Question about Uniden BCD-996T Bearcat 6000 Channel Mobile Trunking Digital Scanner
Hold button not working
Hold button wont hold channel
    Genius:
  • Uniden Master
  • 1,795 Answers
Try a little electronics cleaning spray.That should help.
Posted on Aug 13, 2014
Samsung UN55B8500 wont stop channel scanning and wont respond to any other commands
Either a stuck (they can lock internally and cause this) channel button switch or a micro issue.
You would have to disable (channel up or down depending on which way it is scanning) to know if the switch is bad.
You can try at turn on to hold the menu button to see if it stops--but not likely.
What happens here is if the switch is bad it will act like someone is pushing it---all other commands including the remote will not function.
Both the remote and the keyboard go to the same place inside the set the microprocessor.
Let me know if you have questions.
Mar 20, 2012 | Samsung UN55B8500 TV
Sharp LC-37sh20u green power light blinking and wont come back on
unplug it and hold the the volume down and channel up button for 20 seconds after that plug it back it in while still holding the buttons
Sep 24, 2011 | Sharp LC37SH20U 37 in. LCD Television
I started useing my hdmi cable now it wont work and now my other normal cable dose not work can any one help me
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options. Press 'reset system' option 1.
Be sure to have the av cables or component cables plugged in and your tv set to the right channel.
Jan 20, 2011 | Sony Playstation 3 (PS3) Console
I have a 32 inch Haier TV and my comcast cable remote wont work with it. I need to know how to get my tv to sync with my cable remote.
there is an auto search method....some remotes you can hold the tv button down and then the select button simultanteously for a few seconds to make the light turn red and then proceed with codes, when you get the right code you press the select button again, the light blinks and you are done..... well with out a code its the luck of the draw..... the auto search method is similar to programming the code in....hold the tv button and the select button for a couple seconds until the tv button lights up, but instead of a code.....press the channel up button(that represents the first autosearch code), continue until the tv turns itself off and then press the select button to lock it into the remote...........if you go past the trigger point you can channel down to backtrack.... otherwise drop it in the toilet until it wont work, call the cable company and have them send out a tech with anew remote. they cant charge you for their equipment not working correctly.
trust me, i am a supervisor at a major cable company.
Jan 17, 2010 | Haier HTF20R21 20" TV
Menu keeps flashing remote control wont work, cant change channel or volume.when i hold down channel up andmess with remote sometimes it changes channel. channel down button is only one that doesnt change...
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
Nov 29, 2009 | Insignia IS-LCDTV32 32 in. Television
Wont change channels
Melissa,
I am sorry to hear that you are having remote issues. Let's start with the simpleist things first. If you have a dual tuner ensure you have the right remote for the room you are in and then ensure you have the remote in SAT mode by pressing the top left SAT button. If this fails to operate the receiver and you have a menu button on the receiver press it twice. If your receiver does not have this button press the power off button and hold the channel up/down button at the same time. Releaase the power off button while holding the channel up/down button. You should be brought to the system info screen. Check the remote address for the receiver location you are at. Now press and hold the SAT button until all buttons on top light up. Now key in the two digit remote address number from the system info screen and press the pound key. The SAT button will flash three times. Now press the record button and see if you now have control over the receiver. If the remote is for a TV2 location ensure the antenna on the back of the receiver is elevated. If this is a TV2 remte and you are still having no suceess and it work previously and it no longer works at the receiver location or TV2 you will need a service call to determine if the antenna port burned out. This is a very rare case and you will more than likely need a new remote. If the remote is for TV2 and it works at the receiver but not TV2 you will need someone to pigtail the antenna or in other words move the antenna closer to the TV2 location. I hope this solves your issue. Let me know if I can be of further assistance. Thanks for using Fix Ya.
Jan 22, 2009 | DISH Network IR Remote Control
Viewsonic power lock
On the tv itself hold down channel up button while holding that press and hold the menu button . this will un lock it
Dec 29, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
Motorola Talkabout Basic
I believe you do not need to hold the monitor button when changing channels
Push the talk button till you have the channel you want then push monitor button to accept
Hope this works
Dec 16, 2008 | Motorola Walkie Talkie 2-Way Radio
Cant work my freeview
The [A/D] button on the remote control switches between analogue and dgitial TV.
If this doesn't work you can restore the TV to factory settings as follows:
Press and hold the [Menu] button on the TV (NOT on the remote)
The picture / sound / features menu will appear.
Continue to hold until this menu clears.
Release the [Menu] button and wait for about 90 seconds.
The TV will go blank and eventually return to the original install menu.
Install the TV as you did from new.
This will clear ALL analogue and digital TV channels and install again from scratch.
This should be used if the TV ever freezes on digital, or if any of the channels appear in the wrong place or not at all.
May 07, 2008 | Televison & Video
POWER BUT NO ACTION
Push and hold your on power button for 2 seconds. Or just hit and hold a channel button for a few seconds.
Mar 02, 2008 | Televison & Video
Uniden BCD-996T Bearcat 6000 Channel Mobile Trunking Digital Scanner Logo
29 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
