Question about Juki DDL-8700
No oil movement in bubble on top of machine
My machine has oil to the HIGH line but there is no oil coming up to the clear bubble on the top of the machine... Is this okay? I'm afraid to use it..
  • 64 Answers
Ead the needle raise the presser ft and stomp the power foot down, now check the bubble when the machine is running full tilt. when the machine is running slow you will not see the oil flow. also ck the screen on the oil uptake under machine for dirt.
Posted on Jul 21, 2014
2 Suggested Answers
SOURCE: I do not see any
hi there
1 - are you sure you are used same oil for industerial sewing machine? this oil is light and clear.
2 - if your machine used not new you can chack oil pumb and all tube for oil mybe some dust insaid it try to clean by air gun.
3- the last resone there is gear insid oil pumb if damged change oil pumb.
with my best regards
ashraf abozid
aabozid@hotmail.com
Posted on Oct 08, 2010
Stitches too small
TIP: A general rule of thumb is that if the stitch looks bad on the top it is the bottom tension.
If the stitch looks bad on the bottom it is the upper tension. The upper and lower threads play
tug of war with each other.
Tension
You need correct tension on the top and bottom threads, but you must also have correct tension on
the quilt held between the rails. You should have a small amount of "sag" in your fabric. This allows
enough movement of your quilt layers for the needle to penetrate and make good stitches.
Before you start making adjustments to your machine ask yourself, "What changed?" If your machine
was stitching great and all of a sudden it has loopies on the back or puckers, "What changed?" Did
you just change the bobbin? Did you just lift the take up rail? Did you lower the take up rail after
finishing your last quilt? Did you recently change the needle? Did you just roll the quilt?
If the take up rail with the quilted portion of your quilt is too high, it will result in poor stitch quality. You
need a finger tip space between the quilt and the machine bed. Higher will result in poor stitch
quality, too low and the quilt will create a drag on your machine's movement.
Look at your bobbin, a sloppy wound bobbin will not create a good stitch. Make sure that the threads
on the bobbin are snug and evenly wound. Check to see if there is a piece of lint in the bobbin case
Dec 19, 2016 | Sewing Machines
How do you clean an old 1951 singer sewing machine
Using sewing machine oil only, put a little drop on every point that there is friction, at each end of each shaft. Look at the top, the end, and underneath. Turn the hand wheel and watch for movement. The less movement there is, the more that point will need oil. Also, the hook race (where the piece the bobbin case goes).
Aug 11, 2014 | Singer Sewing Machines
How to oil Highlead sewing machine
which model do you have? tip the head back & fill the sump to the high line on most flats. overlocks you need to unscrew the top cap & fill untill the sight glass is full to the top line. some require you to oil daily check the manual
Jul 12, 2014 | Sewing Machines
Why is there no oil movement in bubble on top of machine?
use lilly white oil and oil flow will not show unless the machine has lots of rpms. tilt machine away from you and ck to see if the oil take up screen is clogged with thread debris. use should always oil hook with lits spray oil. u can take the two rubber knobs off the left side of machine and spray a little in each. oil will not drip out because u have a gasket at bottom.
May 10, 2014 | Juki DDL-8700
I have a Consew CN2230R , DO I NEED TO ADD OIL TO TOP OF MACHINE WHERE THE BUBBLE IS?
Here's some info for you, looks like your machine should have an oil pan and be self oiling.
http://consew.marginspluslive.com/images/products/parts%20books/CN2230R.pdf
Oct 01, 2012 | Consew CN2230R Sewing Machine
I don' really havea problem but I am a hands-on learner. I have just purchased a Juki-8700 industrial machine for my dog collar business. I read somewhere that you run the machine for 5 min before...
hi there,
yes you are right, during you work with your machine you can see oil comming to clear bubble on the top. but this way when you use machine for firist time or you don't use machine for long time.
if need more information please email me.
best regards
ashraf abozid
aabozid@hotmail.com
CAIRO - EGYPT
Jul 20, 2011 | Juki DDL-8700
If my machine is not cutting right do I need to replace both blades
not necesarily, can you see a knick in either of the two blades? use a magnifying glass and see if you can see any damage first.
Then try changing the fixed bottom blade only first, you may have got a replacment top blade in your accessory bag new with the machine.
The blades themselves are very high grade steel just like scissor blade so should last for quite a long time, provided they don't come into contact with a pin.
You can buy the bottom blade for your machine here http://www.sewingpartsonline.com/lower-knife-babylock-60544.aspx along with the top blade and other spares.
Also, remember to clean the blades of lint regularly and give them a wipe with a cloth moistened with a little clear sewing machine oil from time to time.
Jul 06, 2011 | Simplicity Serge Pro SW432 Mechanical...
I do not see any oil in the bubble on top and the machine is starting to sound weird. I just changed the oil and am afraid to use it because I might do damage to the machine.
hi there
ashraf abozid
aabozid@hotmail.com
Oct 07, 2010 | Juki DDL-8700
My manual for the White sewing machine Model 1780
There should be two screws on the top of the machine. Those need to come off first. Most
Whites have a top that comes off in that way. On the hand wheel side there is usually one or two screws to remove that metal piece (below the hand wheel). Then the base should come off just by removing those screws on the bottom. As far as oiling, lubricate any point where two pieces come together and there is movement except the belt area.
Mar 17, 2010 | White Sewing 1780 Sewing Machine
No movement of oil in top eye
Welcome to FixYa. Without knowing when you oiled the machine, I'm not sure whether you have a problem. Self-oiling machines wick the oil from the will in a controlled manner, so the oil should not need to be replaced often. Your manual should tell you how often the machine needs oil. In case you don't have a manual, I'm including a link to a site from which you can purchase one:
http://www.sewingmanuals.net/juki-model-ddl5554-sewing-machine-ma.html
I hope this helps. If you can take a moment to rate my answer, you will help me become a better expert.
Good luck, and feel free to comment if you have additional questions or would like a referral to another expert. Ginny
Jan 31, 2009 | Sewing Machines
Juki DDL-8700 Logo
88 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
SewTechWayne
SewTechWayne
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
