Question about Health & Beauty
Where can I find a glass cooktop part no.74007939
1960 ge cooktop element replacement
Your are not quite specific about what kind of a cooktoop ypu want to replace:
DIY How To Replace Gas Cooktop
Whirlpool Cooktop Broken Glass Replacement Model RCC3024
ge electric glass cooktop board glass replacement
Cooktop Main Top Replacement GE Electric Cooktop Repair Part WB62X10047
You can search for more using these terms with COOGLE
Youtube Replace GE cooktop
Sep 24, 2015 | GE Cooktops
Glass cooktop cracked
Glass cooktops can be removed/replaced with the aid of two small screwdrivers. Gently go around the outer rim using the two screwdrivers like tyre levers don't due too much pressure and it will generally lift quite easily.
Mar 23, 2014 | Samsung NE595R0ABSR/AC 30-in Smooth...
Glass top is scratched and discolored...can you replace just the glass top? Susan
GLASS MAINTOP ASSY
Part Number PS253905
price around $812.92
Replaced main glass cooking surface on cooktop
First, shut of the breaker to the cooktop.
Then removed two screws to release brackets holding cooktop down. Then lifted the cooktop out of the recess in the counter top and removed the screws around the outside of the glass top. Removed the old, cracked top, by unplugging from the motherboard.
Turned the new cooktop upside down on table and placed weather stripping around the entire underside outside edge (to keep spills from going under the cooktop and cushion the cooktop from the counter top.
Then plugged the new cooktop into the motherboard, replaced screws around outside edge, lowered the cooktop into the recess in the counter, and reinserted the two screws into the hold-down brackets.
Turned the breaker back on.
Note: Just need Screw drivers and 40 minutes of your time.
Feb 03, 2011 | GE 36 in. Profile JP968 Electric Cooktop
How to clean glass cooktop maytag electric Model
Hello. Maytag has a special cleaning cream just for their glass cooktop. You can get it whereever the stoves are sold or at this link http://www.buzzillions.com/reviews/maytag-cooktop-cleaning-creme-smooth-top-ranges-reviews
Joe
May 07, 2010 | Maytag MEC7536WS Cooktop
I was cooking popcorn on my glass cooktop and the pan appears to have scratched to surface.
You may have melted the bottom of the pan you were using into the glass. Copper bottom and alum pans sholdnot be used at high temps on a glass top. (never use porclin or glass pots)High temps can etch(mark or discolor) the glass.
Oct 30, 2009 | KitchenAid 30 in. KECC506R Electric...
Burner out in whirpool black glass cooktop
take the whole cooktop out there should be screws around the base you take them out, seperate the bottom from the glass you should be able to get to the element to check if it is bad by ohming it out
May 01, 2009 | Cooktops
I HAVE A WHIRLPOOL ELECTRIC COOKTOP WITH A LARGE CRACK CAN I REPLACE JUST THE SURFACE IF SO WHERE CAN I GET ONE?
The glass can be replaced. Go to any appliance parts website and look up the model number for your cooktop. They should have a parts directory and then search for your cooktop glass. I warn you though - the glass is almost as expensive as a new unit!!
Mar 13, 2009 | Whirlpool GJC3034 Electric Cooktop
Staining of kitchenaid glass top digital control unit
Have you tried using a razor blade scraper. Also I have found Ceramabrite cooktop cleaner to be a very good product. There is also a less abrasive scouring pad available specifically for glass cooktops.
Jan 02, 2009 | KitchenAid 30 in. KECC506R Electric...
Jenn-Aire Cooktop Glass
You can order the replacement glass for about $225 from companies like Repairclinic.com or appliancepartspros.com
Part Number: AP4095442 made by WHIRLPOOL, black
Part Number: AP4096135 made by WHIRLPOOL, white
Dec 22, 2008 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Glass top
The cooktop will need to be removed from the counter. Turn it upside down and remove the screws. The biggest problem will be removing the cooktop from the counter. Sometimes it is not worth fixing as the part could cost around $400. NEVER use a cracked top as it could suddenly explode. This is tempered glass and very unstable if cracked or chipped.
Jul 10, 2008 | GE 30 in. Profile JP350 Electric Cooktop
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
