Question about Logitech Cordless Mouse
Tracking light on my mouse keeps blinking - Logitech Cordless Mouse
The red light on my mouse keeps on blinking
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
Oct 18, 2014 | Computers & Internet
Fan noise and blinking blue power light
green=power in motherboard.
blue=stand by.
yellow=memory powerd
Jun 13, 2013 | Gateway GT5622 PC Desktop
When i reboot my Zmodo dvr I Can't get menu to come up or mouse to work HDD light keeps flashing,blinking hdd light,HDD indicator light
I had the same problem. Did their online tech support and Patty told me to hold down the "rewind" button on the DVR for 20 secs. You should now be able to right click your mouse to access the on screen menu. You will now want to go under system, and a/v setup and change the device to VGA instead of Vout. Now you can reboot and not have to go thru holding down the buttons anymore. Worked for me.
Oct 02, 2012 | ECHO1USA Zmodo 4 Ch Complete Dvr Kit -...
What does the power light indicate? At first it comes on and then goes off.
Hello, it's not a power light! It's actually the light that keeps track of where and when the mouse is moved and is in place of that rubber ball on the traditional mouse.Regards,nicam49
Nov 04, 2011 | Logitech Cordless Mouse
Mouse does not track, in cradle, red light blinks rapid - Solution?
If it is a battery powered mouse, the battery(ies) may be depleted. Try putting in fresh batteries.
Sep 22, 2011 | Logitech Cordless Mouse
Changed battery correctly but the on/off green light keeps blinki
you have to hit the button on the wireless base adapter as well as the one on the mouse its self
good luck and pls rate this post
Mar 23, 2010 | Logitech Wireless Access Duo Optical...
What are the Pros & Cons between a ''Optical Wireless Mouse'' and a ''Laser Wireless Mouse''
The difference between a regular optical mouse and a laser mouse is the light used to track movement. A regular optical mouse uses an LED light in the optical engine, while a laser mouse uses a laser to track movement. The more dots per inch (dpi) a mouse can track, the more sensitive and accurate it is. A typical optical mouse tracks between 400dpi and 800dpi, while laser mice track more than 2,000dpi. Neither is really better; it all depends on your needs and preferences. Unless you're a gamer or a graphic artist with a need for precise movement, you'll probably find a 2,000dpi laser mouse too sensitive. Many gaming mice, however, allow you to switch sensitivity levels so that you have precision when you need it but can revert to 400dpi or 800dpi for regular mousing. Besides their tracking speeds, laser mice work on nearly every surface, whereas optical mice may experience trouble tracking on black or shiny surfaces.
Nov 27, 2009 | Computers & Internet
Mouse light keeps blinking.
You need to make sure that the mouse is near the receiver, or that the reciever didn't fall down or got moved too far away from the PC/desk or the mouse itself. Furthermore, check to make sure that the batteries you inserted were new or fully charged batteries.
Mar 22, 2009 | Logitech 9311570403 Mouse
Bluetooth mouse VGP-BMS33
Turn the mouse off. While holding down the connect button, turn it on. Keep holding the connect button untill the green light starts to blink. Now try searching for the mouse.
Sep 06, 2008 | Sony VAIO VGP-BMS33/B
Red light
If you're talking about the red light on the bottom of the mouse, it is needed for the mouse to track its movement. When the mouse is not being used, this red light blinks only once per second or so to save power, but once it sees movement, it will come back on.
Aug 17, 2007 | Logitech RX600 Mouse
Logitech Cordless Mouse Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
