare but remote receiver go bad and they have to be replaced,but before you call for assistance make sure the remote is communicating with the TV.It could be still good with other devices and not with the set.
Sep 27, 2006 | Panasonic CT-34WX54 34" TV
Panasonic CT-34WX54 34" TV Logo
20 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
