Question about New Wave Audio Multipurpose Pizza-Maker Oven
Why heating element not working. thermostat not switching on
My toaster oven quit working--the led display lights up just fine but no heat. I unplugged/replugged and it worked! for awhile. Then, the same thing and the plug had no effect.
take it in to an appliance repair shop as it may be the elements or thermostat control that is faulty
get a quote as the repair may be more expensive than a replacement unit
Jun 16, 2017 | Toaster Ovens
Why is there no heat?
most likely the element is burnt out
have it tested at an appliance repair shop
Nov 16, 2015 | Toaster Ovens
Bravetti toaster oven
Not enough voltage getting to the heating elements. Look at the thermostat or the control board for the problem
Jul 28, 2017 | Toaster Ovens
My black & decker tro964 is not heating
That may sound like a stupid question, but is it plugged in?
Have you tried to plug in the toaster on a different power outlet?
If there is a ground fault switch where the toaster is plugged in (that's those outlets which have 2 buttons on the front, one labeld "Test" the other usually labeled "Reset") unplug the toaster and push the "Reset" button and try the toaster again. To test, if the power outlet, were the toaster is usually plugged in, is working, try a hair dryer or any other device on that outlet.
Its most likely cheaper to replace the whole toaster than to replace the heating elements, for about 40 $ since that's the price of your toaster on some websites.
Jan 06, 2014 | Black & Decker TRO964 Toaster Oven
Unit power on light is illuminated but no heat from heating element,
The thermostat may have failed. It could be adjustable mechanically but not electrically.
Nov 06, 2013 | Anvil SAA8003 Stainless Steel 3000 Watts...
Euro pro to241r
follow this steps and fix it. God bless you
If the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical panel and test the electrical cord.
If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse.
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostat .
Location of the typical toaster oven's thermal fuse.
If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements
Oct 10, 2013 | Toaster Ovens
Heating units bottom stopped working. Then the top heating bars stopped working. It's a radiant oven.
it is several prosibilites for your problem:
1) the wire of the oven is damaged;
2) the thermostat is decalibrated or damaged;
3) one or more heating element is intrerupted or burned.
solution's:
1) check the wire an replace or repair where is posible whit similar heat resistant wire;
2) replace the thermostat whit similar one;
3) replace the heating element
Feb 21, 2010 | Oster 6239 Toaster Oven with Convection...
Russell Hobbs Toaster has just stopped working
get your volt ohm meter out unplug it and disassemble it check your heating elements if there is no resistance the elements are bad. ONLY if you are comfortable with ac voltage!!! turn your meter to check ac voltage VERY CAREFULLY make sure nothing is shorted plug toaster in press toast button down. this should send voltage through thermostat to the coils . if you measure voltage across toaster switch when it is depressed the switch is bad. check your thermostat same for it if there is voltage across it it is open (bad).
Jan 12, 2010 | Toaster Ovens
Krups Toaster Oven elements stopped heating up
this is all to common . what thought happend did happen . the control board went bad and the elements where stuck on . inside there is a thermal fuse ,it blew out and saved you from haveing a fire but now the oven is dead . if you replaced the fuse it would just do it again and the board cannot be bought so your out of luck . on your next oven stay away from electronic controls . i am shocked you got 3 years out if it ,most go bad mutch sooner
Feb 26, 2009 | Krups FBC1 1600 Watts Toaster Oven with...
New Wave Audio Multipurpose Pizza-Maker Oven Logo
24 people viewed this question
Top New Wave Audio Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a New Wave Audio Toaster Oven Expert? Answer questions, earn points and help others
