Question about Worx Sweeper/Blower 20V Li-Ion Model WG545
Why does it shuts of after a minute but will continue after a minute for another minute. It's not the battery
On my 2007 C6 Corvette I shut it off and I can still hear a little motor sound turns on and off about every two minutes
Are the keys nearby? Corvettes computer continues to run if keyfob is within 20 feet. This leads to dead battery syndrome. The computer is designed to run for a couple minutes until your key fob is out of sitance then the car shuts down.
Nov 06, 2016 | Cars & Trucks
Shuts off after five minutes of recording
Usually in the main menu /programming
Aug 20, 2015 | Video Cameras
After working o.k. for 30 mins my sony pcg-3e2l computer shuts completely down.
1. Check the battery is charging.
2. check it works continuously when using the mains adaptor.
3. Check the power settings to make sue it does not hibernate or shut down after 30 minutes of non-use.
Sep 30, 2014 | Computers & Internet
Fan relay switch
The fan relay could be defective, especially if the fan continues to run after shutdown and drains the battery.
Nov 14, 2013 | 2007 Chrysler PT Cruiser Touring Hatchback
2001 dodge caravan alarm will not shut off
You probably need to disarm the system, try locking and unlocking the drivers door with the key if you don't have the remote.
Aug 08, 2012 | 2001 Dodge Caravan
The car runs great but when I shut off the engine the fan continues to run. How can I get it to shut off?
The fan is controlled by a thermostat, it will (should) shut off by itself after a few minutes, after the engine has cooled down a bit.
If it continues to run after about ten or fifteen minutes (i.e., it does not shut off at all, and will run the battery down if you leave it overnight), then most likely the fan relay is sticking on, and should be replaced. Less likely is that the fan thermostat is bad.
But if it turns off by itself after about five minutes, this is normal and desirable, it gets some of the excess heat out of the engine.
Aug 23, 2010 | Jeep Cherokee Cars & Trucks
The fan wont turn off on my 1997 catera
wait 10 minutes after you shut the car off - then remove the negative side of the battery - wait 30 minutes then reinstall and run the car 30 minutes.
If your cooling fluid is full and other cooling systems are in place and working - you should be fine.
The fan on your cooling system is made to continue to run once the engine is shut down if it is running a little [ or a lot] hot. So don't panic if it runs 5 minutes after you shut the car off.
Apr 01, 2010 | 1997 Cadillac Catera
My universal battery do not have enough back up.
Cpcute,
Yes, initial charge should be for 24 hours before initial use (in general).
The UPS is an Uninterrupted Power Supply and is intended to Power your system in the case of a Main Power Failure long enough for you to Save/Backup your work and shut down your system safely so you don't lose data. Five minutes should be plenty of time to do this? It's not intended for you to continue using your system throughout the Power Outage. The UPS will/should let you know when the Battery needs to be replace, so when it does let you know, replace it at your earliest convenience and it should continue to function as it should.
Good luck.
Mar 20, 2009 | Computers & Internet
Electric fans runs after car is shut off, drains battery
Having the fan run on for a bit after the engine has stopped is not abnormal in itself, but 20 minutes sounds excessive.
If the fan does eventually shut off, I'd consider changing the thermoswitch (this is a sensor screwed into the radiator somewhere near the bottom, with a pair of wires connected to it - to change it, you'll need to drain the cooling system).
If the fan stays on continuously until the battery is completely flat, see what happens when you unplug the wires from the thermoswitch. If this stops the fan, you need to replace the thermoswitch. If it doesn't, then you need to examine the wiring associated with the switch and the fan, looking for damaged insulation.
A.
Nov 28, 2008 | 1999 Volkswagen Passat
W600i-freezing/hard to turn on
This Worked for me!
Goto Sony Ericson website and download the update service.
Run it and follow the instructions. If the system says you already have the latest software click on continue anyway. Let the phone update and you will have your phone back.. Worked for me about 10 minutes ago.
-Chad
Jan 12, 2008 | Sony Ericsson W600i Cellular Phone
Worx Sweeper/Blower 20V Li-Ion Model WG545 Logo
Top Worx Garden Experts
Tim Whalen
ray gallant
Wayne McNeil
Are you a Worx Garden Expert? Answer questions, earn points and help others
