Question about Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor
Craftmans mover blade keeps hitting ground - Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor
    Problem Solver:
  • 8 Answers
Is the deck too low or one side lower than the other? Level the deck side to side, front should be a little lower than back (about 1/4 inch). check tires for correct air pressure. Make sure blades are balanced.
Posted on May 10, 2014
LT2000 craftman mower bolt and nut that tightens blades keep coming loose
Get some red lock tight and put it on the spindle shaft threads. Sounds like the threads are worn down and just won't hold the spindle nut tight any longer.
Jul 02, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hit a rock and shut mower off now every time I engage the blades it shits the mower down
look for a fock stuck between the mover and blades under the mower. pull the plug off before trying this. turning the blade to release something can start the mower with your hands in there.
Apr 23, 2014 | Garden
My blade keeps coming loose after hitting a rock on lawn mover
is the bolt stripped so it wont tighten?
Is the threaded hole on the Crankshaft of the mower cracked
Jul 26, 2013 | Mtd 22" Yard Machine Push Mower
Mower shuts off when blades are engaged
Remove the deck and check the blades and spindles. I suspect your issue is electrical and not mechanical though.
Sep 24, 2012 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Why would the carbuertor on my craftman mover be leaking between carb and filter houseing
My first guess would be a gasket - you may want to repost this in the lawnmower section.
Sep 23, 2012 | Cars & Trucks
Oil leak at the crank, I saw a little crack on it
it will cost a little bit but what I would do is find a uses part and new gasket,Did some one hit something because they dont crack much, and I hope the cranks is not bent,I hope this helps you?
Dec 13, 2009 | Cars & Trucks
Hi i have a craftman bench 10 inch bandsaw that has blade drif
The problem could be one of two things. The tires could be worn or glazed with rosin. Try cleaning the tires with mineral spirits to remove the build-up. The other possibility is that the pulleys are out of alignment. To check this, put a straight edge across the face of the lower pulley and see if squares with the upper pulley, if it doesn't, loosen the set screw on the upper pulley and adjust accordingly
Dec 08, 2009 | Craftsman Saws
Lawn mover will not start, was flipped over
The clicking noise may be the blade hitting the side of the mower or it was not put on properly. It needs a balance to the aluminum flywheel on top of the engine. The blade adapter and blade provide this balance for the engine to run.
Good Day.
Oct 07, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Craftman,36cc, 18" Gas Power Saw Blade
Go to a home improvement store and buy a new chain, they are cheap!
Jul 29, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Craftsman 42 in. Precision Cut Plus 24hp Lawn Tractor Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
