Question about Reliable DreamStitcher 787 Portable 2/3/4 Thread Serging Machine
Where to oil reliable dreamstitcher - Reliable DreamStitcher 787 Portable 2/3/4 Thread Serging Machine
Tip
Antique Clock Oiling Tips
CLOCK OILING TIPS
* NOTE: Many Master Clock Smiths and Hobbyists used many different oils and as many different techniques.
* It is only good sense to use only the best in quality when selecting clock oils and grease. A number of fine oils are made especially for clocks. The oil used should stay in place and not evaporate easily and have no tendency to gum or get sticky as it ages. Most clock oils meet these standards. [CAUTION: Never consider using non-clock lubricants, as they tend to not really work well in clocks. Some are too light and cause unnecessary bushings wear, while others are too thick or can evaporate, over time will gum up and stop the clock prematurely.]
Oiling Procedures
-Main-springs are oiled after cleaning and before they are recoiled.
-Teeth and pinions are never oiled.
-Normally, the dial train of gears, hour wheel, minute wheel and minute wheel post are not oiled. However, oil is used between the center shaft and cannon pinion where slip friction is present in setting the hands.
-All points of friction such as train wheel pivots to bushings are oiled. Verge faces are oiled directly.
-Oil is always used sparingly and should never run all over the plates.
Hope this tip helps.
R/
David
http://antiqueclock.clockstop.com/
on Jan 22, 2010 | Vacuums
W w w google
Yes you can order pads and spot cleaners on the internet, just type in reliable H20 pads and spot cleaners.
Aug 15, 2014 | Reliable H20 Steam Mop
Where is oil presure sendind unit on 2000 blazer V-6
Oil sending unit is under intake manifold, just behind the oil filter on the passenger side (difficult to see-use flashlight). Best option to change : Get everything to do an oil change, removal of the filter makes easier access..
Apr 22, 2013 | GMC W3500 Pressure unit. oil....
My steam mop wont heat up
Don't have one I need to get it replaced
Oct 13, 2012 | Reliable H20 Steam Mop
How much oil would i ad to a pint of gas at a 50 to1 ratio
A pint is 16 ounces, add 1/3 ounce of oil for a 48:1 mixture.
Gary
Aug 30, 2011 | Vacuums
I got a FREE old but lightly used Oreck XL 8300 xtended life commercial. 120V 60 Hz. After cleaning brush etc. is there anywhere to add oil to the electric motor? Is it necessary? Is this machine worth the...
I don't believe that the bearings have a place to oil them. As for the machine being worth the time, I think yes. Orecks are used extensively by hotels, and are noted for their reliability, longevity and weight.
Best regards, --W/D--
Feb 19, 2011 | Oreck Vacuums
My wife has a 910 Babylock Surger and I'd like to clean and oil it, where do I put a drop of machine oil?
Remove the covers as far as you are able to and oil every point where two or more pieces move against each other. It's frankly better to over-oil a sewing machine than to let it starve for lubrication.
If you're using the machine a lot you should oil it daily. If you're not using it that much you should oil it each time you use it. Tri-flow brand oil is very good stuff, if a little spendy- a firearms shop should have it. Any 10W30 synthetic motor oil will also be excellent, if nothing else 3in1 oil is good.
lp
Feb 06, 2011 | Vacuums
Aquamate basin pump does not work. Used it 3 times, stored it for a year and pump does not work. Looks like a reliability issue. Is this product defective for everybody? I saw an ebay listing for the...
Hmmm............ looks like the impeller is already stuck from a year w/o using it!
I suggest if u could open it and spray some penetrating oil on the bushing of the pump motror and the impeller, force the motor to turn manually to set it's rotor FREE. or just POUR some penetrating( I usually use BRAKE FLUiD ) oil in the pump and let it seat for a couple of days.
If don't have a knowhow in opening and repairing such machine, u coud bring it to ur tecnician or service center to fix that up!
Hope that helps u out!
Dec 02, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Out of Warranty
NuTone is a very reliable brandname. If you are the original owner and can document that you are, they will more than likely be willing to assist you. I cannot promise that they will give you a "free" replacement; but I can say that it is my experience that they will offer some type of quality help or guidance. ~ TTURAMBAR
Aug 19, 2008 | Broan-NuTone VX475 Bagged Central System...
Reliable DreamStitcher 787 Portable 2/3/4 Thread Serging Machine Logo
14 people viewed this question
Top Reliable Vacuums Experts
JoeVacs
Are you a Reliable Vacuum Expert? Answer questions, earn points and help others
