What does error 44 mean
Error 15 and HE 44 on the controller mean
2 Suggested Answers
  • 11 Answers
SOURCE: computer shows no display
did you try installing newest drivers from intel/gigabyte website? what you described looks to me as a overheating problem. try running the game with case open. are you running on the integrated GMA graphics or PCI-E graphics card(like geforce, radeon)?
Posted on Jul 02, 2009
What does the code do1cir mean
Never seen one like that. Here is the code listing:
Diagnostic Trouble Codes (DTC)
DTC FAULT CONDITIONFLOW CHART
11Throttle Position Sensor
12 Barometric Pressure Sensor
14 Engine Temperature Sensor
15 Intake Air Temperature Sensor
16Battery Positive Voltage
23 Front Injector
24 Front Ignition Coil
25 Rear Ignition Coil
32 Rear Injector
33 Fuel Pump Relay
35 Tachometer (Except FLHR/C-I)
41 Crankshaft Position Sensor
42 Camshaft Position Sensor
44 Bank Angle Sensor
52, 53, 54, 55 Various (all require ECM replacement)
56Crank position sensor/cam position sensor signal error
Sep 30, 2014 | 2000 Harley Davidson FLTR-FLTRI Road Glide
What does error codes 40 and 41 mean on my 1999 mitsubishi eclispe mean
11 Oxygen sensor fault.
12 Airflow sensor fault.
13 Intake air temp sensor fault.
14 Throttle position sensor (TPS) fault.
15 Idle speed control (ISC) motor position sensor fault.
21 Coolant temp sensor fault.
22 Crankshaft position (CKP) sesnor fault.
23 Camshaft position (CMP) sensor fault.
24 Vehicle speed sensor (VSS) fault.
25 Barometric (BARO) pressure sensor fault.
31 Knock sensor fault.
32 MAP sensor faulty.
36 Ignition timing adjustment signal fault.
39 Oxygen (O2) sensor fault.
41 Injector(s) fault
42 Fuel pump fault.
43 EGR fault.
44 Ignition coil (cylinders #1 & #4) fault.
52 Ignition coil (cylinders #2 & #5) fault.
53 Ignition coil (cylinders #3 & #6) fault.
55 Idle air control (IAC) valve position sensor fault.
59 Rear Oxygen (O2) sesnor fault.
61 Transaxle control module torque reduction signal fault.
62 Variable Induction control (VIC) valve position sensor fault.
71 Traction control (TC) vacuum valve solenoid fault.
72 Traction Control (TC) vent valve solenoid fault.
Sep 26, 2014 | 1999 Mitsubishi Eclipse
IBM TS3200 Code 9F 08
The manual is online with IBM.
Chapter 8 explains the error codes and 9F (mean Error code) means Rotation range out of specification 08 9sub error code) means error during rotation initialisation, get range failed.
Then the manual says: "Isolating a library controller card versus accessor enclosure problem" on page 7-11
But I guess you better look it up yourself. If you don't have any parts, you have to contact IBM.
Look yourself? start in chapter 8, page 225 of the manual under this link.
http://publibfp.dhe.ibm.com/epubs/pdf/a320545c.pdf
Feb 16, 2014 | IBM System Storage TS3200 Tape Library...
We have an error meassge 44 when faxing using the Panasonic Laser KX-FL541 to someone else. Can you please tell us what this means? Thank you so much,.
COMMUNICATION ERROR
(Code: 43, 44)
* A line problem occurred. Connect the
telephone line cord to a different jack and try
again.
* An overseas transmission error occurred. Try
using the overseas mode (feature #23, page
47).
here is the pdf file(manuel)
http://service.us.panasonic.com/OPERMANPDF/KXFL541.PDF
Mar 22, 2011 | Panasonic KX-FL541 Plain Paper Laser Fax
I have a C956 treadmill. I am getting error code 44, can you tell me what that means?
Precor Error 44, Un-commanded Lift Motion Probable Cause 1. Intermittent or bad connection in the lift position sensor(potentiometer).
2. Lift position sensor (potentiometer) is bad.
3. Lower PCA is bad.
Corrective Action
  1. Bad or intermittent connection of the lift position sensor (potentiometer) is the most common cause of the error 44. Inspect all wiring and connections related to the lift position sensor (potentiometer). Repair or replace wiring connections as necessary.
  2. Monitor the lift position number displayed while operating the lift in diagnostics mode. If the reading makes large changes or is erratic, the lift position sensor (potentiometer) is likely bad. Replace the lift position sensor (potentiometer) or lift motor if the lift position sensor (potentiometer) is internal to the lift motor.
  3. If the lift moves without any command entered either manually or through a program, replace the lower PCA.
Precor Error Code 44
Jan 04, 2011 | Precor C956 Treadmill with Cardio Theater...
What does this error mean Line: 44 Char: 8862 Error: Handler already exists Code: 0
Char: 8862
Code: 0
Dec 07, 2009 | Facebook Social Network
Computer shows no display
Jul 02, 2009 | Gigabyte Computers & Internet
Error code F2-37
This is a drum process control error. There is a small patch on the drum that is read by the control sensor every time the drum rotates.
go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" and then enter 44 and start then 2 and start - this will run the process control gain adjustment. You can also clear the error by running sim 14. If the error continues after both of these then it could mean a bad drum/patch or a bad/dirty sensor. They may need to be replaced. pull the drum unit out and check the condition of the drum.
Apr 02, 2009 | Sharp Office Equipment & Supplies
Truck wont start
Is it getting fuel?
is it getting spark?
as for the code.........here is the code list for gm vehicles
Code: Meaning:
12
No Distributor pulses
13
Oxygen sensor
14
Coolant Temp sensor circuit
15
21
22
23
Manifold Air temperature sensor
24
VSS (Vehicle Speed sensor)
25
32
EGR system
33
MAP sensor or MAF sensor depending on engine
34
35
Idle Air Control Valve
36
MAF Burn-off circuit
41
No Distributor pulses, cylinder select error
42
Electronic Spark Timing or Bypass fault
43
Electronic Spark Control fault
44
Lean exhaust
45
Rich exhaust
46
VATS system fault
51
PROM fault
52
CALPAK fault
53
System over-voltage
54
Fuel pump circuit
55
ECM fault
61
Oxygen sensor fault (degraded sensor)
Jul 17, 2008 | 1990 GMC Sierra
Heating & Cooling Logo
13 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
